串口波特率修改无效!
发布于 2020-05-18 14:45:00 浏览:2063
rt_err_t thread; struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; //初始化配置参数 rt_sem_init(&rx485_sem, "rx485_sem", 0, RT_IPC_FLAG_FIFO); //初始化信号量 config.baud_rate = BAUD_RATE_9600; config.data_bits = DATA_BITS_9; config.parity = PARITY_EVEN; config.bufsz = 128; dev_rs485 = rt_device_find(UART485_NAME); if(rt_device_control(dev_rs485,RT_DEVICE_CTRL_CONFIG,&config) == RT_EOK) rt_kprintf("控制成功
"); //drv_485_bsp_set(device_set_parameter.RS485_bsp); rt_device_open(dev_rs485,RT_DEVICE_FLAG_INT_RX); rt_device_set_rx_indicate(dev_rs485, uart485_callback); //设置接收回调函数 这是我初始化的串口波特率 9600,对的! 然后 void drv_485_bsp_set(uint8_t mode) { struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; //初始化配置参数 config.data_bits = DATA_BITS_9; config.baud_rate = BAUD_RATE_9600; config.parity = PARITY_EVEN; config.bufsz = 128; dev_rs485 = rt_device_find(UART485_NAME); if(rt_device_close(dev_rs485) == RT_EOK) rt_kprintf("关闭成功
"); dev_rs485 = rt_device_find(UART485_NAME); if(mode == 0) config.baud_rate = BAUD_RATE_9600; else if(mode == 1) config.baud_rate = BAUD_RATE_4800; else if(mode == 2) config.baud_rate = BAUD_RATE_19200; else if(mode == 3) config.baud_rate = BAUD_RATE_38400; else if(mode == 4) config.baud_rate = BAUD_RATE_57600; else if(mode == 5) config.baud_rate = BAUD_RATE_115200; if(rt_device_control(dev_rs485,RT_DEVICE_CTRL_CONFIG,&config) == RT_EOK) rt_kprintf("控制成功
"); rt_device_open(dev_rs485,RT_DEVICE_FLAG_INT_RX); rt_device_set_rx_indicate(dev_rs485, uart485_callback); //设置接收回调函数 } 我修改了波特率,但是无效,串口还是好的,波特率还是9600! 这是什么情况啊,哪里没设置对吗? 操作前也先关闭了设备!
ASPHYXIA
2020-06-22
你好,最后有解决么
ifreecoding
2020-06-22
drv_485_bsp_set函数中调用顺序: rt_device_find rt_device_close rt_device_find rt_device_control rt_device_open 顺序错了吧,close之后find,open了才能control
cxhxy12345
2021-03-20
close之后,前面对位,校验的操作在后面就丢失了,如果你只是修改波特率,为什么不如下操作: void drv_485_bsp_set(uint8_t mode) { struct serial_configure config = RT_SERIAL_CONFIG_DEFAULT; //初始化配置参数 config.data_bits = DATA_BITS_9; config.baud_rate = BAUD_RATE_9600; config.parity = PARITY_EVEN; config.bufsz = 128; if(mode == 0) config.baud_rate = BAUD_RATE_9600; else if(mode == 1) config.baud_rate = BAUD_RATE_4800; else if(mode == 2) config.baud_rate = BAUD_RATE_19200; else if(mode == 3) config.baud_rate = BAUD_RATE_38400; else if(mode == 4) config.baud_rate = BAUD_RATE_57600; else if(mode == 5) config.baud_rate = BAUD_RATE_115200; dev_rs485 = rt_device_find(UART485_NAME); if(rt_device_control(dev_rs485,RT_DEVICE_CTRL_CONFIG,&config) == RT_EOK) rt_kprintf("控制成功\n"); rt_device_open(dev_rs485,RT_DEVICE_FLAG_INT_RX); rt_device_set_rx_indicate(dev_rs485, uart485_callback); //设置接收回调函数 } 这样不就可以了,为什么要先close了呢?
2021-03-21
open串口设备之后,缓冲区大小不可再进行更改。但除过缓冲区之外的其他参数,在 open 设备前 / 后,均可进行更改。请查阅文档:https://www.rt-thread.org/document/site/programming-manual/device/uart/uart/
2.1k
db520136
23
