使用RT-Stduio建立f429工程,使用UART2输出乱码?
发布于 2020-03-28 22:35:21 浏览:978
首先在board.h中开启串口2的宏定义配置引脚 #define BSP_USING_UART1 #define BSP_USING_UART2 #if defined(BSP_USING_UART1) #define UART1_TX_PORT GPIOA #define UART1_RX_PORT GPIOA #define UART1_TX_PIN GPIO_PIN_9 #define UART1_RX_PIN GPIO_PIN_10 #endif #if defined(BSP_USING_UART2) #define UART2_TX_PORT GPIOA #define UART2_RX_PORT GPIOA #define UART2_TX_PIN GPIO_PIN_2 #define UART2_RX_PIN GPIO_PIN_3 #endif 在main函数中向uart2打印输出,有输出但是乱码,调整了串口接收的波特率2400~115200、奇偶校验都不能正常显示,有人遇到过吗? [图片]() int main(void) { int count = 1; rt_err_t ret = RT_EOK; char uart_name[RT_NAME_MAX]; char str[] = "hello RT-Thread!
"; rt_strncpy(uart_name, SAMPLE_UART_NAME, RT_NAME_MAX); /* 查找系统中的串口设备 */ serial = rt_device_find(uart_name); if (!serial) { rt_kprintf("find %s failed!
", uart_name); return RT_ERROR; } rt_kprintf("find %s OK!
", uart_name); /* 初始化信号量 */ rt_sem_init(&rx_sem, "rx_sem", 0, RT_IPC_FLAG_FIFO); /* 以中断接收及轮询发送模式打开串口设备 */ ret = rt_device_open(serial, RT_DEVICE_FLAG_INT_RX); rt_kprintf("rt_device_open %s %d!
", ret, uart_name); /* 设置接收回调函数 */ rt_device_set_rx_indicate(serial, uart_rx_ind); /* 创建 serial 线程 */ rt_thread_t thread = rt_thread_create("serial", (void (*)(void *parameter))data_parsing, RT_NULL, 1024, 25, 10); /* 创建成功则启动线程 */ if (thread != RT_NULL) { rt_thread_startup(thread); } else { rt_kprintf("rt_thread_startup %s failed!
", uart_name); } /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); rt_thread_init(&oled,"oled",RT_OLED_Entry,RT_NULL,&OLED_stack[0],sizeof(OLED_stack),THREAD_PRIORITY-1, THREAD_TIMESLICE); rt_thread_startup(&oled); while (count++) { /* set LED0 pin level to high or low */ rt_pin_write(LED0_PIN, count % 2); //LOG_D("Hello RT-Thread!"); /* 发送字符串 */ rt_device_write(serial, 0, str, (sizeof(str) - 1)); //rt_kprintf("Hello RT-Thread!!!
", uart_name); rt_thread_mdelay(1000); } return RT_EOK; } ![uart.png](https://oss-club.rt-thread.org/uploads/202003/28/223500v0m0typ0dpbd7ey0.png)
ponysin
2020-03-29
问题已解决,是串口连接电压问题。
978
ponysin
rt_thread studio 啥时候能用呢
RT_Thread使用反馈帖子
RTT studio 下的 AT指令问题。
rt thread Studio 关于J-LINK下载问题
RT-Thread studio 调试设置问题
RTT-Studio 如何设置调试配置参数?
rt_thread studio 软件包配置
RT-Studio目前只能开发STM32的项目吗?
rtt studio 生成hex名字修改
