RW007使用SPI方式异常
发布于 2020-04-18 22:18:37 浏览:1360
执行 wifi scan 命令总是扫描失败或者卡住,如下: ![RW007_wifi_scan_failed.png](/uploads/202004/18/221724myaa9zoz9oeygr1g.png) 工程是根据 [https://www.rt-thread.org/document/site/application-note/packages/rw007_module_using/an0034-rw007-module-using/](https://www.rt-thread.org/document/site/application-note/packages/rw007_module_using/an0034-rw007-module-using/) 教程搭建的,使用 SPI 模式在 NUCLEO-F401RE 上连接 RW007 模块,Menuconfig 配置,包括 SPI 引脚配置都是一样的,rw007 软件包的几个版本都试过了,还是不行......
sync
2020-04-20
也在用rw007,这个问题还没遇到过,帮顶下
阿基米东
2020-04-20
https://github.com/luhuadong
今天把调试串口焊上,直接在rw007上执行 wifi scan,第一次可以找到WiFi,第二次再扫就出错了!如下: ``` [446715]WiFi: Scan is running. Wait 2s timeout.ERROR: wifi scan failed ```
阿基米东
2020-04-20
然后让板子飞了一会儿,居然满屏的Error:L ``` [add_mem_usage] Catch a mem alloc fail with size of 32, current heap free size = 16384 ```
阿基米东
2020-04-20
怎么感觉这么水。。。文档也不齐全。。。 附上RW007的启动信息,看看我是不是要更新固件: ``` \ | / - RT - Thread Operating System / | \ 3.1.1 build Dec 19 2019 2006 - 2018 Copyright by rt-thread team lwIP-2.0.2 initialized! LDO Mode, BD_Info: 0 LDO Mode, BD_Info: 0 i2c_idx:0 [I/SAL_SOC] Socket Abstraction Layer initialize success. [start_value]: 1 SPI raw mode init [I/WLAN.dev] wlan init success [I/WLAN.lwip] eth device init ok name:w0 [I/WLAN.dev] wlan init success [I/WLAN.lwip] eth device init ok name:w1 [D/FAL] (fal_flash_init:63) Flash device | norflash0 . [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | app | norflash0 | 0x0000b000 | 0x00135000 | [I/FAL] | env | norflash0 | 0x00140000 | 0x00001000 | [I/FAL] | download | norflash0 | 0x00141000 | 0x000af000 | [I/FAL] | bootloader | norflash0 | 0x001f0000 | 0x0000f000 | [I/FAL] | rdp | norflash0 | 0x001ff000 | 0x00001000 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer (V0.2.0) initialize succes. [Flash] (packages/EasyFlash/src/ef_env.c:152) ENV start address is 0. [Flash] (packages/EasyFlash/src/ef_env.c:821) Calculate ENV CRC32 nu. [Flash] (packages/EasyFlash/src/ef_env.c:833) Verify ENV CRC32 resul. [Flash] EasyFlash V3.2.3 is initialize success. [Flash] You can get the latest version on https://github.com/armink/. Mac:88:97:46:07:cc:a5 rw007 sn: [rw007746978800a5cc] rw007 ver: [1.2.9-72a55281-28908] build time: Dec 19 2019 11:19:44 Hello RT-Thread! [Flash] (packages/EasyFlash/src/ef_env.c:152) ENV start address is 0. [Flash] (packages/EasyFlash/src/ef_env.c:821) Calculate ENV CRC32 nu. [Flash] (packages/EasyFlash/src/ef_env.c:833) Verify ENV CRC32 resul. [Flash] EasyFlash V3.2.3 is initialize success. [Flash] You can get the latest version on https://github.com/armink/. msh /> ```
阿基米东
2020-04-20
有内存溢出。。。 启动后查看内存情况: ``` msh />free total memory: 113532 used memory : 75592 maximum allocated memory: 77800 ``` 执行 wifi scan 扫描失败,一段时间后再查看: ``` msh />free total memory: 113532 used memory : 96640 maximum allocated memory: 96640 msh />free total memory: 113532 used memory : 98240 maximum allocated memory: 98240 msh />free total memory: 113532 used memory : 100000 maximum allocated memory: 100000 msh />free total memory: 113532 used memory : 101280 maximum allocated memory: 101280 msh />free total memory: 113532 used memory : 104160 maximum allocated memory: 104160 msh />free total memory: 113532 used memory : 107360 maximum allocated memory: 107436 msh />free total memory: 113532 used memory : 111360 maximum allocated memory: 111360 msh />free total memory: 113532 used memory : 112000 maximum allocated memory: 112236 msh />free total memory: 113532 used memory : 113280 maximum allocated memory: 113280 msh /> [add_mem_usage] Catch a mem alloc fail with size of 32, current heap free size = 16384 [add_mem_usage] Catch a mem alloc fail with size of 32, current heap free size = 16384 [add_mem_usage] Catch a mem alloc fail with size of 32, current heap free size = 16384 [add_mem_usage] Catch a mem alloc fail with size of 32, current heap free size = 16384 [add_mem_usage] Catch a mem alloc fail with size of 32, current heap free size = 16384 [add_mem_usage] Catch a mem alloc fail with size of 32, current heap free size = 16384 ```
阿基米东
2020-04-20
### 异常复现 - 启动后通过调试串口进入RW007,第一次执行 `wifi scan` 扫描成功,但内存占用不断升高,再次扫描时会失败。 - 在RW007调试串口中执行 `reboot` 重启模块,多次执行 `wifi scan` 均正常。
阿基米东
2020-04-20
:L难道只有我一个人遇到这种问题???
sync
2020-04-22
[https://www.rt-thread.org/qa/thread-424041-1-1.html](https://www.rt-thread.org/qa/thread-424041-1-1.html) 我这个帖子里面也打印了rw007的启动信息,看起来是一样的 楼主的问题还真没遇到了
sync
2020-04-22
rw007不能连接5G 注意下
阿基米东
2020-04-22
>rw007不能连接5G 注意下 --- 我连的是2.4G :'(
1.4k
阿基米东
52
