Network
STM32H743 网口调试
发布于 2020-05-29 15:39:41 浏览:1729
参照网上帖子移植LWIP,网口还是没有调通,网上来求助,下边代码里__attribute__((section(".RxDecripSection")))),**这个section需要在链接脚本里定义吗?该怎么写呢?**我对链接脚本不了解,用的是rtthread-stdio编译。 #elif defined ( __GNUC__ ) /* GNU Compiler */ #elif defined ( __GNUC__ ) /* GNU Compiler */ ETH_DMADescTypeDef DMARxDscrTab[ETH_RX_DESC_CNT] __attribute__((section(".RxDecripSection"))); /* Ethernet Rx DMA Descriptors */ ETH_DMADescTypeDef DMATxDscrTab[ETH_TX_DESC_CNT] __attribute__((section(".TxDecripSection"))); /* Ethernet Tx DMA Descriptors */ uint8_t Rx_Buff[ETH_RX_DESC_CNT][ETH_RX_BUFFER_SIZE] __attribute__((section(".RxArraySection"))); /* Ethernet Receive Buffers */ #endif --------------------------------------------------------------------- /* * linker script for STM32H743II with GNU ld */ /* Program Entry, set to mark it as "used" and avoid gc */ MEMORY { ROM (rx) : ORIGIN =0x8000000,LENGTH =2048k RAM (rw) : ORIGIN =0x24000000,LENGTH =512k } ENTRY(Reset_Handler) _system_stack_size = 0x200; SECTIONS { .text : { . = ALIGN(4); _stext = .; KEEP(*(.isr_vector)) /* Startup code */ . = ALIGN(4); *(.text) /* remaining code */ *(.text.*) /* remaining code */ *(.rodata) /* read-only data (constants) */ *(.rodata*) *(.glue_7) *(.glue_7t) *(.gnu.linkonce.t*) /* section information for finsh shell */ . = ALIGN(4); __fsymtab_start = .; KEEP(*(FSymTab)) __fsymtab_end = .; . = ALIGN(4); __vsymtab_start = .; KEEP(*(VSymTab)) __vsymtab_end = .; /* section information for utest */ . = ALIGN(4); __rt_utest_tc_tab_start = .; KEEP(*(UtestTcTab)) __rt_utest_tc_tab_end = .; /* section information for at server */ . = ALIGN(4); __rtatcmdtab_start = .; KEEP(*(RtAtCmdTab)) __rtatcmdtab_end = .; . = ALIGN(4); /* section information for initial. */ . = ALIGN(4); __rt_init_start = .; KEEP(*(SORT(.rti_fn*))) __rt_init_end = .; . = ALIGN(4); PROVIDE(__ctors_start__ = .); KEEP (*(SORT(.init_array.*))) KEEP (*(.init_array)) PROVIDE(__ctors_end__ = .); . = ALIGN(4); _etext = .; } > ROM = 0 /* .ARM.exidx is sorted, so has to go in its own output section. */ __exidx_start = .; .ARM.exidx : { *(.ARM.exidx* .gnu.linkonce.armexidx.*) /* This is used by the startup in order to initialize the .data secion */ _sidata = .; } > ROM __exidx_end = .; /* .data section which is used for initialized data */ .data : AT (_sidata) { . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _sdata = . ; *(.data) *(.data.*) *(.gnu.linkonce.d*) PROVIDE(__dtors_start__ = .); KEEP(*(SORT(.dtors.*))) KEEP(*(.dtors)) PROVIDE(__dtors_end__ = .); . = ALIGN(4); /* This is used by the startup in order to initialize the .data secion */ _edata = . ; } >RAM .stack : { . = ALIGN(4); _sstack = .; . = . + _system_stack_size; . = ALIGN(4); _estack = .; } >RAM __bss_start = .; .bss : { . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _sbss = .; *(.bss) *(.bss.*) *(COMMON) . = ALIGN(4); /* This is used by the startup in order to initialize the .bss secion */ _ebss = . ; *(.bss.init) } > RAM __bss_end = .; _end = .; /* Stabs debugging sections. */ .stab 0 : { *(.stab) } .stabstr 0 : { *(.stabstr) } .stab.excl 0 : { *(.stab.excl) } .stab.exclstr 0 : { *(.stab.exclstr) } .stab.index 0 : { *(.stab.index) } .stab.indexstr 0 : { *(.stab.indexstr) } .comment 0 : { *(.comment) } /* DWARF debug sections. * Symbols in the DWARF debugging sections are relative to the beginning * of the section so we begin them at 0. */ /* DWARF 1 */ .debug 0 : { *(.debug) } .line 0 : { *(.line) } /* GNU DWARF 1 extensions */ .debug_srcinfo 0 : { *(.debug_srcinfo) } .debug_sfnames 0 : { *(.debug_sfnames) } /* DWARF 1.1 and DWARF 2 */ .debug_aranges 0 : { *(.debug_aranges) } .debug_pubnames 0 : { *(.debug_pubnames) } /* DWARF 2 */ .debug_info 0 : { *(.debug_info .gnu.linkonce.wi.*) } .debug_abbrev 0 : { *(.debug_abbrev) } .debug_line 0 : { *(.debug_line) } .debug_frame 0 : { *(.debug_frame) } .debug_str 0 : { *(.debug_str) } .debug_loc 0 : { *(.debug_loc) } .debug_macinfo 0 : { *(.debug_macinfo) } /* SGI/MIPS DWARF 2 extensions */ .debug_weaknames 0 : { *(.debug_weaknames) } .debug_funcnames 0 : { *(.debug_funcnames) } .debug_typenames 0 : { *(.debug_typenames) } .debug_varnames 0 : { *(.debug_varnames) } }
nongxiaoming
2020-06-01
rt-thread大师兄
要指定.RxDecripSection放在那个内存区域内而且要确保这个内存块以太网控制器是能访问到的。
1.7k
weideke@qq.com
lwip1.4.1连接经常会断开无法连接上,可以ping通
求一些LWIP开发的经验,目前ping一直不稳定。
stm32f207+dp83848无法ping通
RTT下的LWIP传递机制
rtt内lwip的socket是否是线程安全?
Lwip+enc28j60无法ping通
坑爹的rtconfig.h lwip关掉了checksum
NXP MCXN947测评之 adc
