文件系统学习营
【文件系统学习】+DMY+任务2 文件匹配
发布于 2018-07-17 10:11:43 浏览:1422
a.开发环境:RT-Thread源码+ENV工具+Source Insight 4.0 完成任务的前提: (1)已经对RTT内核熟悉,了解基本操作,可以在荔枝微课中观看15入门视频学习。 (2)熟悉ENV基本操作,可以在网易云课堂中搜索ENV教学视频。 b.过程及结果: 任务2.文件匹配:有一系列文件如:1.txt,12.txt,123.txt,从中找出1.txt 任务2可以更据ls命令改编,改编思路为,在列出当前文件夹中文件时与输入的文件比较,若与输入的文件名相同则,说明匹配成功打印This Directory has the specifiedfile 若没有匹配的文件则打印check_file failure 具体文件如下,在之前的工程下修改用Source Insight修改main。 #include
int main(void) { printf("hello rt-thread
"); return 0; } static struct dfs_fd fd; static struct dirent dirent; void check_file(int argc, char **argv) { struct stat stat; int length; char *fullpath, *path; char *pathname; int temp=0; fullpath = NULL; if ((argc < 1)&&(argc > 3)) return ; if (pathname == NULL) { #ifdef DFS_USING_WORKDIR /* open current working directory */ path = rt_strdup(working_directory); #else path = rt_strdup("/"); #endif if (path == NULL) return ; /* out of memory */ } else { path = (char *)pathname; } /* list directory */ if (dfs_file_open(&fd, path, O_DIRECTORY) == 0) { rt_kprintf("Directory %s:
", path); do { memset(&dirent, 0, sizeof(struct dirent)); length = dfs_file_getdents(&fd, &dirent, sizeof(struct dirent)); if (length > 0) { memset(&stat, 0, sizeof(struct stat)); /* build full path for each file */ fullpath = dfs_normalize_path(path, dirent.d_name); if (fullpath == NULL) break; if (dfs_file_stat(fullpath, &stat) == 0) { // rt_kprintf("%-20s", dirent.d_name); if (0 == strcmp(argv[1], dirent.d_name)) { rt_kprintf("This Directory has the specified file \"%s\".
", dirent.d_name); temp=1; dfs_file_close(&fd); return ; } } else rt_kprintf("BAD file: %s
", dirent.d_name); rt_free(fullpath); } }while(length > 0); if(temp==0) rt_kprintf("check_file failure \"%s\"
",argv[1]); dfs_file_close(&fd); } else { rt_kprintf("No such directory
"); } if (pathname == NULL) rt_free(path); } MSH_CMD_EXPORT(check_file, check one file contain in the current directory); 修改使用scons编译,qemu.bat运行后实验现象如图: ![600,0](https://oss-club.rt-thread.org/uploads/201807/14/031709ih6h4g467i4pmmgr.png) 以上任务2完成
1.4k
DMY
【文件系统学习】+DMY+任务1sample例程
【文件系统学习】skawu的文件系统跑起来了
【文件系统学习】skawu之文件匹配学习
【文件系统学习】+清石+运行文件系统sample例程
【文件系统学习】+小燕+运行文件系统sample例程
【文件系统学习】+阿暖+运行文件系统 sample 例程
【文件系统学习】+小燕+一系列文件中找出指定文件
【文件系统学习】+小燕+文件数据替换
