基于潘多拉开发使用rt-thread studio 开发使用软件包AHT10遇到....
发布于 2020-05-26 18:00:10 浏览:2276
基于潘多拉开发板使用的问题: 配置了I2c总线和软件包,初始化也成功了,但是无法读取数据时怎么回事?有哪位大神帮忙看看? ```c #include
/* PLEASE DEFINE the LED0 pin for your board, such as: PA5 */ #define LED0_PIN GET_PIN(E, 7) #include "aht10.h" #include "sensor_asair_aht10.h" #define AHT10_I2C_BUS "i2c1" int rt_hw_aht10_port(void) { struct rt_sensor_config cfg; cfg.intf.dev_name = AHT10_I2C_BUS; cfg.intf.user_data = (void *)AHT10_I2C_ADDR; rt_hw_aht10_init("aht10", &cfg); LOG_D("aht10 is OK!"); return RT_EOK; } int main(void) { rt_err_t res; float humidity, temperature; int count = 1; aht10_device_t dev; rt_hw_aht10_port(); dev = aht10_init(AHT10_I2C_BUS); if (dev == RT_NULL) { LOG_E(" The sensor initializes failure"); return 0; } else { LOG_D(" The sensor initializes ok!"); } /* set LED0 pin mode to output */ rt_pin_mode(LED0_PIN, PIN_MODE_OUTPUT); while (count++) { humidity = aht10_read_humidity(dev); rt_kprintf("humidity : %d.%d %%
", (int)humidity, (int)(humidity * 10) % 10); /* former is integer and behind is decimal */ /* read temperature */ temperature = aht10_read_temperature(dev); rt_kprintf("temperature: %d.%d
", (int)temperature, (int)(temperature * 10) % 10); /* former is integer and behind is decimal */ rt_thread_mdelay(1000); /* set LED0 pin level to high or low */ rt_pin_write(LED0_PIN, count % 2); // LOG_D("Hello RT-Thread!"); rt_thread_mdelay(1000); } return RT_EOK; } ```
cgh198510
2020-05-26
[E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is under an abnormal status. Please try again [E/AHT10] The aht10 is under an abnormal status. Please try again humidity : 0.0 % temperature: -50.0 [E/AHT10] The aht10 is
cgh198510
2020-06-08
>看下用这个例子能读取数据吗https://www.rt-thread.org/document/site/programming-manual/device/i2c/i2c/ ... --- 感谢恢复,是管脚接错了。
姜还是我辣
2020-06-10
楼主你好,我也遇到了相同的问题,同样的报错,请问你是怎么解决的?
姜还是我辣
2020-06-10
软件包中的内容: 注意事项 测试中发现传感器 aht10 为不标准 I2C 设备,总线上出现数据与该器件地址相同,即使没有开始信号,也会响应,导 SDA 死锁。所以,建议用户给 AHT10 独立一个 I2C 总线。 我在想是不是与这个有关系,,
2.3k
cgh198510
潘多拉开发板AP6181 外设支持报错
潘多拉wifi管理例程中ap模式未启动
潘多拉开发板上I2C设备驱动开发
潘多拉开发板 综合例程 调试报错
潘多拉开发板在VSCODE无法执行micropython
潘多拉添加freemodbus例子出现错误
潘多拉开发板OV2640拍摄JPEG格式的照片
SFUD 提示闪存超过32g
有谁用潘多拉开发过OV2640吗
请问潘多拉开发板怎么烧录micropython固件
NXP MCXN947测评之 adc
