mo动态模块_Module
测试 应用模块 功能编译时出错
发布于 2017-12-20 14:42:24 浏览:4891
我严格按照手册上的步骤做下来,在最后一步 scons --app=test执行之后会报错,由于对scons 不是很熟悉所以咨询下。 1.新建文件夹放入需要编译的文件 ![0.jpg](/uploads/201712/20/143445shzrhf1y3nb2bq59.jpg) 2.编译出错提示如下 ![1.jpg](/uploads/201712/20/143632pregymrmiegdjueu.jpg) F:\work>scons --app=test scons: Reading SConscript files ... scons: warning: No version of Visual Studio compiler found - C/C++ compilers mos t likely not set correctly File "F:\work\SConstruct", line 14, in
IOError: [Errno 2] No such file or directory: 'F:\\/bsp/stm32f10x/rtconfig.h': File "F:\work\SConstruct", line 66: PrepareModuleBuilding(env, RTT_ROOT, RTT_ROOT + '/bsp/' + rtconfig.BSP) File "F:\tools\building.py", line 346: f = file(bsp_directory + '/rtconfig.h', 'r') F:\work> **3.我还在源码目录下试了一下,但是还是报错** ![3.jpg](/uploads/201712/20/144201t2ebclen2ujw15xe.jpg) [E:\14.RTT3.0 t-thread-3.0.00 t-thread-3.0.0\examples\module]$ scons --app=basicapp scons: Reading SConscript files ... scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly File "E:\14.RTT3.0 t-thread-3.0.00 t-thread-3.0.0\examples\module\SConstruct", line 14, in
AttributeError: 'module' object has no attribute 'PLATFORM': File "E:\14.RTT3.0 t-thread-3.0.00 t-thread-3.0.0\examples\module\SConstruct", line 69: objs = SConscript(app + '/Sconscript', variant_dir=dir, duplicate=0) File "D:\Python2.7\Scripts\..\Lib\site-packages\scons-2.3.5\SCons\Script\SConscript.py", line 614: return method(*args, **kw) File "D:\Python2.7\Scripts\..\Lib\site-packages\scons-2.3.5\SCons\Script\SConscript.py", line 551: return _SConscript(self.fs, *files, **subst_kw) File "D:\Python2.7\Scripts\..\Lib\site-packages\scons-2.3.5\SCons\Script\SConscript.py", line 260: exec _file_ in call_stack[-1].globals File "E:\14.RTT3.0 t-thread-3.0.00 t-thread-3.0.0\examples\module\basicapp\Sconscript", line 6: group = DefineGroup('', src, depend = ['']) File "E:\14.RTT3.0 t-thread-3.0.00 t-thread-3.0.0\tools\building.py", line 505: if not GetOption('buildlib') and os.path.exists(os.path.join(group['path'], GroupLibFullName(name, Env))): File "E:\14.RTT3.0 t-thread-3.0.00 t-thread-3.0.0\tools\building.py", line 564: return env['LIBPREFIX'] + GroupLibName(name, env) + env['LIBSUFFIX'] File "E:\14.RTT3.0 t-thread-3.0.00 t-thread-3.0.0\tools\building.py", line 556: if rtconfig.PLATFORM == 'armcc':
neal
2017-12-20
**AttributeError: 'module' object has no attribute 'PLATFORM':** 这个错误我也没看到在429的bsp下面的scons相关文件中有定义。不知道是哪里设置有问题了。
2017-12-20
这个后面等等吧,需要参照另外一个rtthread-apps github仓库的。后面这些统一做些测试
neal
2017-12-20
我在rtconfig.py 里面加了一句 PLATFORM = 'gcc' 错误成了 [F:\AMOS\rtos\rtt2\examples\module]$ scons --app=basicapp scons: Reading SConscript files ... scons: warning: No version of Visual Studio compiler found - C/C++ compilers most likely not set correctly File "F:\AMOS\rtos\rtt2\examples\module\SConstruct", line 15, in
scons: done reading SConscript files. scons: Building targets ... arm-none-eabi-gcc -o basicapp\build\stm32f429-apollo\basicapp.o -c -mcpu=cortex-m4 -O0 -fPIC -DFTK_AS_PLUGIN -DRT_THREAD basicapp\basicapp.c Error in calling: arm-none-eabi-gcc -o "basicapp\build\stm32f429-apollo\basicapp.o" -c -mcpu=cortex-m4 -O0 -fPIC -DFTK_AS_PLUGIN -DRT_THREAD "basicapp\basicapp.c" Exception: [Error 2] : No such file or directory scons: *** [basicapp\build\stm32f429-apollo\basicapp.o] Error 2 scons: building terminated because of errors.
neal
2017-12-20
>这个后面等等吧,需要参照另外一个rtthread-apps github仓库的。后面这些统一做些测试 ... --- 那就是现在这些功能还没测试过是吗?哪个git 仓库里是软件啊
tanek
2017-12-20
>我在rtconfig.py 里面加了一句 PLATFORM = 'gcc' > >错误成了 --- 这个看起来有点像是编译器没找到。
neal
2017-12-21
>这个看起来有点像是编译器没找到。 --- 我后面把路径改了,不是编译器的问题。 现在是编译和 RTT相关的模块时,头文件会和编译器的头文件冲突,会报重复定义的错误。 只要编和RTT头文件无关的模块就能出现.so文件。 但是,在程序中加载的时候会出现段错误,终端会打印出寄存器的值,然后报错。
neal
2017-12-21
查看源码得知,其实加载模块就是动态创建线程。在文件module.c的1044行可以看出来,有rt_thread_creat()函数调用。现在就查看在动态线程创建的时候会不会出错。在rtdebug.h中打开RT_DEBUG_MODULE宏。终端打印如下: rt_module_load: basicapp LOAD segment: 0, 0x00000000, 0x000003fb LOAD segment: 1, 0x00000400, 0x000000b4 module size: 1204, vstart_addr: 0x00000000 relocate symbol c shndx 11 R_ARM_JUMP_SLOT: 0x200117b0 -> 0x200117b8 0x200117b8 relocate symbol printf shndx 0 relocate symbol: printf
gk7
2017-12-22
>我在rtconfig.py 里面加了一句 PLATFORM = 'gcc' > >错误成了 --- 我也出现了这样的错误,请问你最后是怎么解决的呢?
neal
2017-12-22
问题已解决: 我的stm32_rom.ld 文件中少 /* section information for modules */ . = ALIGN(4); __rtmsymtab_start = .; KEEP(*(RTMSymTab)) __rtmsymtab_end = .; 加上就好了,内部原理正在研究。git 上最新的代码里面有这些,应该不会有问题。
tanek
2017-12-23
>问题已解决: >我的stm32_rom.ld 文件中少 >/* section information for modules */ --- 这个是保留module用到的api到一个section里面,在加载模块的时候做重定向用的。
4.9k
neal
21
75
貌似stm32f10x的应用模块在1.2.x版本不能正常编译
应用模块打开之后unload之后还在内存中
关于module.c的_load_shared_object的疑问
应用模块的rt_module_unload函数的bug
rtt 如何实现动态加载app
使用zmodem传输文件,应用模块文件传输完成,访问失败
RTT下应用模块编译具体方法
RTT应用模块编译出错
RTT应用模块编译问题
求问动态模块是什么意思呢
