http_ota
AT8266来进行HTTP OTA 失败
发布于 2020-04-23 11:32:39 浏览:2268
用串口传输没问题,请问怎么解决呢?片子是STM32F103RET6。 信息如下: ``` msh />http_ota using uri: [http://******************rtthread.elf](http://iot.api.indota.cn/apk/rtthread.elf) [35738] E/at.skt.esp: no memory receive buffer(14[35743] W/UART: Warning: There is no enough buffer for saving data, please increase the RT_SERIAL_RB_BUFSZ option. 60). [35981] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [36110] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [36238] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [36367] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [36496] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [36624] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [36752] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [36880] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [37008] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [37136] E/at.clnt: read line failed. The line data length is out of buffer size(512)! [37265] E/at.clnt: read line failed. The line data length is out of buffer size(512)! http file_si[37393] E/at.clnt: read line failed. The line data length is out of buffer size(512)! ze:1047192 把串口buffer加大到4096也不管用 msh />http_ota using uri: [http://iot.api.indota.cn/apk/rtthread.rbl](http://iot.api.indota.cn/apk/rtthread.rbl) [15415] E/at.skt.esp: no memory receive buffer(1460). [15543] E/at.skt.esp: no memory receive buffer(1460). [15673] E/at.skt.esp: no memory receive buffer(1459). [15801] E/at.skt.esp: no memory receive buffer(1460). [15929] E/at.skt.esp: no memory receive buffer(1460). [16058] E/at.skt.esp: no memory receive buffer(1459). [16186] E/at.skt.esp: no memory receive buffer(1460). [16314] E/at.skt.esp: no memory receive buffer(1460). [16444] E/at.skt.esp: no memory receive buffer(1459). [16572] E/at.skt.esp: no memory receive buffer(1460). [16700] E/at.skt.esp: no memory receive buffer(1460). [16829] E/at.skt.esp: no memory receive buffer(1459). [16957] E/at.skt.esp: no memory receive buffer(1460). [17085] E/at.skt.esp: no memory receive buffer(1460). [17213] E/at.skt.esp: no memory receive buffer(1460). [17341] E/at.skt.esp: no memory receive buffer(1460). [17470] E/at.skt.esp: no memory receive buffer(1460). [17598] E/at.skt.esp: no memory receive buffer(1460). [17726] E/at.skt.esp: no memory receive buffer(1460). [17854] E/at.skt.esp: no memory receive buffer(1460). [17983] E/at.skt.esp: no memory receive buffer(1459). [18111] E/at.skt.esp: no memory receive buffer(1460). [18239] E/at.skt.esp: no memory receive buffer(1460). [18369] E/at.skt.esp: no memory receive buffer(1459). [18497] E/at.skt.esp: no memory receive buffer(1460). [18625] E/at.skt.esp: no memory receive buffer(1460). [18754] E/at.skt.esp: no memory receive buffer(1459). [18882] E/at.skt.esp: no memory receive buffer(1460). [19010] E/at.skt.esp: no memory receive buffer(1460). [19140] E/at.skt.esp: no memory receive buffer(1459). [19268] E/at.skt.esp: no memory receive buffer(1460). [19396] E/at.skt.esp: no memory receive buffer(1460). [19525] E/at.skt.esp: no memory receive buffer(1459). [19653] E/at.skt.esp: no memory receive buffer(1460). [19781] E/at.skt.esp: no memory receive buffer(1460). [19910] E/at.skt.esp: no memory receive buffer(1459). [20038] E/at.skt.esp: no memory receive buffer(1460). [20166] E/at.skt.esp: no memory receive buffer(1460). [20296] E/at.skt.esp: no memory receive buffer(1459). [20424] E/at.skt.esp: no memory receive buffer(1460). [20552] E/at.skt.esp: no memory receive buffer(1460). [20681] E/at.skt.esp: no memory receive buffer(1459). [20809] E/at.skt.esp: no memory receive buffer(1460). [20937] E/at.skt.esp: no memory receive buffer(1460). [21066] E/at.skt.esp: no memory receive buffer(1459). [21194] E/at.skt.esp: no memory receive buffer(1460). [21323] E/at.skt.esp: no memory receive buffer(1460). [21452] E/at.skt.esp: no memory receive buffer(1459). [21580] E/at.skt.esp: no memory receive buffer(1460). [21708] E/at.skt.esp: no memory receive buffer(1460). [21837] E/at.skt.esp: no memory receive buffer(1459). [21965] E/at.skt.esp: no memory receive buffer(1460). [22093] E/at.skt.esp: no memory receive buffer(1460). [22223] E/at.skt.esp: no memory receive buffer(1459). [22351] E/at.skt.esp: no memory receive buffer(1460). [22479] E/at.skt.esp: no memory receive buffer(1460). [22607] E/at.skt.esp: no memory receive buffer(1460). [22735] E/at.skt.esp: no memory receive buffer(1460). [22863] E/at.skt.esp: no memory receive buffer(1460). [22991] E/at.skt.esp: no memory receive buffer(1460). [23119] E/at.skt.esp: no memory receive buffer(1460). [23248] E/at.skt.esp: no memory receive buffer(1460). [23376] E/at.skt.esp: no memory receive buffer(1460). [23504] E/at.skt.esp: no memory receive buffer(1460). [23632] E/at.skt.esp: no memory receive buffer(1460). [23760] E/at.skt.esp: no memory receive buffer(1460). [23888] E/at.skt.esp: no memory receive buffer(856). http file_size:123232 [23972] I/http_ota: Start erase flash (download) partition! [24439] I/http_ota: Erase flash (download) partition success! [24446] E/http_ota: No memory for http ota! ```
Exculivor
2020-04-25
各位大佬有人能帮助解决一下吗?
Exculivor
2020-04-27
没人用8266升级固件吗?
Exculivor
2020-04-27
各位哥哥姐姐们,求助没人理的吗?
2020-04-27
没遇到过这个问题
2020-04-27
感觉你这个像是at驱动或者是串口都没配置好,因为从开始接收数据都是no memory 。到后边OTA时创建http_ota 的buffer也失败。 建议你先看看8266有么有初始化成功?或者在msh指令那里直接用at client 来测试一下,at指令是否正常?用at指令进行一些网络通信能否成功,传输数据能否正常?逐步排查一下吧。
Exculivor
2020-04-29
>感觉你这个像是at驱动或者是串口都没配置好,因为从开始接收数据都是no memory 。到后边OTA时创建http_ota ... 应该是芯片RAM不足导致的,用的F103RET6只有64K .刚重新打板用的F412RE,有256K,不知道够不够,等回来测试下
2020-04-29
>应该是芯片RAM不足导致的,用的F103RET6只有64K .刚重新打板用的F412RE,有256K,不知道够不够,等回来测 ... --- 应该不是芯片ram不足导致的,加ram不能根本上解决问题 注意你获取文件大小 ``` http file_size:123232 ``` 这一句在获取到全部固件数据之后才打印出来,**猜测是等待send ok超时了**,send函数被阻塞,不能及时处理urc数据
2020-04-29
昨天用的sim800c,f103ret6,也是64k的ram,230k的固件完美更新:lol
Exculivor
2020-04-29
>昨天用的sim800c,f103ret6,也是64k的ram,230k的固件完美更新 --- 程序烧录进去之后还剩多少RAM可用啊?
2020-04-29
>程序烧录进去之后还剩多少RAM可用啊? --- 下载成功的话全程ram最高占用不到8k,下载完成就释放了
2.3k
Exculivor
rt-thread 2g/3g/4g通信模块的教程有吗?
基于AT指令,用esp8266如何连接mqtt?
AT组件使用问题
官方AT客户端应用笔记的几个小tip
RTT的SAL能够判断使用LWIP或者AT?
rt_therad AT组件移植不成功(结贴)
AT组件在哪个版本的?
AT组件 连接 Onenet 连接失败
esp8266 AT指令 MQTT连接问题
AT组件使用问题之模块主动上报【已解决】
