关于U8G2菜单历程按键问题
发布于 2020-06-22 16:55:14 浏览:3106
* 本帖最后由 Silly_roe_deer 于 2020-6-22 16:58 编辑 * 我尝试使用按键历程,修改为硬件SPI 方式驱动,屏幕正常显示,可是按键无响应,按键引脚已经自定义,请问可能是什么原因呢?我是用的是4.0.2完整版,ST的L496开发板 #include "menu.h" struct menu_entry_type { const uint8_t *font; uint16_t icon; const char *name; }; struct menu_state { int16_t menu_start; /* in pixel */ int16_t frame_position; /* in pixel */ uint8_t position; /* position, array index */ }; /* Icon configuration Width and height must match the icon font size GAP: Space between the icons BGAP: Gap between the display border and the cursor. */ #define ICON_WIDTH 32 #define ICON_HEIGHT 32 #define ICON_GAP 4 #define ICON_BGAP 16 #define ICON_Y 32+ICON_GAP static struct menu_entry_type menu_entry_list[] = { { u8g2_font_open_iconic_play_4x_t, 77, "音乐"}, { u8g2_font_open_iconic_mime_4x_t, 64, "收音机"}, { u8g2_font_open_iconic_embedded_4x_t, 70, "心率"}, { u8g2_font_open_iconic_embedded_4x_t, 74, "蓝牙"}, { u8g2_font_open_iconic_embedded_4x_t, 66, "设置"}, { NULL, 0, NULL } }; static void draw(struct menu_state *state) { int16_t x; uint8_t i; x = state->menu_start; i = 0; while( menu_entry_list*.icon > 0 ) { if ( x >= -ICON_WIDTH && x < u8g2.getDisplayWidth() ) { u8g2.setFont(menu_entry_list*.font); u8g2.drawGlyph(x, ICON_Y, menu_entry_list*.icon ); } i++; x += ICON_WIDTH + ICON_GAP; } u8g2.drawFrame(state->frame_position-1, ICON_Y-ICON_HEIGHT-1, ICON_WIDTH+2, ICON_WIDTH+2); u8g2.drawFrame(state->frame_position-2, ICON_Y-ICON_HEIGHT-2, ICON_WIDTH+4, ICON_WIDTH+4); u8g2.drawFrame(state->frame_position-3, ICON_Y-ICON_HEIGHT-3, ICON_WIDTH+6, ICON_WIDTH+6); } static void to_right(struct menu_state *state) { if ( menu_entry_list[state->position+1].font != NULL ) { if ( (int16_t)state->frame_position+ 2*(int16_t)ICON_WIDTH + (int16_t)ICON_BGAP < (int16_t)u8g2.getDisplayWidth() ) { state->position++; state->frame_position += ICON_WIDTH + (int16_t)ICON_GAP; } else { state->position++; state->frame_position = (int16_t)u8g2.getDisplayWidth() - (int16_t)ICON_WIDTH - (int16_t)ICON_BGAP; state->menu_start = state->frame_position - state->position*((int16_t)ICON_WIDTH + (int16_t)ICON_GAP); } } } static void to_left(struct menu_state *state) { if ( state->position > 0 ) { if ( (int16_t)state->frame_position >= (int16_t)ICON_BGAP+(int16_t)ICON_WIDTH+ (int16_t)ICON_GAP ) { state->position--; state->frame_position -= ICON_WIDTH + (int16_t)ICON_GAP; } else { state->position--; state->frame_position = ICON_BGAP; state->menu_start = state->frame_position - state->position*((int16_t)ICON_WIDTH + (int16_t)ICON_GAP); } } } static uint8_t towards_int16(int16_t *current, int16_t dest) { if ( *current < dest ) { (*current)++; return 1; } else if ( *current > dest ) { (*current)--; return 1; } return 0; } static uint8_t towards(struct menu_state *current, struct menu_state *destination) { uint8_t r = 0; r |= towards_int16( &(current->frame_position), destination->frame_position); r |= towards_int16( &(current->frame_position), destination->frame_position); r |= towards_int16( &(current->menu_start), destination->menu_start); r |= towards_int16( &(current->menu_start), destination->menu_start); return r; } static struct menu_state current_state = { ICON_BGAP, ICON_BGAP, 0 }; static struct menu_state destination_state = { ICON_BGAP, ICON_BGAP, 0 }; static void menu_entry(void *parameter) { u8g2.begin(/*Select=*/ U8G2_PIN_SELECT, /*Right/Next=*/ U8G2_PIN_RIGHT, /*Left/Prev=*/ U8G2_PIN_LEFT, /*Up=*/ U8G2_PIN_UP, /*Down=*/ U8G2_PIN_DOWN, /*Home/Cancel=*/ U8G2_PIN_HOME); u8g2.enableUTF8Print(); u8g2.setFont(u8g2_font_6x12_tr); u8g2.setContrast(128); while(1) { int8_t event; do { u8g2.clearBuffer(); draw(¤t_state); // u8g2.setFont(u8g2_font_helvB10_tr); u8g2.setFont(u8g2_font_wqy16_t_gb2312); u8g2.setCursor((u8g2.getDisplayWidth()-u8g2.getStrWidth(menu_entry_list[destination_state.position].name))/2,u8g2.getDisplayHeight()-5); // u8g2.setFont(u8g2_font_wqy16_t_gb2312); u8g2.print(menu_entry_list[destination_state.position].name); u8g2.sendBuffer(); rt_thread_mdelay(10); event = u8g2.getMenuEvent(); if ( event == U8X8_MSG_GPIO_MENU_NEXT ) to_right(&destination_state); if ( event == U8X8_MSG_GPIO_MENU_PREV ) to_left(&destination_state); if ( event == U8X8_MSG_GPIO_MENU_SELECT ) { u8g2.setFont(u8g2_font_wqy16_t_gb2312); // u8g2.setFont(u8g2_font_helvB10_tr); u8g2.userInterfaceMessage("Selection:", menu_entry_list[destination_state.position].name, "", " Ok "); } } while ( towards(¤t_state, &destination_state) ); rt_thread_mdelay(10); } } int rt_hw_menu_port(void) { menu = rt_thread_create("menu", menu_entry, RT_NULL, 2048, 2, 10); if (menu != RT_NULL) rt_thread_startup(menu); return 0; } INIT_APP_EXPORT(rt_hw_menu_port); #ifndef __MENU_H__ #define __MENU_H__ #include
//#define U8G2_PIN_UP 26 // PB10 //#define U8G2_PIN_DOWN 27 // PB11 //#define U8G2_PIN_LEFT 28 // PB12 //#define U8G2_PIN_RIGHT 29 // PB13 //#define U8G2_PIN_SELECT 30 // PB14 //#define U8G2_PIN_HOME 31 // PB15 #define U8G2_PIN_UP GET_PIN(B,12) #define U8G2_PIN_DOWN GET_PIN(B,13) #define U8G2_PIN_LEFT GET_PIN(B,10) #define U8G2_PIN_RIGHT GET_PIN(B,11) #define U8G2_PIN_SELECT GET_PIN(B,14) #define U8G2_PIN_HOME GET_PIN(B,15) #define OLED_SPI_PIN_RES 8 // PA8 #define OLED_SPI_PIN_DC 9 // PA9 #define OLED_SPI_PIN_CS 10 // PA10 #define THREAD_PRIORITY 4 #define THREAD_STACK_SIZE 512 #define THREAD_TIMESLICE 10 static rt_thread_t menu = RT_NULL; //static rt_thread_t collision_check = RT_NULL; static U8G2_SSD1306_128X64_NONAME_F_4W_HW_SPI u8g2(U8G2_R0, /* cs=*/ OLED_SPI_PIN_CS, /* dc=*/ OLED_SPI_PIN_DC, /* reset=*/ OLED_SPI_PIN_RES); #endif *** ![IMG_20200622_165311.jpg](https://oss-club.rt-thread.org/uploads/202006/22/165507iooujidepu9oem0z.jpg)
wuhanstudio
2020-06-22
上面代码定义了6个引脚,但是下面有很多按键是悬空的, 可以试试把悬空的脚上拉
打盹的消防车
2020-06-23
忙着打盹...
>上面代码定义了6个引脚,但是下面有很多按键是悬空的, >可以试试把悬空的脚上拉 ... --- 好的,谢谢,我试试
打盹的消防车
2020-06-23
忙着打盹...
>上面代码定义了6个引脚,但是下面有很多按键是悬空的, >可以试试把悬空的脚上拉 ... --- 您好,全部加了上拉电阻,还是没响应,不知道是不是我程序哪里出了问题,检查了好几遍,想不通:'(
打盹的消防车
2020-06-23
忙着打盹...
>上面代码定义了6个引脚,但是下面有很多按键是悬空的, >可以试试把悬空的脚上拉 ... --- 大佬,问题解决了,已经可以使用了,非常感谢帮助:lol
霍大侠是小学生
2023-09-21
遇到同样的问题,你们是怎么解决的呀,心态要炸了。
3.1k
打盹的消防车
忙着打盹...
30
【学习分享】初探RT-Thread系统调度
