Kernel
消息队列接收rt_mq_recv是否存在缺陷?
发布于 2020-04-29 10:47:17 浏览:1564
* 本帖最后由 jszhou 于 2020-4-29 11:01 编辑 * 现在问题是这样的,我发现接收完消息队列后,msg_pool里面的数据并没有被清空,以下是我的代码:```static struct rt_messagequeue usbmq; static rt_uint8_t msg_pool[5][1024];``````rt_mq_init(&usbmq, "usbmqg", &msg_pool, sizeof(msg_pool[0]), sizeof(msg_pool), RT_IPC_FLAG_FIFO);``````rt_mq_send(&usbmq, keyboard_recev_data_pro.data, keyboard_recev_data_pro.len); rt_memset(keyboard_recev_data_pro.data, 0x00, keyboard_recev_data_pro.len); keyboard_recev_data_pro.len = 0;`````` if((usbmq_hid_recv(hidbuf) == RT_EOK)) { hidbuflen = rt_strlen(hidbuf); ......//这里是我的数据处理接口 rt_memset(hidbuf, 0x00, hidbuflen); hidbuflen = 0; }```当我把内核ipc.c的rt_mq_recv改成如下代码时(加了一个清空的函数),问题就没有了 ```rt_err_t rt_mq_recv(rt_mq_t mq, void *buffer, rt_size_t size, rt_int32_t timeout) { struct rt_thread *thread; register rt_ubase_t temp; struct rt_mq_message *msg; rt_uint32_t tick_delta; RT_ASSERT(mq != RT_NULL); RT_ASSERT(buffer != RT_NULL); RT_ASSERT(size != 0); /* initialize delta tick */ tick_delta = 0; /* get current thread */ thread = rt_thread_self(); RT_OBJECT_HOOK_CALL(rt_object_trytake_hook, (&(mq->parent.parent))); /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* for non-blocking call */ if (mq->entry == 0 && timeout == 0) { rt_hw_interrupt_enable(temp); return -RT_ETIMEOUT; } /* message queue is empty */ while (mq->entry == 0) { RT_DEBUG_IN_THREAD_CONTEXT; /* reset error number in thread */ thread->error = RT_EOK; /* no waiting, return timeout */ if (timeout == 0) { /* enable interrupt */ rt_hw_interrupt_enable(temp); thread->error = -RT_ETIMEOUT; return -RT_ETIMEOUT; } /* suspend current thread */ rt_ipc_list_suspend(&(mq->parent.suspend_thread), thread, mq->parent.parent.flag); /* has waiting time, start thread timer */ if (timeout > 0) { /* get the start tick of timer */ tick_delta = rt_tick_get(); RT_DEBUG_LOG(RT_DEBUG_IPC, ("set thread:%s to timer list
", thread->name)); /* reset the timeout of thread timer and start it */ rt_timer_control(&(thread->thread_timer), RT_TIMER_CTRL_SET_TIME, &timeout); rt_timer_start(&(thread->thread_timer)); } /* enable interrupt */ rt_hw_interrupt_enable(temp); /* re-schedule */ rt_schedule(); /* recv message */ if (thread->error != RT_EOK) { /* return error */ return thread->error; } /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* if it's not waiting forever and then re-calculate timeout tick */ if (timeout > 0) { tick_delta = rt_tick_get() - tick_delta; timeout -= tick_delta; if (timeout < 0) timeout = 0; } } /* get message from queue */ msg = (struct rt_mq_message *)mq->msg_queue_head; /* move message queue head */ mq->msg_queue_head = msg->next; /* reach queue tail, set to NULL */ if (mq->msg_queue_tail == msg) mq->msg_queue_tail = RT_NULL; /* decrease message entry */ mq->entry --; /* enable interrupt */ rt_hw_interrupt_enable(temp); /* copy message */ rt_memcpy(buffer, msg + 1, size > mq->msg_size ? mq->msg_size : size); rt_memset(msg + 1, 0x00, size > mq->msg_size ? mq->msg_size : size); //这里是我添加的测试代码 /* disable interrupt */ temp = rt_hw_interrupt_disable(); /* put message to free list */ msg->next = (struct rt_mq_message *)mq->msg_queue_free; mq->msg_queue_free = msg; /* enable interrupt */ rt_hw_interrupt_enable(temp); RT_OBJECT_HOOK_CALL(rt_object_take_hook, (&(mq->parent.parent))); return RT_EOK; }```不知道这个算不算是原来ipc消息队列接收机制的缺陷,还是我用法有什么问题,还请官方大佬给指点指点!!!
liuxy
2020-11-26
我也遇到了同样的问题,感觉你的解决方法靠谱
1.6k
jszhou
cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
