USB OTG
对ST fullspeed usb otg(dual role)实现的探索
发布于 2020-05-03 15:45:29 浏览:1146
像安卓手机连接PC时,手机就当做设备,当使用OTG线连接时,手机就当做主机使用。 类似上述功能在ST的cubemx并没有看到实现 ![dual.png](https://oss-club.rt-thread.org/uploads/202005/02/230814aonepptnv5n5znnv.png) **STSW-STM32046**里面有USB_Host_Device_Examples,但并没有通过ID触发实现主从切换。 通过阅读ST LL库关于USB这块代码,在USB_DevInit和USB_HostInit中都有这么一句代码: ```c /* Disable all interrupts. */ USBx->GINTMSK = 0U; ``` 然后只开启相关部分中断,并没有开启OTG的CIDSCHGM中断,当然就没法使用ID触发主从切换。 好吧,还是仿写个LL USB库算了。 ```c struct rt_st_fsusb { USB_OTG_GlobalTypeDef* global_register; USB_OTG_HostTypeDef* host_register; volatile rt_uint32_t* host_port_register; USB_OTG_HostChannelTypeDef* host_channel_registers[32]; USB_OTG_DeviceTypeDef* peripheral_register; USB_OTG_INEndpointTypeDef* peripheral_inendpoint_registers[16]; USB_OTG_OUTEndpointTypeDef* peripheral_outendpoint_registers[16]; volatile rt_uint32_t* fifo_start_address; volatile rt_uint32_t* power_clock_register; rt_uint32_t peripheral_endpoint_count; rt_uint32_t host_channel_count; }; typedef struct rt_st_fsusb* rt_st_fsusb_t; ``` ```c rt_err_t rt_st_fsusb_register_init(rt_st_fsusb_t st_fsusb, int peripheral_endpoint_count, int host_channel_count); rt_err_t rt_st_fsusb_core_reset(rt_st_fsusb_t st_fsusb); void rt_st_fsusb_set_fullspeed_transceiver(rt_st_fsusb_t st_fsusb); void rt_st_fsusb_enable_vbus_sensing(rt_st_fsusb_t st_fsusb, rt_bool_t is_true); rt_err_t rt_st_fsusb_enable_output_vbus(rt_st_fsusb_t st_fsusb, rt_bool_t is_true); rt_uint32_t rt_st_fsusb_get_current_mode(rt_st_fsusb_t st_fsusb); void rt_st_fsusb_enable_global_interrupts(rt_st_fsusb_t st_fsusb, rt_bool_t is_true); void rt_st_fsusb_set_global_interrupts(rt_st_fsusb_t st_fsusb, rt_uint32_t value); rt_uint32_t rt_st_fsusb_read_global_interrupts_state(rt_st_fsusb_t st_fsusb); void rt_st_fsusb_clear_global_interrupts_state(rt_st_fsusb_t st_fsusb, rt_uint32_t value); rt_err_t rt_st_fsusb_write_packet_in_tx_fifo(rt_st_fsusb_t st_fsusb, rt_uint8_t channel_endpoint_number, rt_uint8_t* packet_buffer, rt_uint16_t packet_size); void rt_st_fsusb_read_packet_in_rx_fifo(rt_st_fsusb_t st_fsusb, rt_uint8_t* packet_buffer, rt_uint16_t size); rt_err_t rt_st_fsusb_flush_tx_fifo(rt_st_fsusb_t st_fsusb, rt_uint32_t number); rt_err_t rt_st_fsusb_flush_rx_fifo(rt_st_fsusb_t st_fsusb); rt_err_t rt_st_fsusb_peripheral_create(rt_st_fsusb_t st_fsusb); rt_err_t rt_st_fsusb_peripheral_destroy(rt_st_fsusb_t st_fsusb); void rt_st_fsusb_peripheral_enable_connect(rt_st_fsusb_t st_fsusb, rt_bool_t is_true); rt_err_t rt_st_fsusb_host_create(rt_st_fsusb_t st_fsusb); rt_err_t rt_st_fsusb_host_destroy(rt_st_fsusb_t st_fsusb); ``` 初始化USB OTG,关全局中断-->phy core 复位-->"activate the transceiver in transmission/reception"-->取消vbus检测-->设置开启的中断。 ```c static void rt_hw_usb_init() { GPIO_InitTypeDef GPIO_InitStruct = { 0 }; GPIO_InitTypeDef GPIO_InitStruct_ID = { 0 }; rt_st_fsusb_register_init(&stm32_otg, 4, 8); __HAL_RCC_GPIOA_CLK_ENABLE() ; /**USB_OTG_FS GPIO Configuration PA11 ------> USB_OTG_FS_DM PA12 ------> USB_OTG_FS_DP */ GPIO_InitStruct.Pin = GPIO_PIN_11 | GPIO_PIN_12; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF10_OTG_FS; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); GPIO_InitStruct_ID.Pin = GPIO_PIN_10; GPIO_InitStruct_ID.Mode = GPIO_MODE_AF_OD; GPIO_InitStruct_ID.Pull = GPIO_PULLUP; GPIO_InitStruct_ID.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct_ID.Alternate = GPIO_AF10_OTG_FS; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct_ID); /* Peripheral clock enable */ __HAL_RCC_USB_OTG_FS_CLK_ENABLE() ; /* USB_OTG_FS interrupt Init */ HAL_NVIC_SetPriority(OTG_FS_IRQn, 0, 0); HAL_NVIC_EnableIRQ(OTG_FS_IRQn); rt_st_fsusb_enable_global_interrupts(&stm32_otg, RT_FALSE); rt_st_fsusb_core_reset(&stm32_otg); rt_st_fsusb_set_fullspeed_transceiver(&stm32_otg); rt_st_fsusb_enable_vbus_sensing(&stm32_otg, RT_FALSE); rt_st_fsusb_set_global_interrupts(&stm32_otg, (common_interrup_mask | host_interrup_mask | device_interrupt_mask)); } ``` 开启的中断: ```c static const rt_uint32_t common_interrup_mask = USB_OTG_GINTMSK_WUIM | USB_OTG_GINTMSK_SRQIM | USB_OTG_GINTMSK_CIDSCHGM | USB_OTG_GINTMSK_RXFLVLM | /*USB_OTG_GINTMSK_SOFM |*/ USB_OTG_GINTMSK_OTGINT | USB_OTG_GINTMSK_MMISM; static const rt_uint32_t host_interrup_mask = /*USB_OTG_GINTMSK_PTXFEM |*/ USB_OTG_GINTMSK_HCIM | USB_OTG_GINTMSK_PRTIM | USB_OTG_GINTMSK_PXFRM_IISOOXFRM; /*USB_OTG_GINTMSK_NPTXFEM |*/ static const rt_uint32_t device_interrupt_mask = USB_OTG_GINTMSK_DISCINT | USB_OTG_GINTMSK_PXFRM_IISOOXFRM | USB_OTG_GINTMSK_IISOIXFRM | USB_OTG_GINTMSK_OEPINT | USB_OTG_GINTMSK_IEPINT | /*USB_OTG_GINTMSK_EOPFM |*/ USB_OTG_GINTMSK_ISOODRPM | USB_OTG_GINTMSK_ENUMDNEM | USB_OTG_GINTMSK_USBRST | USB_OTG_GINTMSK_USBSUSPM | USB_OTG_GINTMSK_ESUSPM | USB_OTG_GINTMSK_GONAKEFFM | USB_OTG_GINTMSK_GINAKEFFM; ``` 剩下的就是中断处理了。rt-thread现有的USB框架没有实现主从切换,尝试先实现一个otg_controller: ```c struct rt_usb_otg_controller { struct rt_usb_slave_controller slave_controller; struct rt_usb_host_controller host_controller; void (*process_interrupt_role_change)(struct rt_usb_otg_controller* controller, rt_usb_data_role_type_t type); }; typedef struct rt_usb_otg_controller* rt_usb_otg_controller_t;``````static void process_interrupt_role_change(rt_usb_otg_controller_t controller, rt_usb_data_role_type_t type) { if (type == RT_USB_DATA_ROLE_TYPE_HOST) { rt_kprintf("usb role change: host mode.
"); controller->slave_controller.stop_role_instance(&controller->slave_controller); controller->host_controller.start_role_instance(&controller->host_controller); } else { rt_kprintf("usb role change: slave mode
"); controller->host_controller.stop_role_instance(&controller->host_controller); controller->slave_controller.start_role_instance(&controller->slave_controller); } } ``` ID触发中断处理: ```c if (USB_OTG_GINTSTS_CIDSCHG & global_interrupt) { rt_st_fsusb_clear_global_interrupts_state(&stm32_otg, USB_OTG_GINTSTS_CIDSCHG); if (stm32_otg.global_register->GOTGCTL & USB_OTG_GOTGCTL_CIDSTS) { // device mode otg_controller.process_interrupt_role_change(&otg_controller, RT_USB_DATA_ROLE_TYPE_SLAVE); } else { //host mode otg_controller.process_interrupt_role_change(&otg_controller, RT_USB_DATA_ROLE_TYPE_HOST); } } ``` 串口输出: ``` \ | / - RT - Thread Operating System / | \ 4.0.2 build May 3 2020 2006 - 2019 Copyright by rt-thread team boot rtusb dev version: v0.05. comm interrupt srq usb role change: slave mode msh >device interrupt usb reset. device interrupt enum done. device interrupt epnum = 0, size = 8, datapid = 0, packet type = 6 80 06 00 01 00 00 40 00 device interrupt epnum = 0, size = 0, datapid = 0, packet type = 4 device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. comm interrupt usb role change: host mode. comm interrupt usb role change: slave mode device interrupt usb early suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. device interrupt usb early suspend. device interrupt usb suspend. comm interrupt usb role change: host mode. host interrupt new host port host interrupt port disconnect ```
1.1k
charlown.cai
52
请教USB Host
STM32F4调试USB 读卡器(Slave)提示格式化
USB 框架问题
USB键盘
LPC17xx 如何添加USB HOST设备
RT-Thread目前支持USB HOST了吗?
USB HOST的支持问题
USB库已经很久没更新了
