如何新建rt-thread 工程
发布于 2018-05-24 14:34:42 浏览:4634
* 本帖最后由 zhanxiaozhang 于 2018-5-24 14:51 编辑 * 各位高手,我在新增项目的时候,把bsp下的工程copy一份到我的工程位置(不在rt-thread 目录下) 系统变量换了RTT_ROOT 为rt-thread 的根目录 编译的时候出现错误: ImportError: No module named building: File "F:\Workspace\2018\Stm32_rt_thread_demo\first_demo\code\SConstruct", line 13: from building import * F:\Workspace\tools t-thread-master\这个是rtt的root F:\Workspace\2018\Stm32_rt_thread_demo\first_demo\code这个是bsp 下copy过来的 请指教。 一般我们的工程不可能在rt-thread的bsp下面建工程,都是在其他地方建立自己的工程和code,其他component和kernel source 等都放在rt-thread 的地方。 还请指教。
zhanxiaozhang
2018-05-24
[i=s] 本帖最后由 zhanxiaozhang 于 2018-5-24 15:50 编辑 [/i] 找到问题了,‘\’是转义字符,需要‘\\’ 但是,env找不到RTT_ROOT ,实际已经设置到了系统环境变量 menuconfig menuconfig command should be used in a bsp root path with a Kconfig file, you should check if there is a Kconfig file in your bsp root first. And then you can check Kconfig file and modify the default option below to your rtthread root path. config $RTT_DIR string option env="RTT_ROOT" default "../.." example: default "F:/git_repositories/rt-thread" using command 'set RTT_ROOT=your_rtthread_root_path' to set RTT_ROOT is ok too. you can ignore debug messages below. Kconfig:3:warning: ignoring unsupported character '$' Kconfig:3:warning: environment variable BSP_ROOT undefined Kconfig:8:warning: ignoring unsupported character '$' Kconfig:8:warning: environment variable RTT_ROOT undefined Kconfig:13:warning: ignoring unsupported character '$' Kconfig:18: can't open file "../../Kconfig" Try the command
Enable the auto update option,env will auto update the packages you select. All the selected packages have been downloaded successfully. Operation completed successfully. Auto update packages done Select the project type your bsp support and then env will create a new mdk/iar project.
nicole.088
2018-06-01
也遇到此问题,怎么破?
haisen668
2018-11-30
set RTT_ROOT=D:\\你的路劲\\rt-thread 是用 \\ 区分
4.6k
zhanxiaozhang
用scons构建代码出现问题
求助用scons生成不了mdk工程
关于使用scons编译的问题
关于scons 编译CPP问题求教
scons编译出现警告信息
SCons生成MDK5工程出错
realtouch的scons问题
SCons的PreAction能用吗?
scons 编译时出错。
求教:关于scons构建rtt时的两个问题
