mo动态模块_Module
应用模块编译出问题
发布于 2017-05-22 10:19:44 浏览:2585
[tocm] 想在正点原子的阿波罗开发板上使用应用模块,参考最新的realboard板子, 模块程序目录D: t-thread_dev t-threadexamplesmoduleasicapp BSP目录下用scons --target=ua -s生成了rtua.py rtconfig.py 如下: ```import os cwd = os.path.split(os.path.realpath(__file__))[0] # RT-Thread root directory RTT_ROOT = 'D:/rt-thread_dev/rt-thread' BSP_ROOT = 'D:/rt-thread_dev/rt-thread/bsp/stm32f767-apollo' # toolchains EXEC_PATH = 'C:/Program Files (x86)/GNU Tools ARM Embedded/5.4 2016q3' if os.getenv('RTT_ROOT'): RTT_ROOT = os.getenv('RTT_ROOT') if os.getenv('BSP_ROOT'): BSP_ROOT = os.getenv('BSP_ROOT') if os.getenv('RTT_EXEC_PATH'): EXEC_PATH = os.getenv('RTT_EXEC_PATH') PLATFORM = 'gcc' PREFIX = 'arm-none-eabi-' CC = PREFIX + 'gcc' CXX = PREFIX + 'g++' AS = PREFIX + 'gcc' AR = PREFIX + 'ar' LINK = PREFIX + 'gcc' TARGET_EXT = 'mo' SIZE = PREFIX + 'size' OBJDUMP = PREFIX + 'objdump' OBJCPY = PREFIX + 'objcopy' DEVICE = ' -mcpu=cortex-m7' CFLAGS = DEVICE + ' -mthumb -mlong-calls -O0 -fPIC -fno-exceptions' AFLAGS = ' -c' + DEVICE + ' -x assembler-with-cpp' LFLAGS = DEVICE + ' -mthumb -Wl,-z,max-page-size=0x4 -shared -fPIC -e main -nostdlib' CPATH = '' LPATH = '' ``` SConstruct如下: ```import os import sys import rtconfig sconstruct = File('SConstruct') fn = sconstruct.rfile() name = fn.name building_dir = os.path.dirname(fn.abspath) program_dir = '../bin' from rtconfig import RTT_ROOT from rtconfig import BSP_ROOT sys.path = sys.path + [os.path.join(RTT_ROOT, 'tools'), BSP_ROOT] from building import * from rtua import GetCPPPATH from rtua import GetCPPDEFINES Export('RTT_ROOT') Export('BSP_ROOT') # add target option AddOption('--app', dest='app', nargs=1, type='string', action='store', metavar='DIR', help='installation prefix') # add target option AddOption('--type', dest='type', nargs=1, type='string', action='store', metavar='DIR', help='installation prefix') if GetOption('type') == 'ext': linkflags = rtconfig.LFLAGS + ' -e 0' else: linkflags = rtconfig.LFLAGS + ' -e main' CPPPATH = GetCPPPATH(BSP_ROOT, RTT_ROOT) env = Environment(tools = ['mingw'], AS = rtconfig.AS, ASFLAGS = rtconfig.AFLAGS, CC = rtconfig.CC, CCFLAGS = rtconfig.CFLAGS, CXX = rtconfig.CXX, AR = rtconfig.AR, ARFLAGS = '-rc', LINK = rtconfig.LINK, LINKFLAGS = linkflags, CPPPATH = CPPPATH) env.PrependENVPath('PATH', rtconfig.EXEC_PATH) PrepareModuleBuilding(env, RTT_ROOT, BSP_ROOT) app = GetOption('app') if app: objs = SConscript(os.path.join(app, 'D:/rt-thread_dev/rt-thread/examples/module/basicapp/SConscript')) TARGET = os.path.join(app , app + '.' + rtconfig.TARGET_EXT) # build program target = env.Program(TARGET, objs) env.Command("$TARGET", target, action = Copy(program_dir, TARGET)) ``` D: t-thread_dev t-threadexamplesmoduleasicapp下运行 scons --app=basicapp报错 ```scons: Reading SConscript files ... scons: done reading SConscript files. scons: Building targets ... arm-none-eabi-gcc -o basicapp.o -c -mcpu=cortex-m7 -mthumb -mlong-calls -O0 -fPIC -fno-exceptions -ID: t-thread_dev t-threadspstm32f767-apollo -ID: t-thread_dev t-threadspstm32f767-apolloapplications -ID: t-thread_dev t-threadspstm32f767-apollodrivers -ID: t-thread_dev t-threadcomponentsdfsfilesystemsdevfs -ID: t-thread_dev t-threadcomponentsdfsfilesystemselmfat -ID: t-thread_dev t-threadcomponentsdfsinclude -ID: t-thread_dev t-threadcomponentsdriversinclude -ID: t-thread_dev t-threadcomponentsdriversspi -ID: t-thread_dev t-threadcomponentsexternalluaapplications -ID: t-thread_dev t-threadcomponentsexternalluaexlibs -ID: t-thread_dev t-threadcomponentsexternallualua -ID: t-thread_dev t-threadcomponentsexternallua est -ID: t-thread_dev t-threadcomponentsfinsh -ID: t-thread_dev t-threadcomponentslibc ewlib -ID: t-thread_dev t-threadcomponentslibcpthreads -ID: t-thread_dev t-threadinclude -ID: t-thread_dev t-threadlibcpuarmcommon -ID: t-thread_dev t-threadlibcpuarmcortex-m7 basicapp.c Error in calling: arm-none-eabi-gcc -o "basicapp.o" -c -mcpu=cortex-m7 -mthumb -mlong-calls -O0 -fPIC -fno-exceptions -ID: t-thread_dev t-threadspstm32f767-apollo -ID: t-thread_dev t-threadspstm32f767-apolloapplications -ID: t-thread_dev t-threadspstm32f767-apollodrivers -ID: t-thread_dev t-threadcomponentsdfsfilesystemsdevfs -ID: t-thread_dev t-threadcomponentsdfsfilesystemselmfat -ID: t-thread_dev t-threadcomponentsdfsinclude -ID: t-thread_dev t-threadcomponentsdriversinclude -ID: t-thread_dev t-threadcomponentsdriversspi -ID: t-thread_dev t-threadcomponentsexternalluaapplications -ID: t-thread_dev t-threadcomponentsexternalluaexlibs -ID: t-thread_dev t-threadcomponentsexternallualua -ID: t-thread_dev t-threadcomponentsexternallua est -ID: t-thread_dev t-threadcomponentsfinsh -ID: t-thread_dev t-threadcomponentslibc ewlib -ID: t-thread_dev t-threadcomponentslibcpthreads -ID: t-thread_dev t-threadinclude -ID: t-thread_dev t-threadlibcpuarmcommon -ID: t-thread_dev t-threadlibcpuarmcortex-m7 "basicapp.c" Exception: [Error 2] : No such file or directory scons: building terminated because of errors. 但是命令行运行单独这个命令可以生成basicapp.o arm-none-eabi-gcc -o basicapp.o -c -mcpu=cortex-m7 -mthumb -mlong-calls -O0 -fPIC -fno-exceptions -ID: t-thread_dev t-threadspstm32f767-apollo -ID: t-thread_dev t-threadspstm32f767-apolloapplications -ID: t-thread_dev t-threadspstm32f767-apollodrivers -ID: t-thread_dev t-threadcomponentsdfsfilesystemsdevfs -ID: t-thread_dev t-threadcomponentsdfsfilesystemselmfat -ID: t-thread_dev t-threadcomponentsdfsinclude -ID: t-thread_dev t-threadcomponentsdriversinclude -ID: t-thread_dev t-threadcomponentsdriversspi -ID: t-thread_dev t-threadcomponentsexternalluaapplications -ID: t-thread_dev t-threadcomponentsexternalluaexlibs -ID: t-thread_dev t-threadcomponentsexternallualua -ID: t-thread_dev t-threadcomponentsexternallua est -ID: t-thread_dev t-threadcomponentsfinsh -ID: t-thread_dev t-threadcomponentslibc ewlib -ID: t-thread_dev t-threadcomponentslibcpthreads -ID: t-thread_dev t-threadinclude -ID: t-thread_dev t-threadlibcpuarmcommon -ID: t-thread_dev t-threadlibcpuarmcortex-m7 basicapp.c ``` 发现tools下的building.py等有变化,不知道是不是有影响。
2017-05-22
scons用的arm-none-eabi-gcc都不是命令行路径里配置的,需要在配置文件里制定,所以依然还是gcc未找到
jeffwei
2017-05-22
在rtconfig.py配置了GCC路径的,缺少/bin ``` # toolchains EXEC_PATH = 'C:/Program Files (x86)/GNU Tools ARM Embedded/5.4 2016q3' EXEC_PATH = 'C:/Program Files (x86)/GNU Tools ARM Embedded/5.4 2016q3/bin' ```
2.6k
jeffwei
122
貌似stm32f10x的应用模块在1.2.x版本不能正常编译
应用模块打开之后unload之后还在内存中
关于module.c的_load_shared_object的疑问
应用模块的rt_module_unload函数的bug
rtt 如何实现动态加载app
使用zmodem传输文件,应用模块文件传输完成,访问失败
RTT下应用模块编译具体方法
RTT应用模块编译出错
RTT应用模块编译问题
求问动态模块是什么意思呢
