STM32F103VE+Air720H+AT_Client升级过程分享
发布于 2020-04-14 19:54:52 浏览:1379
* 本帖最后由 yc985055 于 2020-4-14 19:58 编辑 * 这些天一直在测试STM32F103VE通过Air720H的HTTP功能升级固件。 其中参考了官方文档 [https://www.rt-thread.org/docume ... -rtboot/#bootloader](https://www.rt-thread.org/document/site/application-note/system/rtboot/an0028-rtboot/#bootloader) 和以下链接 [https://www.rt-thread.org/qa/for ... ypeid%26typeid%3D64](https://www.rt-thread.org/qa/forum.php?mod=viewthread&tid=423550&extra=page%3D1%26filter%3Dtypeid%26typeid%3D64) 1.下面是擦除download分区和写数据函数。 /*************************************************************************************************** * @fn hw_upgrade_start(void) * * @brief erase flash * * @param * * @return none ****************************************************************************************************/; static void hw_upgrade_start(void) { http_size_bytes = 0; http_size_conts = 0; http_size_conts_max = 0; u16UdpCrc = 0; rt_kprintf("hw_upgrade_start() !!!
"); if ((dl_part = fal_partition_find(recv_partition)) == RT_NULL) { rt_kprintf("Firmware download failed! Partition (%s) find error!", recv_partition); return; } /* erase DL section */ if (fal_partition_erase(dl_part, 0, 196 * 1024) < 0) { rt_kprintf("Firmware download failed! Partition (%s) erase error!", dl_part->name); return ; } //stm32_flash_erase ((rt_uint32_t)INT_FLASH_DOWNLOAD_ADDR, 196 * 1024); } /*************************************************************************************************** * @fn void hw_upgrade_data_save(rt_uint8_t *pDataBuf, rt_uint16_t dataLen) * * @brief save upgrade data to flash * * @param * * @return none ****************************************************************************************************/ static void hw_upgrade_data_save(rt_uint8_t *pDataBuf, rt_uint16_t dataLen) { rt_uint16_t tempU16 = 0; tempU16 = dataLen; //if (tempU16 == stm32_flash_write((rt_uint32_t)INT_FLASH_DOWNLOAD_ADDR + (rt_uint32_t)(http_size_conts * HTTP_SIZE_PER_PKT), pDataBuf, dataLen)) if (fal_partition_write(dl_part, (rt_uint32_t)(http_size_conts * HTTP_SIZE_PER_PKT), pDataBuf, dataLen) > 0) { http_size_conts++; //计算校验,最后两字节是校验值,不参与运算 rt_kprintf("http_size_conts is-%d!!! UdpCrc is 0x%04x !!!0x%02x 0x%02x
", http_size_conts, u16UdpCrc, pDataBuf[tempU16 - 2], pDataBuf[tempU16 - 1]); if (tempU16 < HTTP_SIZE_PER_PKT) { tempU16 -= 2; } for (rt_uint16_t i = 0; i < tempU16; i++) { u16UdpCrc = hw_udp_pkt_run_poly(u16UdpCrc, pDataBuf*); } } else { rt_kprintf("fal_partition_write() error
"); } } 注:其实用stm32_flash_erase(...) stm32_flash_write(...)来执行是一样的,我开始升级不成功,以为是它们的原因。所以调用了ymodem_ota中的两个函数。 2.http读取数据函数。 http线程函数 { case HTTP_READ_DATA: { if ((http_size_bytes - http_size_conts * HTTP_SIZE_PER_PKT) >= HTTP_SIZE_PER_PKT) { u16Temp = HTTP_SIZE_PER_PKT; } else { u16Temp = http_size_bytes - http_size_conts * HTTP_SIZE_PER_PKT; } rt_kprintf("http_size_bytes %d http_size_conts:%d http_size_conts_max:%d
", http_size_bytes, http_size_conts, http_size_conts_max); at_delete_resp(resp); resp = at_create_resp(HTTP_SIZE_PER_PKT + 56, 0, rt_tick_from_millisecond(500)); if(resp == NULL) { rt_kprintf(" create HTTP resp no memory"); } sprintf((char *)HTTP_CMD_READ,(char const *)"%s%d%s%d",(char const *)"AT+HTTPREAD=", (rt_uint32_t)(http_size_conts * HTTP_SIZE_PER_PKT), ",", u16Temp); if (at_exec_cmd(resp, HTTP_CMD_READ) == RT_EOK) { http_read_func(resp); } else { rt_kprintf("at_exec_cmd return error
"); } } } /*************************************************************************************************** * @fn void http_read_func(at_response_t httpReadResp) * * @brief 读取http下载的数据 * * @param none * * @return none ****************************************************************************************************/ static void http_read_func(at_response_t httpReadResp) { rt_bool_t bIsHaveData = RT_FALSE; rt_uint16_t u16Temp ,i; const char *line_buffer = RT_NULL; char *httpReadBuf = RT_NULL; if (httpReadResp == RT_NULL || httpReadResp->line_counts < 4) { return; } httpReadBuf = rt_malloc(HTTP_SIZE_PER_PKT); if (httpReadBuf == RT_NULL) { rt_kprintf("http_read_func out of memory!!
"); } if ((http_size_bytes - http_size_conts * HTTP_SIZE_PER_PKT) >= HTTP_SIZE_PER_PKT) { u16Temp = HTTP_SIZE_PER_PKT; } else { u16Temp = http_size_bytes - http_size_conts * HTTP_SIZE_PER_PKT; } rt_kprintf("The max lines is %d size is %d
", httpReadResp->line_counts, httpReadResp->buf_len); for (rt_size_t line_num = 1; line_num <= httpReadResp->line_counts; line_num++) { if((line_buffer = at_resp_get_line(httpReadResp, line_num)) != RT_NULL) { //找到数据区的前一行 if(strstr(line_buffer, "+HTTPREAD:")) { //找到数据区的首行 if((line_buffer = at_resp_get_line(httpReadResp, line_num + 1)) != RT_NULL) { bIsHaveData = RT_TRUE; break; } } //rt_kprintf("line %d %02x %02x %02x %02x
", line_num, line_buffer[0],line_buffer[1],line_buffer[2],line_buffer[3]); } } if (httpReadResp->line_counts > 4) { for (i = 0; i < u16Temp; i++) { if (line_buffer* == 0x0D && line_buffer[i + 1] == 0x00) { httpReadBuf[i++] = 0x0D; httpReadBuf* = 0x0A; } else { httpReadBuf* = line_buffer*; } } } if (bIsHaveData) { if (httpReadResp->line_counts > 4 ) { hw_upgrade_data_save((rt_uint8_t *)httpReadBuf, u16Temp); } else { hw_upgrade_data_save((rt_uint8_t *)line_buffer, u16Temp); } } //判断是否下载完成 if (http_size_conts >= http_size_conts_max) { //系统重启 air_cur_status = HTTP_TERM; rt_kprintf("System now will restart...u16UdpCrc value is 0x%04x
", u16UdpCrc); hw_upgrade_crc_check(); /* wait some time */ rt_thread_delay(500); rt_hw_cpu_reset(); rt_thread_delay(500); } else { air_cur_status = HTTP_READ_DATA; } rt_free(httpReadBuf); } 注:这里遇到不少问题。 A. 不能用urc函数获取{"+HTTPREAD", "
", urc_http_read_func}. 因为没有结束符。 B. 想用at_client_recv代替at_exec_cmd和at_create_resp函数来读数据。老返回失败 C. 后面在AT_Client中找了,没有合适函数还是用at_exec_cmd和at_create_resp. 这里我通过每条数据包校验打印才发现。at_create_resp以行为单位读取数据,会把文件中的0x0D 0x0A转换成0x0D 0x00。 现在我是做了判断,把数据反转回来。暂时可以这样做,升级没有问题。 **********D.没用采用ota_http升级中的函数,或许会更容易,我是为了减少源码大小。***** *****E期间,我还自己写了C#代码来计算校验值,看是哪个包出错啦。 ***** ***** 在此要感谢以下两位的帮助:面码1314 发表于 2020-4-12 18:07 小小李sunny 发表于 2020-4-12 22:07 *****
jerry4cool
2020-06-19
感谢分享。。。。
2020-06-19
谢谢分享哦
2022-01-14
嵌入式
谢谢分享
1.4k
yc985055
38
进入bootloader的方式探讨
求助:IAP里的APP使用的RTT,跳转后出错。[已解决]
想做网口的IAP远程升级,不知可不可行
IAP问题
