玩iot camera笔记之3测试试用3路pwm
发布于 2016-09-19 16:44:00 浏览:2621
**在测试PWM的时候,发现只能启动PWM0,PWM1 PWM2 启动失败,求大神(已解决!根据网友提示并参考lua pwm库)** 代码放在 firmware-20160908applicationsmain.c 里面,添加对应所需的头文件 ```/* pwm init test * * * * */ #include
``` 在main函数后面添加代码并添加到main函数里面,以便启动完 /init.sh脚本后,启动我的测试pwm ``` int pwmSet() { rt_device_t pwm_dev; struct pwm_device pwm; int ret; pwm_dev = rt_device_find("pwm"); rt_kprintf("pwm_dev->device_id = %d " , pwm_dev->device_id); ret = rt_device_open(pwm_dev, RT_DEVICE_OFLAG_RDWR); rt_kprintf("rt_device_open end "); /* 打开设备时就使能了 ret = rt_device_control(pwm_dev, ENABLE_PWM, &pwm); rt_kprintf("ENABLE_PWM end "); */ //ret = rt_device_control(pwm_dev, GET_PWM_DUTY_CYCLE, &pwm); pwm.id=0;//pwm0 pwm.working= 1; //38kHz =26.3 pwm.counter_ns = 13000;//for duty pwm.period_ns = 26000; ret = rt_device_control(pwm_dev, SET_PWM_DUTY_CYCLE, &pwm); rt_kprintf("SET_PWM_DUTY_CYCLE end "); #if 1 ret = rt_device_control(pwm_dev, GET_PWM_DUTY_CYCLE, &pwm); rt_kprintf("GET_PWM_DUTY_CYCLE id= %d pwm.counter_ns = %d pwm.period_ns = %d " , pwm.id,pwm.counter_ns , pwm.period_ns); #endif #if 1 pwm.id=1;//pwm1 pwm.working= 1; //38kHz =26.3 pwm.counter_ns = 13000;//for duty pwm.period_ns = 26000; ret = rt_device_control(pwm_dev, SET_PWM_DUTY_CYCLE, &pwm); rt_kprintf("SET_PWM_DUTY_CYCLE pwm1 end "); #endif } MSH_CMD_EXPORT(pwmSet, pwmSet); ``` 然后让系统启动后自动启动pwm,在main函数的return 前面添加一行 ``` pwmSet(); return 0;``` 重新编译并启动,发现PWM0有输出38KHZ的方波,但是隔壁的PWM1 PWM2 都是低电平,没反应,难道芯片挂了? 求救啊
独行客
2016-09-19
已经解决 在初始化时添加端口复用,切到pwm端口 ``` fh_iomux_pin_switch(49, 1);//pwm1 fh_iomux_pin_switch(50, 1);//pwm2 fh_iomux_pin_switch(51, 1);//pwm0 ```
2.6k
独行客
[已解决]PWM输出异常分析
给RT-Thread添加PWM驱动框架
关于rt-thread-3.1.0 pwm
stm32f103ze 添加pwm 设备失败
定时器3通道2输出不了以20ms为周期的PWM波???
