mo动态模块_Module
应用模块找不到符号表
发布于 2017-05-23 10:58:26 浏览:3112
[tocm] 报错内容: ```Module: can't find led1_on in kernel symbol table Module: can't find rt_thread_delay in kernel symbol table ``` 平台是STM32F767正点原子阿波罗,IAR编译主程序,icf文件已经添加keep { section RTMSymTab }; 编译产生的rtthread.map文件可以找到 ```__rtmsym_rt_thread_delay 0x0804116c 0x8 Data Gb thread.o [1] __rtmsym_rt_thread_delay_name 0x08049cec 0x10 Data Gb thread.o [1]``` ```__rtmsym_led1_off 0x08040a94 0x8 Data Gb drv_led.o [1] __rtmsym_led1_off_name 0x0804a08c 0xc Data Gb drv_led.o [1] __rtmsym_led1_on 0x08040a8c 0x8 Data Gb drv_led.o [1] __rtmsym_led1_on_name 0x0804a6d0 0x8 Data Gb drv_led.o [1]``` ```RTMSymTab$$Base 0x0804090c -- Gb - Linker created - RTMSymTab$$Limit 0x080411d4 -- Gb - Linker created -``` 模块的rtconfig.py如下 ```import os cwd = os.path.split(os.path.realpath(__file__))[0] # RT-Thread root directory RTT_ROOT = 'D:/rt-thread_dev/rt-thread' BSP_ROOT = 'D:/rt-thread_dev/rt-thread/bsp/stm32f767-apollo' # toolchains EXEC_PATH = 'C:/Program Files (x86)/GNU Tools ARM Embedded/5.4 2016q3/bin' if os.getenv('RTT_ROOT'): RTT_ROOT = os.getenv('RTT_ROOT') if os.getenv('BSP_ROOT'): BSP_ROOT = os.getenv('BSP_ROOT') if os.getenv('RTT_EXEC_PATH'): EXEC_PATH = os.getenv('RTT_EXEC_PATH') PLATFORM = 'gcc' PREFIX = 'arm-none-eabi-' CC = PREFIX + 'gcc' CXX = PREFIX + 'g++' AS = PREFIX + 'gcc' AR = PREFIX + 'ar' LINK = PREFIX + 'gcc' TARGET_EXT = 'mo' SIZE = PREFIX + 'size' OBJDUMP = PREFIX + 'objdump' OBJCPY = PREFIX + 'objcopy' DEVICE = ' -mcpu=cortex-m7' CFLAGS = DEVICE + ' -mthumb -mlong-calls -O0 -fPIC -fno-exceptions' AFLAGS = ' -c' + DEVICE + ' -x assembler-with-cpp' LFLAGS = DEVICE + ' -mthumb -Wl,-z,max-page-size=0x4 -shared -fPIC -e main -nostdlib' CPATH = '' LPATH = '' ``` sconstruct 文件: ```import os import sys import rtconfig sconstruct = File('SConstruct') fn = sconstruct.rfile() name = fn.name building_dir = os.path.dirname(fn.abspath) program_dir = '../bin' from rtconfig import RTT_ROOT from rtconfig import BSP_ROOT sys.path = sys.path + [os.path.join(RTT_ROOT, 'tools'), BSP_ROOT] from building import * from rtua import GetCPPPATH from rtua import GetCPPDEFINES Export('RTT_ROOT') Export('BSP_ROOT') # add target option AddOption('--app', dest='app', nargs=1, type='string', action='store', metavar='DIR', help='installation prefix') # add target option AddOption('--type', dest='type', nargs=1, type='string', action='store', metavar='DIR', help='installation prefix') if GetOption('type') == 'ext': linkflags = rtconfig.LFLAGS + ' -e 0' else: linkflags = rtconfig.LFLAGS + ' -e main' CPPPATH = GetCPPPATH(BSP_ROOT, RTT_ROOT) env = Environment(tools = ['mingw'], AS = rtconfig.AS, ASFLAGS = rtconfig.AFLAGS, CC = rtconfig.CC, CCFLAGS = rtconfig.CFLAGS, CXX = rtconfig.CXX, AR = rtconfig.AR, ARFLAGS = '-rc', LINK = rtconfig.LINK, LINKFLAGS = linkflags, CPPPATH = CPPPATH) env.PrependENVPath('PATH', rtconfig.EXEC_PATH) PrepareModuleBuilding(env, RTT_ROOT, BSP_ROOT) app = GetOption('app') if app: objs = SConscript(os.path.join(app, 'D:/rt-thread_dev/rt-thread/examples/module/basicapp/SConscript')) TARGET = os.path.join(app , app + '.' + rtconfig.TARGET_EXT) # build program target = env.Program(TARGET, objs) env.Command("$TARGET", target, action = Copy(program_dir, TARGET))``` 确定rt_system_module_init函数运行到了下面代码: #elif defined (__IAR_SYSTEMS_ICC__) _rt_module_symtab_begin = __section_begin("RTMSymTab"); _rt_module_symtab_end = __section_begin("RTMSymTab"); #endif rtua.y是自动生成的。 确定报错函数是这个 static struct rt_module *_load_shared_object(const char *name, void *module_ptr) 求教下一步怎么查?
jeffwei
2017-05-23
用mdk试了一下,一加载就死了: \ | / - RT - Thread Operating System / | \ 2.1.0 build May 23 2017 2006 - 2017 Copyright by rt-thread team found part[0], begin: 32256, size: 14.857GB dfs initialized! msh />psr: 0x41000000 pc: 0xc1002ccc lr: 0x0800fca1 r12: 0x00000000 r03: 0x00000000 r02: 0xc1002ccd r01: 0x00000000 r00: 0x00000000 hard fault on thread: basicapp thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- basicapp 30 ready 0x00000048 0x00002000 01% 0x0000000a 000 led 12 suspend 0x00000078 0x00000100 46% 0x00000005 000 tshell 10 suspend 0x0000008c 0x00000400 20% 0x0000000a 000 tidle 31 ready 0x0000005c 0x00000200 17% 0x0000001e 000 timer 4 suspend 0x00000060 0x00000200 18% 0x00000009 000 main 10 suspend 0x00000084 0x00000800 43% 0x00000012 000 吐槽一下mdk速度问题,同样的工程,mdk编译链接要一刻钟,IAR只要一分钟。 ------------------------------------------------------------------------------------ 忘了一条,由于编译时报错,暂时屏蔽了LIBC代码 /* import the full stdio for printf */ #if defined(RT_USING_MODULE) && defined(__MICROLIB) #error "[RT_USING_LIBC] Please use standard libc but not microlib." #endif
2017-05-23
关掉符号浏览就快了,MDK是在编译时生成符号信号,IAR是编译完成后再生成。 所以在运算量一样的情况下,IAR先完成。
jeffwei
2017-05-23
>关掉符号浏览就快了,MDK是在编译时生成符号信号,IAR是编译完成后再生成。 >所以在运算量一样的情况下,IAR先完成。 --- 没找到在哪里关闭啊!
jeffwei
2017-05-24
用 list_symbol iar编译的主程序没列出符号 mdk编译的主程序就直接死在tshell了 ---------------------------------------------- 既然map文件有 ``` RTMSymTab$$Base 0x08041d9c Data Gb - Linker created - RTMSymTab$$Limit 0x08042664 Data Gb - Linker created - ``` 把rt_system_module_init里面IAR的程序换成和MDK一样,然后list_symbol就出来一大堆了 用rt_module_open也会死。把rt_module_open导出到msh,运行后报错乱码 ``` rt_kprintf("Module: access %s failed ", path); Module: access 劭Ⅴ#H肗I ?g_贜縥蛮E7?V?挖S薇鮡鍊atR?tR??6钲舦??T??`鶰阪W蕖 failed ``` -------------------------------------------------------------------------- 单步发现main程序使用 rt_module_open正常的,死在了startup_stm32f767xx.s中: B MemManage_Handler ``` MemManage_Handler B MemManage_Handler ```
jeffwei
2017-05-25
昨天下午培训易控软件去了,晚上吃虾喝酒,早上继续,因为是死在内存问题上, 就把SDRAM先关了,然后模块运行正常了。继续找SDRAM问题。
2017-05-25
难道mpu的权限没配置?
jeffwei
2017-05-25
>难道mpu的权限没配置? --- 上午又折腾选型买一堆样品,没时间搞程序,休息一下, 下午看看MPU配置再给你汇报结果。 -------------------------------------------------------- 没等到下午,刚刚看了MPU配置,0xC0000000起始地址, 我在board.h里面设置的0xC1000000开始,因为分了一半SDRAM 给emwin用了。以前没用过带MPU的CPU,还是老大威武,一句话搞定!
softwind
2017-06-01
>>难道mpu的权限没配置? > >--- > > >上午又折腾选型买一堆样品,没时间搞程序,休息一下, >下午看看MPU配置再给你汇报结果。 >-------------------------------------------------------- >没等到下午,刚刚看了MPU配置,0xC0000000起始地址, >我在board.h里面设置的0xC1000000开始,因为分了一半SDRAM >给emwin用了。以前没用过带MPU的CPU,还是老大威武,一句话搞定! --- @jeffwei, 我这边也准备采用RT-Thread+emWin,SDRAM做显存,想请教一下,您这边的SDRAM的MPU属性是怎么配置的?另外SDRAM是否也有一部分用作System Heap,这部分的MPU属性又是怎么设置的?
qiousanxi
2018-03-16
>上午又折腾选型买一堆样品,没时间搞程序,休息一下, >下午看看MPU配置再给你汇报结果。 >------------------ ... --- 看看 原子的例程,你做程序区的SDRAM和内部RAM 应该是一样的,
3.1k
jeffwei
122
貌似stm32f10x的应用模块在1.2.x版本不能正常编译
应用模块打开之后unload之后还在内存中
关于module.c的_load_shared_object的疑问
应用模块的rt_module_unload函数的bug
rtt 如何实现动态加载app
使用zmodem传输文件,应用模块文件传输完成,访问失败
RTT下应用模块编译具体方法
RTT应用模块编译出错
RTT应用模块编译问题
求问动态模块是什么意思呢
