网络学习营
libcurl2rtt包使用DNS问题
发布于 2020-06-18 09:15:44 浏览:1458
Hello 各位RTT的大神指教一下: 1.移植的libcurl2rtt包,dns服务总是过不了,直接`ping www.rt-thread.com`都能通. ``` msh />curl --verbose -k --capath ./ [https://www.rt-thread.com/service/rt-thread.txt](https://www.rt-thread.com/service/rt-thread.txt) * timeout on name lookup is not supported * Curl_ipv4_resolve_r failed for [www.rt-thread.com](www.rt-thread.com) * Couldn't resolve host 'www.rt-thread.com' * Closing connection 0 curl: (6) Couldn't resolve host 'www.rt-thread.com' msh />ping [www.rt-thread.com](www.rt-thread.com) 60 bytes from 118.31.15.152 icmp_seq=0 ttl=49 time=60 ms 60 bytes from 118.31.15.152 icmp_seq=1 ttl=49 time=30 ms 60 bytes from 118.31.15.152 icmp_seq=2 ttl=49 time=30 ms 60 bytes from 118.31.15.152 icmp_seq=3 ttl=49 time=30 ms ```
liu2guang
2020-06-18
在qemu中测试,证书DIGICERT_ROOT_CA.cer放到 ./ 目录下调用 curl --verbose -k --capath ./ [https://www.rt-thread.com/service/rt-thread.txt](https://www.rt-thread.com/service/rt-thread.txt) 是没有问题的。你试试qemu跑把 [attach]15803[/attach]
2020-06-18
楼主这里好像是dns解析不出来,还没到证书那阶段。
芋圆源钰
2020-06-19
>在qemu中测试,证书DIGICERT_ROOT_CA.cer放到 ./ 目录下调用 curl --verbose -k --capath ./ https://www.r ... 谢谢你的回复, 1.我这里是DNS解析不了. 2.你图里面执行时加了-k参数是跳过证书了额.
芋圆源钰
2020-06-19
>楼主这里好像是dns解析不出来,还没到证书那阶段。 --- 是的呢,直接ping [www.rt-thread.com](www.rt-thread.com)都能正常解析. 不清楚是否这个包的那个配置有问题.还请指教.
芋圆源钰
2020-07-01
查了一周,还是老老实实跟代码发先就是一个宏的问题. ```patch +++ b/source/ekernel/subsys/net/rt-thread/net_tools/netutils-master/libcurl2rtt-latest/curl/curl_config.h @@ -30,7 +30,7 @@ #define HAVE_FCNTL_O_NONBLOCK 1 /* Define to 1 if you have the gethostbyname_r function. */ -#define HAVE_GETHOSTBYNAME_R 1 +//#define HAVE_GETHOSTBYNAME_R 1 ``` 注释后测试已正常: ``` msh />curl --verbose -k --capath ./ [https://www.rt-thread.com/service/rt-thread.txt](https://www.rt-thread.com/service/rt-thread.txt) * timeout on name lookup is not supported * Trying 118.31.15.152:443... * TCP_NODELAY set * Connected to [http://www.rt-thread.com](www.rt-thread.com) () port 443 (#0) * mbedTLS: Connecting to [http://www.rt-thread.com:443](www.rt-thread.com:443) * mbedTLS: Set min SSL version to TLS 1.0 * mbedTLS: Handshake complete, cipher is TLS-ECDHE-RSA-WITH-AES-128-GCM-SHA256 * Dumping cert info: * cert. version : 3 * serial number : 06:43:FD:59:D0:4D:C8:94:2F:54:BA:AF:82:55:72:0E * issuer name : C=US, O=DigiCert Inc, OU=www.digicert.com, CN=Encryption Everywhere DV TLS CA - G1 * subject name : CN=www.rt-thread.com * issued on : 2020-06-21 00:00:00 * expires on : 2021-06-22 12:00:00 * signed using : RSA with SHA-256 * RSA key size : 2048 bits * basic constraints : CA=false * subject alt name : [http://www.rt-thread.com](www.rt-thread.com), rt-thread.com * key usage : Digital Signature, Key Encipherment * ext key usage : TLS Web Server Authentication, TLS Web Client Authentication * SSL connected > GET /service/rt-thread.txt HTTP/1.1 > Host: [http://www.rt-thread.com](www.rt-thread.com) > User-Agent: curl/7.67.0-DEV > Accept: */* > * Mark bundle as not supporting multiuse < HTTP/1.1 200 OK < Server: nginx/1.10.3 (Ubuntu) < Date: Wed, 01 Jul 2020 07:50:41 GMT < Content-Type: text/plain < Content-Length: 267 < Connection: keep-alive < Last-Modified: Tue, 18 Sep 2018 03:55:48 GMT < ETag: "10b-5761d43d95900" < Accept-Ranges: bytes < Vary: Accept-Encoding < RT-Thread is an open source IoT operating system from China, which has strong scalability: from a tiny kernel running on a tiny core, for example ARM Cortex-M0, or Cortex-M3/4/7, to a rich feature system running on MIPS32, ARM Cortex-A8, ARM Cortex-A9 DualCore etc. ``` 发现一个新问题: 直接用ip地址代替rt-thread.com出现301返回码? ``` msh />curl --verbose -k --capath ./ [https://118.31.15.152/service/rt-thread.txt](https://118.31.15.152/service/rt-thread.txt) * timeout on name lookup is not supported * Trying 118.31.15.152:443... * TCP_NODELAY set * Connected to 118.31.15.152 () port 443 (#0) * mbedTLS: Connecting to 118.31.15.152:443 * mbedTLS: Set min SSL version to TLS 1.0 * mbedTLS: Handshake complete, cipher is TLS-ECDHE-RSA-WITH-AES-256-GCM-SHA384 * Dumping cert info: * cert. version : 3 * serial number : 09:2F:6D:AE:96:EC:D7:D0:24:55:D2:F5:64:20:50:23 * issuer name : C=US, O=DigiCert Inc, OU=www.digicert.com, CN=RapidSSL RSA CA 2018 * subject name : CN=*.rt-thread.org * issued on : 2020-06-05 00:00:00 * expires on : 2021-06-05 12:00:00 * signed using : RSA with SHA-256 * RSA key size : 2048 bits * basic constraints : CA=false * subject alt name : *.rt-thread.org, rt-thread.org * key usage : Digital Signature, Key Encipherment * ext key usage : TLS Web Server Authentication, TLS Web Client Authentication * SSL connected > GET /service/rt-thread.txt HTTP/1.1 > Host: 118.31.15.152 > User-Agent: curl/7.67.0-DEV > Accept: */* > * Mark bundle as not supporting multiuse < HTTP/1.1 301 Moved Permanently < Server: nginx/1.10.3 (Ubuntu) < Date: Wed, 01 Jul 2020 07:43:17 GMT < Content-Type: text/html < Content-Length: 194 < Connection: keep-alive < Location: [https://www.rt-thread.org/service/rt-thread.txt](https://www.rt-thread.org/service/rt-thread.txt) < Strict-Transport-Security: max-age=1800; includeSubdomains; preload <
* Connection #0 to host 118.31.15.152 left intact ```
2020-07-01
>发现一个新问题: >直接用ip地址代替rt-thread.com出现301返回码? --- 记得别的贴子和你说了,https的SNI问题
1.5k
芋圆源钰
【LWIP学习营】第一关开发环境搭建
LWIP学习营第一周入门移植问题汇总贴
【LWIP学习营】f407+lan8720A小结
【LwIP学习营】【第一周】仅零散记录,无主题
【LwIP学习营】【第一周】LWIP移植
【LwIP学习营】【第一周】开发板适配
【LwIP学习营】【第一周】环境搭建和配置验证
