DIY综合交流区
MP3播放异常 请求协助
发布于 2016-09-20 17:04:45 浏览:3561
板子是老板子 v2.0的,用的代码是google上的 名称:stm32radio_svn66_v4.7z 歌曲:随便网上下的6首mp3 128kbps速率 情况:只有一首可以播放,播放10s后死掉 其他5首一放就进入hard fault on thread: ply_bg board.h配置如下: ```/* board configuration */ //
SDCard Driver <1=>SDIO sdcard <0=>SPI MMC card //
Default: 1 #define STM32_USE_SDIO 0 /* whether use board external SRAM memory */ //
Use external SRAM memory on the board //
Enable External SRAM memory #define STM32_EXT_SRAM 1 //
Begin Address of External SRAM //
Default: 0x68000000 #define STM32_EXT_SRAM_BEGIN 0x68000000 /* the begining address of external SRAM */ //
End Address of External SRAM //
Default: 0x68080000 #define STM32_EXT_SRAM_END 0x68080000 /* the end address of external SRAM */ //
Internal SRAM memory size[Kbytes] <8-64> //
Default: 64 #define STM32_SRAM_SIZE 64 #define STM32_SRAM_END (0x20000000 + STM32_SRAM_SIZE * 1024) //
Console on USART: <0=> no console <1=>USART 1 <2=>USART 2 <3=> USART 3 //
Default: 1 #define STM32_CONSOLE_USART 1 //
LCD Module Version // <1=>Version 1: fmt0371 // <2=>Version 2: i8080/16bit ili9320/9325/9328 LG4531 ST7783 // <3=>Version 3: i8080/16bit SSD1289 //
Default: 1 #define LCD_VERSION 1 //
LCD backlight: // <0=>NO // <1=>PB9 TIM4_CH4 ( Version: V0.* V3.0 V3.1 ) // <2=>PB6 TIM4_CH1 ( Version: V4 ) //
Default: 1 #define LCD_USE_PWM 0 /* * IMPORTANT NOTICE: * CODEC_MASTER_MODE = 1 with CODEC_USE_SPI3 = 0 is unusable due to a hardware bug of STM32's SPI2. */ //
CODEC Mode // <0=>I2S Slave // <1=>I2S Master #define CODEC_MASTER_MODE 0 //
CODEC SPI Port // <0=>SPI2 // <1=>SPI3 #define CODEC_USE_SPI3 0 //
SPI FLASH TYPE // <1=>Version 1: AT45DB161D // <2=>Version 2: SST25VF016B //
Default: 2 #define SPI_FLASH_TYPE 1``` ================================================================== 开机后打印信息如下: ``` | / - RT - Thread Operating System / | 0.4.0 build Sep 20 2016 2006 - 2009 Copyright by rt-thread team found part[0], begin: 70144, size: 1.851GB SPI File System initialized! SD File System initialized! Unable to open GBK to Unicode look up table. Unable to open Unicode to GBK look up table. LCD GRAM test.... TEST PASS! rem_codes /resource/remote.txt open fail! fd:-1 The remote disbale. please run rem_study() rtc is not configured please configure with set_date and set_time Thu Jan 1 00:00:00 1970 dm9000 id: 0x90000a46 finsh>>could not establish link``` ============================================================ 发现在mp3.c 里面死掉的 修改了以下打印代码: ``` /* write to sound device */ outputSamps = decoder->frame_info.outputSamps; if (outputSamps > 0) { int ii; if (decoder->frame_info.nChans == 1) { int i; for (i = outputSamps - 1; i >= 0; i--) { buffer[i * 2] = buffer*; buffer[i * 2 + 1] = buffer*; } outputSamps *= 2; rt_kprintf("debug 4.5. "); } rt_kprintf("debug 5. "); ii=rt_device_write(decoder->snd_device, 0, buffer, outputSamps * sizeof(rt_uint16_t)); if(ii==0) rt_kprintf("debug 5.5. "); }``` ================================================================== 具体死掉的时候打印信息如下: ```debug 5. debug 5. debug 5. psr: 0x81000000 pc: 0x0801ae3a lr: 0x0801ae2d r12: 0x0000000a r03: 0x000cf72d r02: 0xfffea0fd r01: 0xfffcc24c r00: 0x000026ab hard fault on thread: ply_bg thread pri status sp stack size max used left tick error -------- ---- ------- ---------- ---------- ---------- ---------- --- tcpip 0x0a suspend 0x000000c8 0x00000400 0x000001c0 0x00000014 000 etx 0x0c suspend 0x00000088 0x00000200 0x00000088 0x00000010 000 erx 0x0c suspend 0x00000088 0x00000200 0x00000088 0x00000010 000 key 0x1e suspend 0x00000090 0x00000180 0x00000098 0x00000005 000 ply_ui 0x19 suspend 0x000000d0 0x00001000 0x00000570 0x00000001 000 ply_bg 0x0d ready 0x00000120 0x00000800 0x00000468 0x00000001 000 info 0x19 suspend 0x000000d0 0x00000800 0x00000490 0x00000004 000 rtgui 0x0f suspend 0x000000e0 0x00000400 0x000000e0 0x00000004 000 tidle 0x1f ready 0x00000040 0x00000100 0x00000050 0x00000013 000 tshell 0x14 suspend 0x00000088 0x00000800 0x00000088 0x0000000a 000 init 0x08 suspend 0x000000a0 0x00000800 0x00000438 0x00000006 000``` 怀疑是标红的代码处出问题?不确定 请求协助 最后的目标是想用这个板子播放flac wav 等无损 任重道远啊
2016-09-20
这个板子感觉够呛。 查问题的话,建议在 MP3Decode() 加个打印。 最好用仿真器单步调试。
littleworm
2016-09-20
其实板子性能很OK的 播放flac wav ape无损 显示什么的应该没问题的 wm9878貌似差一点 高编码的播放不了 都调整好了后 再换这个dac 应该来说就很完美了 丢下这么久 好难搞啊
2016-09-20
是的,这个过去太久时间了,很多都是以前的东西 楼主是在哪里,怎么想着玩这套东西
littleworm
2016-09-21
bernard 好 毕业后工作跟开发无关 丢下几年了 也好久没怎么上论坛了 这套板子是最早试验的一批 那时候还没毕业 安哥送我的 一直拿静电盒子套着 目前99新 嘿嘿 最近想听无损 看板子的处理能力还是足够的 就想重新利用起来 否则硬件更新太快 再放着就真的浪费了
sjj430
2019-11-23
>bernard 好 >毕业后工作跟开发无关 丢下几年了 也好久没怎么上论坛了 >这套板子是最早试验的一批 那时候 ... --- APE后来能播了吗,怎么做的
3.6k
littleworm
[项目]搞个开源的硬件项目
硬件计划贴,及时更新,欢迎提意见
MMS协议
定点的wma解压库-libwma
QQ群记录 [20090821]
STM32网络收音机PCB报名征集
第一版调试记录
第二版硬件讨论
