CC2538移植到RT-Thread-nano启动文件
发布于 2020-05-20 19:54:32 浏览:864
```//***************************************************************************** //! @file startup_iar.c //! @brief Startup code for CC2538 for use with IAR EWARM. //! //! Revised $Date: 2013-04-29 14:48:18 +0200 (Mon, 29 Apr 2013) $ //! Revision $Revision: 9929 $ // // Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/ // // // Redistribution and use in source and binary forms, with or without // modification, are permitted provided that the following conditions // are met: // // Redistributions of source code must retain the above copyright // notice, this list of conditions and the following disclaimer. // // Redistributions in binary form must reproduce the above copyright // notice, this list of conditions and the following disclaimer in the // documentation and/or other materials provided with the distribution. // // Neither the name of Texas Instruments Incorporated nor the names of // its contributors may be used to endorse or promote products derived // from this software without specific prior written permission. // // THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS // "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT // LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR // A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT // OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, // SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT // LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, // DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY // THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT // (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE // OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE. //****************************************************************************/ #include
#define FLASH_START_ADDR 0x00200000 #define BOOTLOADER_BACKDOOR_DISABLE 0xEFFFFFFF #define SYS_CTRL_EMUOVR 0x400D20B4 #define SYS_CTRL_I_MAP 0x400D2098 //***************************************************************************** // // Check if compiler is IAR // //***************************************************************************** #if !(defined(__IAR_SYSTEMS_ICC__)) #error "startup_iar.c: Unsupported compiler!" #endif //***************************************************************************** // // Macro for hardware access, both direct and via the bit-band region. // //***************************************************************************** #ifndef HWREG #define HWREG(x) \ (*((volatile uint32_t *)(x))) #endif //***************************************************************************** // // IAR: Enable the IAR extensions for this source file. // //***************************************************************************** #pragma language=extended //***************************************************************************** // // IAR: The entry point for the application startup code. // //***************************************************************************** extern void __iar_program_start(void); //***************************************************************************** // // IAR: Get stack start (highest address) symbol from linker file. // //***************************************************************************** extern const void* STACK_TOP; // It is required to place something in the CSTACK segment to get the stack // check feature in IAR to work as expected __root static void* dummy_stack @ ".stack"; //***************************************************************************** // // Forward declaration of the default fault handlers. // //***************************************************************************** static void ResetISR(void); static void NmiISR(void); //static void FaultISR(void); void HardFault_Handler(void); //static void PendSV_Handler(void); void PendSV_Handler(void); // Handlers that can potentially be registered directly by application extern void PendSV_Handler(void); extern void SysTickIntHandler(void); extern void GPIOAIntHandler(void); extern void GPIOBIntHandler(void); extern void GPIOCIntHandler(void); extern void GPIODIntHandler(void); extern void UART0IntHandler(void); extern void UART1IntHandler(void); extern void SSI0IntHandler(void); extern void SSI1IntHandler(void); extern void I2CIntHandler(void); extern void ADCIntHandler(void); extern void WatchdogIntHandler(void); extern void Timer0AIntHandler(void); extern void Timer0BIntHandler(void); extern void Timer1AIntHandler(void); extern void Timer1BIntHandler(void); extern void Timer2AIntHandler(void); extern void Timer2BIntHandler(void); extern void Timer3AIntHandler(void); extern void Timer3BIntHandler(void); extern void CompIntHandler(void); extern void RFCoreTxIntHandler(void); extern void RFCoreErrIntHandler(void); extern void IcePickIntHandler(void); extern void FlashIntHandler(void); extern void AESIntHandler(void); extern void PKAIntHandler(void); extern void SleepModeIntHandler(void); extern void MacTimerIntHandler(void); extern void USBIntHandler(void); extern void uDMAIntHandler(void); extern void uDMAErrIntHandler(void); // Default interrupt handlers, these can be overwritten if defined elsewhere #pragma weak PendSVHandler = PendSV_Handler #pragma weak SysTickIntHandler = PendSV_Handler #pragma weak GPIOAIntHandler = PendSV_Handler #pragma weak GPIOBIntHandler = PendSV_Handler #pragma weak GPIOCIntHandler = PendSV_Handler #pragma weak GPIODIntHandler = PendSV_Handler #pragma weak UART0IntHandler = PendSV_Handler #pragma weak UART1IntHandler = PendSV_Handler #pragma weak SSI0IntHandler = PendSV_Handler #pragma weak SSI1IntHandler = PendSV_Handler #pragma weak I2CIntHandler = PendSV_Handler #pragma weak ADCIntHandler = PendSV_Handler #pragma weak WatchdogIntHandler = PendSV_Handler #pragma weak Timer0AIntHandler = PendSV_Handler #pragma weak Timer0BIntHandler = PendSV_Handler #pragma weak Timer1AIntHandler = PendSV_Handler #pragma weak Timer1BIntHandler = PendSV_Handler #pragma weak Timer2AIntHandler = PendSV_Handler #pragma weak Timer2BIntHandler = PendSV_Handler #pragma weak Timer3AIntHandler = PendSV_Handler #pragma weak Timer3BIntHandler = PendSV_Handler #pragma weak CompIntHandler = PendSV_Handler #pragma weak RFCoreTxIntHandler = PendSV_Handler #pragma weak RFCoreErrIntHandler = PendSV_Handler #pragma weak IcePickIntHandler = PendSV_Handler #pragma weak FlashIntHandler = PendSV_Handler #pragma weak AESIntHandler = PendSV_Handler #pragma weak PKAIntHandler = PendSV_Handler #pragma weak SleepModeIntHandler = PendSV_Handler #pragma weak MacTimerIntHandler = PendSV_Handler #pragma weak USBIntHandler = PendSV_Handler #pragma weak uDMAIntHandler = PendSV_Handler #pragma weak uDMAErrIntHandler = PendSV_Handler //***************************************************************************** // // Customer Configuration Area in Lock Page // Holds Image Vector table address (bytes 2013 - 2015) and // Image Valid bytes (bytes 2008 -2011) // //***************************************************************************** typedef struct { uint32_t ui32BootldrCfg; uint32_t ui32ImageValid; uint32_t ui32ImageVectorAddr; } lockPageCCA_t; __root const lockPageCCA_t __cca @ ".flashcca" = { BOOTLOADER_BACKDOOR_DISABLE, // Bootloader backdoor disabled 0, // Image valid bytes FLASH_START_ADDR // Vector table located at flash start address }; //***************************************************************************** // // The vector table. Note that the proper constructs must be placed on this to // ensure that it ends up at physical address 0x200000 (start of the flash). // //***************************************************************************** __root void (* const __vector_table[])(void) @ ".intvec" = { (void (*)(void))&STACK_TOP, // 0 The initial stack pointer ResetISR, // 1 The reset handler NmiISR, // The NMI handler //FaultISR, // The hard fault handler HardFault_Handler, PendSV_Handler, // 4 The MPU fault handler PendSV_Handler, // 5 The bus fault handler PendSV_Handler, // 6 The usage fault handler 0, // 7 Reserved 0, // 8 Reserved 0, // 9 Reserved 0, // 10 Reserved PendSV_Handler, // 11 SVCall handler PendSV_Handler, // 12 Debug monitor handler 0, // 13 Reserved PendSV_Handler, // 14 The PendSV handler SysTickIntHandler, // 15 The SysTick handler GPIOAIntHandler, // 16 GPIO Port A GPIOBIntHandler, // 17 GPIO Port B GPIOCIntHandler, // 18 GPIO Port C GPIODIntHandler, // 19 GPIO Port D 0, // 20 none UART0IntHandler, // 21 UART0 Rx and Tx UART1IntHandler, // 22 UART1 Rx and Tx SSI0IntHandler, // 23 SSI0 Rx and Tx I2CIntHandler, // 24 I2C Master and Slave 0, // 25 Reserved 0, // 26 Reserved 0, // 27 Reserved 0, // 28 Reserved 0, // 29 Reserved ADCIntHandler, // 30 ADC Sequence 0 0, // 31 Reserved 0, // 32 Reserved 0, // 33 Reserved WatchdogIntHandler, // 34 Watchdog timer, timer 0 Timer0AIntHandler, // 35 Timer 0 subtimer A Timer0BIntHandler, // 36 Timer 0 subtimer B Timer1AIntHandler, // 37 Timer 1 subtimer A Timer1BIntHandler, // 38 Timer 1 subtimer B Timer2AIntHandler, // 39 Timer 2 subtimer A Timer2BIntHandler, // 40 Timer 2 subtimer B CompIntHandler, // 41 Analog Comparator 0 RFCoreTxIntHandler, // 42 RFCore Rx/Tx RFCoreErrIntHandler, // 43 RFCore Error IcePickIntHandler, // 44 IcePick FlashIntHandler, // 45 FLASH Control AESIntHandler, // 46 AES PKAIntHandler, // 47 PKA SleepModeIntHandler, // 48 Sleep Timer MacTimerIntHandler, // 49 MacTimer SSI1IntHandler, // 50 SSI1 Rx and Tx Timer3AIntHandler, // 51 Timer 3 subtimer A Timer3BIntHandler, // 52 Timer 3 subtimer B 0, // 53 Reserved 0, // 54 Reserved 0, // 55 Reserved 0, // 56 Reserved 0, // 57 Reserved 0, // 58 Reserved 0, // 59 Reserved USBIntHandler, // 60 USB 2538 0, // 61 Reserved uDMAIntHandler, // 62 uDMA uDMAErrIntHandler, // 63 uDMA Error #ifndef CC2538_USE_ALTERNATE_INTERRUPT_MAP 0, // 64 64-155 are not in use 0, // 65 0, // 66 0, // 67 0, // 68 0, // 69 0, // 70 0, // 71 0, // 72 0, // 73 0, // 74 0, // 75 0, // 76 0, // 77 0, // 78 0, // 79 0, // 80 0, // 81 0, // 82 0, // 83 0, // 84 0, // 85 0, // 86 0, // 87 0, // 88 0, // 89 0, // 90 0, // 91 0, // 92 0, // 93 0, // 94 0, // 95 0, // 96 0, // 97 0, // 98 0, // 99 0, // 100 0, // 101 0, // 102 0, // 103 0, // 104 0, // 105 0, // 106 0, // 107 0, // 108 0, // 109 0, // 110 0, // 111 0, // 112 0, // 113 0, // 114 0, // 115 0, // 116 0, // 117 0, // 118 0, // 119 0, // 120 0, // 121 0, // 122 0, // 123 0, // 124 0, // 125 0, // 126 0, // 127 0, // 128 0, // 129 0, // 130 0, // 131 0, // 132 0, // 133 0, // 134 0, // 135 0, // 136 0, // 137 0, // 138 0, // 139 0, // 140 0, // 141 0, // 142 0, // 143 0, // 144 0, // 145 0, // 146 0, // 147 0, // 148 0, // 149 0, // 150 0, // 151 0, // 152 0, // 153 0, // 154 0, // 155 USBIntHandler, // 156 USB RFCoreTxIntHandler, // 157 RFCORE RX/TX RFCoreErrIntHandler, // 158 RFCORE Error AESIntHandler, // 159 AES PKAIntHandler, // 160 PKA SleepModeIntHandler, // 161 SMTimer MacTimerIntHandler, // 162 MACTimer #endif }; //***************************************************************************** // // This is the code that gets called when the processor is reset. // //***************************************************************************** static void ResetISR(void) { #ifdef DEBUG // // Workaround for System Reset debug issue // uint32_t ui32Timeout = 2000000; volatile uint32_t* pui32StopAtResetIsr = (uint32_t*)0x20003000; while((*pui32StopAtResetIsr == 0xA5F01248) && (ui32Timeout--)); #endif #ifdef CC2538_USE_ALTERNATE_INTERRUPT_MAP // // Enable alternate interrupt mapping // HWREG(SYS_CTRL_I_MAP) |= 1; #endif // // Jump to IAR initialization routine // __iar_program_start(); //rtthread_startup(); } //***************************************************************************** // // This is the code that gets called when the processor receives a NMI. This // simply enters an infinite loop, preserving the system state for examination // by a debugger. // //***************************************************************************** static void NmiISR(void) { // // Enter an infinite loop. // while(1) { } } //***************************************************************************** // // This is the code that gets called when the processor receives a fault // interrupt. This simply enters an infinite loop, preserving the system state // for examination by a debugger. // //***************************************************************************** //static void //FaultISR(void) //{ // // // // Enter an infinite loop. // // // // while(1) // // { // // } //} //***************************************************************************** // // This is the code that gets called when the processor receives an unexpected // interrupt. This simply enters an infinite loop, preserving the system state // for examination by a debugger. // //***************************************************************************** static void PendSV_Handler(void) { // // Enter an infinite loop. // //while(1) //{ //} } ```
李肯陪你玩赚嵌入式
2021-09-11
学习了。
864
sunlichao
23
STM32 407 串口接收数据 系统卡死
RTT nrf24l01 设备驱动程序
stm32f10x串口只能发送数据,无法接收
rt-thread线程调度异常在stm32f103芯片上
RTT是否支持STM32F429
rt-thread在stm32f411下的移植问题
