在NANO3.1.3上面添加外部sram作为动态内存池报错
发布于 2020-04-16 16:58:24 浏览:1191
NANO3.1.3默认是用4K的数组作为动态内存池的,,单片机是STM32F407ZGT6我先把它改成使用片内剩余SRAM空间作为动态内存池成功了。但是使用片外IS62WV51216时失败报错了,单独把片外SRAM拿来读写测试了一下是正常的,但是一用做动态内存池就不行了,是什么原因呢?: ![3种方式的首尾地址设置.jpg](/uploads/202004/16/165455txpp3pth9hzunhhh.jpg)![3种方式的堆初始化.jpg](/uploads/202004/16/165455fgg1lnsrg5o5kp5g.jpg)![默认数组方式结果.jpg](/uploads/202004/16/165456uif66oo6935c9ez7.jpg)![使用片内剩余SRAM方式结果.jpg](/uploads/202004/16/165456sv8nyx0xs9qz0qa4.jpg)![使用外部SRAM方式结果.jpg](/uploads/202004/16/165456rol84q88mq488odp.jpg)下面代码是外部SRAM的初始化及读写测试代码。 ```#include "sram.h" #include "usart.h" #include
//使用NOR/SRAM的 Bank1.sector3,地址位HADDR[27,26]=10 //对IS61LV25616/IS62WV25616,地址线范围为A0~A17 //对IS61LV51216/IS62WV51216,地址线范围为A0~A18 #define Bank1_SRAM3_ADDR ((u32)(0x68000000)) //初始化外部SRAM static int FSMC_SRAM_Init(void) { GPIO_InitTypeDef GPIO_InitStructure; FSMC_NORSRAMInitTypeDef FSMC_NORSRAMInitStructure; FSMC_NORSRAMTimingInitTypeDef readWriteTiming; RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOB|RCC_AHB1Periph_GPIOD|RCC_AHB1Periph_GPIOE|RCC_AHB1Periph_GPIOF|RCC_AHB1Periph_GPIOG, ENABLE);//使能PD,PE,PF,PG时钟 RCC_AHB3PeriphClockCmd(RCC_AHB3Periph_FSMC,ENABLE);//使能FSMC时钟 GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;//PB15 推挽输出 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT;//普通输出模式 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化 //PB15 推挽输出 GPIO_InitStructure.GPIO_Pin = (3<<0)|(3<<4)|(0XFF<<8);//PD0,1,4,5,8~15 AF OUT GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOD, &GPIO_InitStructure);//初始化 GPIO_InitStructure.GPIO_Pin = (3<<0)|(0X1FF<<7);//PE0,1,7~15,AF OUT GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOE, &GPIO_InitStructure);//初始化 GPIO_InitStructure.GPIO_Pin = (0X3F<<0)|(0XF<<12); //PF0~5,12~15 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOF, &GPIO_InitStructure);//初始化 GPIO_InitStructure.GPIO_Pin =(0X3F<<0)| GPIO_Pin_10;//PG0~5,10 GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF;//复用输出 GPIO_InitStructure.GPIO_OType = GPIO_OType_PP;//推挽输出 GPIO_InitStructure.GPIO_Speed = GPIO_Speed_100MHz;//100MHz GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_UP;//上拉 GPIO_Init(GPIOG, &GPIO_InitStructure);//初始化 GPIO_PinAFConfig(GPIOD,GPIO_PinSource0,GPIO_AF_FSMC);//PD0,AF12 GPIO_PinAFConfig(GPIOD,GPIO_PinSource1,GPIO_AF_FSMC);//PD1,AF12 GPIO_PinAFConfig(GPIOD,GPIO_PinSource4,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource5,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource8,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource9,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource10,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource11,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource12,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource13,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource14,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOD,GPIO_PinSource15,GPIO_AF_FSMC);//PD15,AF12 GPIO_PinAFConfig(GPIOE,GPIO_PinSource0,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource1,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource7,GPIO_AF_FSMC);//PE7,AF12 GPIO_PinAFConfig(GPIOE,GPIO_PinSource8,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource9,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource10,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource11,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource12,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource13,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource14,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOE,GPIO_PinSource15,GPIO_AF_FSMC);//PE15,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource0,GPIO_AF_FSMC);//PF0,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource1,GPIO_AF_FSMC);//PF1,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource2,GPIO_AF_FSMC);//PF2,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource3,GPIO_AF_FSMC);//PF3,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource4,GPIO_AF_FSMC);//PF4,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource5,GPIO_AF_FSMC);//PF5,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource12,GPIO_AF_FSMC);//PF12,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource13,GPIO_AF_FSMC);//PF13,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource14,GPIO_AF_FSMC);//PF14,AF12 GPIO_PinAFConfig(GPIOF,GPIO_PinSource15,GPIO_AF_FSMC);//PF15,AF12 GPIO_PinAFConfig(GPIOG,GPIO_PinSource0,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOG,GPIO_PinSource1,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOG,GPIO_PinSource2,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOG,GPIO_PinSource3,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOG,GPIO_PinSource4,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOG,GPIO_PinSource5,GPIO_AF_FSMC); GPIO_PinAFConfig(GPIOG,GPIO_PinSource10,GPIO_AF_FSMC); readWriteTiming.FSMC_AddressSetupTime = 0x00; //地址建立时间(ADDSET) readWriteTiming.FSMC_AddressHoldTime = 0x00; //地址保持时间(ADDHLD)模式A未用到 readWriteTiming.FSMC_DataSetupTime = 0x08; ////数据保持时间(DATAST)为9个HCLK 6*9=54ns readWriteTiming.FSMC_BusTurnAroundDuration = 0x00; readWriteTiming.FSMC_CLKDivision = 0x00; readWriteTiming.FSMC_DataLatency = 0x00; readWriteTiming.FSMC_AccessMode = FSMC_AccessMode_A; //模式A FSMC_NORSRAMInitStructure.FSMC_Bank = FSMC_Bank1_NORSRAM3;// 这里我们使用NE3 ,也就对应BTCR[4],[5]。 FSMC_NORSRAMInitStructure.FSMC_DataAddressMux = FSMC_DataAddressMux_Disable; FSMC_NORSRAMInitStructure.FSMC_MemoryType =FSMC_MemoryType_SRAM;// FSMC_MemoryType_SRAM; //SRAM FSMC_NORSRAMInitStructure.FSMC_MemoryDataWidth = FSMC_MemoryDataWidth_16b;//存储器数据宽度为16bit FSMC_NORSRAMInitStructure.FSMC_BurstAccessMode =FSMC_BurstAccessMode_Disable;// FSMC_BurstAccessMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalPolarity = FSMC_WaitSignalPolarity_Low; FSMC_NORSRAMInitStructure.FSMC_AsynchronousWait=FSMC_AsynchronousWait_Disable; FSMC_NORSRAMInitStructure.FSMC_WrapMode = FSMC_WrapMode_Disable; FSMC_NORSRAMInitStructure.FSMC_WaitSignalActive = FSMC_WaitSignalActive_BeforeWaitState; FSMC_NORSRAMInitStructure.FSMC_WriteOperation = FSMC_WriteOperation_Enable; //存储器写使能 FSMC_NORSRAMInitStructure.FSMC_WaitSignal = FSMC_WaitSignal_Disable; FSMC_NORSRAMInitStructure.FSMC_ExtendedMode = FSMC_ExtendedMode_Disable; // 读写使用相同的时序 FSMC_NORSRAMInitStructure.FSMC_WriteBurst = FSMC_WriteBurst_Disable; FSMC_NORSRAMInitStructure.FSMC_ReadWriteTimingStruct = &readWriteTiming; FSMC_NORSRAMInitStructure.FSMC_WriteTimingStruct = &readWriteTiming; //读写同样时序 FSMC_NORSRAMInit(&FSMC_NORSRAMInitStructure); //初始化FSMC配置 FSMC_NORSRAMCmd(FSMC_Bank1_NORSRAM3, ENABLE); // 使能BANK1区域3 return 0; } INIT_BOARD_EXPORT(FSMC_SRAM_Init); //在指定地址(WriteAddr+Bank1_SRAM3_ADDR)开始,连续写入n个字节. //pBuffer:字节指针 //WriteAddr:要写入的地址 //n:要写入的字节数 void FSMC_SRAM_WriteBuffer(u8* pBuffer,u32 WriteAddr,u32 n) { for(;n!=0;n--) { *(vu8*)(Bank1_SRAM3_ADDR+WriteAddr)=*pBuffer; WriteAddr++; pBuffer++; } } //在指定地址((WriteAddr+Bank1_SRAM3_ADDR))开始,连续读出n个字节. //pBuffer:字节指针 //ReadAddr:要读出的起始地址 //n:要写入的字节数 void FSMC_SRAM_ReadBuffer(u8* pBuffer,u32 ReadAddr,u32 n) { for(;n!=0;n--) { *pBuffer++=*(vu8*)(Bank1_SRAM3_ADDR+ReadAddr); ReadAddr++; } } //外部内存测试(最大支持1M字节内存测试) void fsmc_sram_test(u16 x,u16 y) { u32 i=0; u8 temp=0; u8 sval=0; //在地址0读到的数据 //每隔4K字节,写入一个数据,总共写入256个数据,刚好是1M字节 for(i=0;i<1024*1024;i+=4096) { FSMC_SRAM_WriteBuffer(&temp,i,1); temp++; } //依次读出之前写入的数据,进行校验 for(i=0;i<1024*1024;i+=4096) { FSMC_SRAM_ReadBuffer(&temp,i,1); if(i==0)sval=temp; else if(temp<=sval)break;//后面读出的数据一定要比第一次读到的数据大. rt_kprintf("Ex Memory Test: %dKB
", (temp-sval+1)*4); } } MSH_CMD_EXPORT(fsmc_sram_test, fsmc_sram_test);```![片外SRAM读写正常测试.jpg](/uploads/202004/16/165456reh4v2l2wpahf6ca.jpg)
游泳的鱼儿
2020-10-30
楼主弄好这个了吗 我也是这个问题 setting里内存管理选择all好像就可以了 但是会在串口输出一大堆东西
1.2k
DX_RTT
新手请教关于hardfault怎么查
STM32F1+RTT串口接收中断进入hardfault
STM32F746NG随机进入hardfault(已解决)
MCXN947测评系列(二)串口设备测评
