文件系统学习营
文件系统学习 + Eric + 输出系统log
发布于 2018-07-18 21:43:25 浏览:1476
将系统 log 日志,保存为 csv 文件,存储到 SD 卡中,通过 winimage 提取出 csv 文件,可以通过 excel 打开; log是通过rt_kprintf打印出来的,所以需要将在rt_kprintf函数中,将所有内容顺便往我们的csv文件中保持一份! 先编写csv一个函数: ``` void write_log_to_csv(const char* log_name, const char* log_buf) { FILE *fp = fopen(log_name, "a+"); if(fp == NULL) return; fseek(fp, 0, SEEK_END); fwrite(log_buf, strlen(log_buf), 1, fp); fclose(fp); } ``` 在rt_kprintf函数中: ``` void rt_kprintf(const char *fmt, ...) { va_list args; rt_size_t length; static char rt_log_buf[RT_CONSOLEBUF_SIZE]; va_start(args, fmt); /* the return value of vsnprintf is the number of bytes that would be * written to buffer had if the size of the buffer been sufficiently * large excluding the terminating null byte. If the output string * would be larger than the rt_log_buf, we have to adjust the output * length. */ length = rt_vsnprintf(rt_log_buf, sizeof(rt_log_buf) - 1, fmt, args); if (length > RT_CONSOLEBUF_SIZE - 1) length = RT_CONSOLEBUF_SIZE - 1; #ifdef RT_USING_DEVICE if (_console_device == RT_NULL) { rt_hw_console_output(rt_log_buf); } else { rt_uint16_t old_flag = _console_device->open_flag; _console_device->open_flag |= RT_DEVICE_FLAG_STREAM; rt_device_write(_console_device, 0, rt_log_buf, length); _console_device->open_flag = old_flag; } //添加log函数 { extern int fs_system_init;//文件系统标志位,初始化完成后才工作,不然会出现下图错误 extern void write_log_to_csv(const char* log_name, const char* log_buf); if(fs_system_init == 1) write_log_to_csv("log.csv", rt_log_buf); } #else rt_hw_console_output(rt_log_buf); #endif va_end(args); } ``` ![1.png](/uploads/201807/18/214246teexau02fn2eenlu.png) ``` int fs_system_init = 0; int mnt_init(void) { rt_thread_delay(RT_TICK_PER_SECOND); if (dfs_mount("sd0", "/", "elm", 0, 0) == 0) { rt_kprintf("file system initialization done!
"); } fs_system_init = 1; return 0; } ``` 运行情况: ![2.png](/uploads/201807/18/214247jxx5acc2micnz5o9.png) ![3.png](/uploads/201807/18/214247bn2hcs9yucnrs4lf.png) ![4.png](/uploads/201807/18/214247mpeyruvy9cunra3h.png)
1.5k
EricYYG
【文件系统学习】+DMY+任务1sample例程
【文件系统学习】skawu的文件系统跑起来了
【文件系统学习】skawu之文件匹配学习
【文件系统学习】+清石+运行文件系统sample例程
【文件系统学习】+小燕+运行文件系统sample例程
【文件系统学习】+阿暖+运行文件系统 sample 例程
【文件系统学习】+小燕+一系列文件中找出指定文件
【文件系统学习】+小燕+文件数据替换
