SFUD,QSPI,MT25QL101g. 能探测到,读写没内容,各位大神帮忙看下.
发布于 2020-05-25 11:31:20 浏览:1317
[D/drv.qspi] qspi init success! [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud.c:862) The flash device manufacturer ID is 0x20, memory type ID is 0xBA, capacity ID is 0x21. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:132) Check SFDP header is OK. The reversion is V1.6, NPN is 1. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:175) Check JEDEC basic flash parameter header is OK. The table id is 0, reversion is V1.6, length is 16, parameter table pointer is 0x000030. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:203) JEDEC basic flash parameter table info: [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:204) MSB-LSB 3 2 1 0 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0001] 0xFF 0xFB 0x20 0xE5 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0002] 0x3F 0xFF 0xFF 0xFF [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0003] 0x6B 0x27 0xEB 0x29 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0004] 0xBB 0x27 0x3B 0x27 [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0005] 0xFF 0xFF 0xFF 0xFF [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0006] 0xBB 0x27 0xFF 0xFF [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0007] 0xEB 0x29 0xFF 0xFF [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0008] 0xD8 0x10 0x20 0x0C [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:207) [0009] 0x00 0x00 0x52 0x0F [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:215) 4 KB Erase is supported throughout the device. Command is 0x 20. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:234) Write granularity is 64 bytes or larger. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:245) Target flash status register is non-volatile. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:276) 3- or 4-Byte addressing. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:305) Capacity is 134217728 Bytes. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:312) Flash device supports 4KB block erase. Command is 0x20. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:312) Flash device supports 64KB block erase. Command is 0xD8. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud_sfdp.c:312) Flash device supports 32KB block erase. Command is 0x52. [SFUD] Find a Micron flash chip. Size is 134217728 bytes. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud.c:840) Flash device reset success. [SFUD] (../rt-thread/components/drivers/spi/sfud/src/sfud.c:941) Enter 4-Byte addressing mode success. [SFUD] M25QL1GB flash device is initialize success. [D/drv.qspi] qspi init success! [SFUD] Probe SPI flash M25QL1GB by SPI device qspi10 success. 1 - Use SFUD API sfud device name: M25QL1GB, sector_count: 32768, bytes_per_sector: 4096, block_size: 4096. msh />sfud api write data to m25q(address:0x2000) success. sfud api read data from m25q(address:0x2000) is: ------------------------------------------------------------------------------------------------------------ #define SFUD_FLASH_CHIP_TABLE \ { {"M25QL1GB", SFUD_MF_ID_MICRON, 0x20, 0x21, 128L*1024L*1024L,SFUD_WM_PAGE_256B, 4096, 0x21}, } --------------------------------------------------------------------------------------------------------- #include "drv_qspi.h" #include
#define QSPI_BUD_NAME "qspi1" #define QSPI_DEVICE_NAME "qspi10" #define M25Q_FLASH_NAME "M25QL1GB" #define QSPI_CS_PIN GET_PIN(B, 11) #define LED0_PIN GET_PIN(B, 4) #define LED1_PIN GET_PIN(B, 5) rt_uint8_t wData[4096] = {"1234567."}; rt_uint8_t rData[4096] = {"7654321."}; int rt_hw_spi_flash_init(void) { if(stm32_qspi_bus_attach_device(QSPI_BUD_NAME, QSPI_DEVICE_NAME, (rt_uint32_t)QSPI_CS_PIN, 1, RT_NULL, RT_NULL) != RT_EOK) return -RT_ERROR; #ifdef RT_USING_SFUD if(rt_sfud_flash_probe(M25Q_FLASH_NAME, QSPI_DEVICE_NAME) == RT_NULL) return -RT_ERROR; #endif return RT_EOK; } void sfud_w25q_sample(void) { rt_spi_flash_device_t flash_dev; sfud_flash_t sfud_dev; struct rt_device_blk_geometry geometry; // 1- use sfud api rt_kprintf("
1 - Use SFUD API
"); sfud_dev = rt_sfud_flash_find_by_dev_name(M25Q_FLASH_NAME); if(sfud_dev == RT_NULL){ rt_kprintf("sfud can't find %s device.
", M25Q_FLASH_NAME); }else{ rt_kprintf("sfud device name: %s, sector_count: %d, bytes_per_sector: %d, block_size: %d.
", sfud_dev->name, sfud_dev->chip.capacity / sfud_dev->chip.erase_gran, sfud_dev->chip.erase_gran, sfud_dev->chip.erase_gran); if(sfud_erase_write(sfud_dev, 0x002000, sizeof(wData), wData) == SFUD_SUCCESS) rt_kprintf("sfud api write data to m25q(address:0x2000) success.
"); if(sfud_read(sfud_dev, 0x002000, sizeof(rData), rData) == SFUD_SUCCESS) rt_kprintf("sfud api read data from m25q(address:0x2000) is:%s
", rData); } // 2- use rt_device api rt_kprintf("
2 - Use rt_device API
"); flash_dev = (rt_spi_flash_device_t)rt_device_find(M25Q_FLASH_NAME); if(flash_dev == RT_NULL){ rt_kprintf("rt_device api can't find %s device.
", M25Q_FLASH_NAME); }else{ rt_device_open(&flash_dev->flash_device, RT_DEVICE_OFLAG_OPEN); if(rt_device_control(&flash_dev->flash_device, RT_DEVICE_CTRL_BLK_GETGEOME, &geometry) == RT_EOK) rt_kprintf("qspi flash device name: %s, sector_count: %d, bytes_per_sector: %d, block_size: %d.
", flash_dev->flash_device.parent.name, geometry.sector_count, geometry.bytes_per_sector, geometry.block_size); if(rt_device_write(&flash_dev->flash_device, 0x03, wData, 1) > 0) rt_kprintf("rt_device api write data to m25q(address:0x3000) success.
"); if(rt_device_read(&flash_dev->flash_device, 0x03, rData, 1) > 0) rt_kprintf("rt_device api read data from m25q(address:0x3000) is:%s
", rData); rt_device_close(&flash_dev->flash_device); } } int main(void) { int count = 1; /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); rt_pin_mode(LED1_PIN, PIN_MODE_OUTPUT); rt_hw_spi_flash_init(); sfud_w25q_sample(); while (count++) { /* set LED0 pin level to high or low */ rt_pin_write(LED0_PIN, count % 2); //rt_kprintf("Hello RT-Thread!"); rt_thread_mdelay(1000); } return RT_EOK; } void HAL_QSPI_MspInit(QSPI_HandleTypeDef* qspiHandle) { //rt_kprintf("rt_device HAL_QSPI_MspInit
"); GPIO_InitTypeDef GPIO_InitStruct = {0}; if(qspiHandle->Instance==QUADSPI) { /* USER CODE BEGIN QUADSPI_MspInit 0 */ /* USER CODE END QUADSPI_MspInit 0 */ /* QUADSPI clock enable */ __HAL_RCC_QSPI_CLK_ENABLE(); __HAL_RCC_GPIOA_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); /**QUADSPI GPIO Configuration PA6 ------> QUADSPI_BK1_IO3 PA7 ------> QUADSPI_BK1_IO2 PB0 ------> QUADSPI_BK1_IO1 PB1 ------> QUADSPI_BK1_IO0 PB10 ------> QUADSPI_CLK PB11 ------> QUADSPI_NCS */ GPIO_InitStruct.Pin = GPIO_PIN_6|GPIO_PIN_7; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF10_QUADSPI; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); GPIO_InitStruct.Pin = GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_10|GPIO_PIN_11; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF10_QUADSPI; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); /* USER CODE BEGIN QUADSPI_MspInit 1 */ /* USER CODE END QUADSPI_MspInit 1 */ } } #if 1 void HAL_QSPI_MspDeInit(QSPI_HandleTypeDef* qspiHandle) { if(qspiHandle->Instance==QUADSPI) { /* USER CODE BEGIN QUADSPI_MspDeInit 0 */ /* USER CODE END QUADSPI_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_QSPI_CLK_DISABLE(); /**QUADSPI GPIO Configuration PA6 ------> QUADSPI_BK1_IO3 PA7 ------> QUADSPI_BK1_IO2 PB0 ------> QUADSPI_BK1_IO1 PB1 ------> QUADSPI_BK1_IO0 PB10 ------> QUADSPI_CLK PB11 ------> QUADSPI_NCS */ HAL_GPIO_DeInit(GPIOA, GPIO_PIN_6|GPIO_PIN_7); HAL_GPIO_DeInit(GPIOB, GPIO_PIN_0|GPIO_PIN_1|GPIO_PIN_10|GPIO_PIN_11); /* USER CODE BEGIN QUADSPI_MspDeInit 1 */ /* USER CODE END QUADSPI_MspDeInit 1 */ } }
james_s
2021-04-13
看起来没啥错误, 换个flash试试确认硬件没问题
1.3k
Qzeng
