编译动态模块错误: ld.exe: invalid maxium page size `0x4-shared'
发布于 2020-06-19 15:51:55 浏览:839
编译动态模块出现一个错误,如下: scons --app=hello scons: Reading SConscript files ... scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly File "C:\RT-ThreadStudio\workspace tthread-apps\tools\ua.py", line 193, in BuildApplication scons: done reading SConscript files. scons: Building targets ... CC hello\main.o LINK hello\hello.mo d:/code/env/tools/gnu_gcc/arm_gcc/mingw/bin/../lib/gcc/arm-none-eabi/5.4.1/../../../../arm-none-eabi/bin**/ld.exe: invalid maxium page size `0x4-shared'** collect2.exe: error: ld returned 1 exit status scons: *** [hello\hello.mo] Error 1 scons: building terminated because of errors. 请懂的帮忙看看。
2020-06-19
可以看看命令行参数,是不是弄错了
weideke@qq.com
2020-06-22
已解决,是rtconfig.py中错误 M_LFLAGS = DEVICE + CXXFLAGS + '-Wl,--gc-sections,-z,max-page-size=0x4' +\ ' -shared -fPIC -nostartfiles -nostdlib -static-libgcc' 在-shared前加一个空格解决。
weideke@qq.com
2020-06-22
现在是运行时错误,可能问题是什么? 模块代码: #include
int main(int argc, char *argv[]) { printf("this is hello test string\n"); return 0; } 编译: $ scons --app=hello scons: Reading SConscript files ... scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly File "C:\RT-ThreadStudio\workspace\rtthread-apps\tools\ua.py", line 193, in BuildApplication scons: done reading SConscript files. scons: Building targets ... CC hello\main.o LINK hello\hello.mo Copy("D:\TFTP_Server\clinet", "hello/hello.mo") scons: done building targets. 运行时错误如下: tftp: write request from 192.168.10.163 for 'hello.mo' mode 'octet' tftp: closing msh /troot> msh /troot> msh /troot>hello msh /troot>psr: 0x20000000 r00: 0x00000001 r01: 0x24008788 r02: 0x24008788 r03: 0x24007da8 r04: 0x24007f00 r05: 0xdeadbeef r06: 0xdeadbeef r07: 0x24008780 r08: 0xdeadbeef r09: 0xdeadbeef r10: 0xdeadbeef r11: 0xdeadbeef r12: 0x00000000 lr: 0x0800abfb pc: 0x24007da8 hard fault on thread: hello thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- hello 31 running 0x00000048 0x00000800 06% 0x0000000a 000 eth_link 20 suspend 0x00000120 0x00000400 28% 0x0000000a 000 eth_rx 2 suspend 0x000000a8 0x00000800 13% 0x00000004 000 tcpip_th 2 suspend 0x000000f0 0x00000800 59% 0x00000003 000 tshell 20 suspend 0x00000184 0x00001000 34% 0x00000001 000 sys_work 23 suspend 0x00000088 0x00000800 06% 0x0000000a 000 tidle0 31 ready 0x00000088 0x00000100 53% 0x00000020 000 timer 4 suspend 0x0000007c 0x00000200 24% 0x00000009 000 main 10 suspend 0x00000158 0x00000800 57% 0x0000000b 000 usage fault: SCB_CFSR_UFSR:0x02 INVSTATE
839
weideke@qq.com
用scons构建代码出现问题
求助用scons生成不了mdk工程
关于使用scons编译的问题
关于scons 编译CPP问题求教
scons编译出现警告信息
SCons生成MDK5工程出错
realtouch的scons问题
SCons的PreAction能用吗?
scons 编译时出错。
求教:关于scons构建rtt时的两个问题
