文件系统学习营
【文件系统学习】+小燕+基于STM32F407ZG开发板运行文件系统
发布于 2018-07-28 00:08:19 浏览:2094
```/* * File : main.c * This file is part of RT-Thread RTOS * COPYRIGHT (C) 2009, RT-Thread Development Team * * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * http://www.rt-thread.org/license/LICENSE * * Change Logs: * Date Author Notes * 2015-07-29 Arda.Fu first implementation */ #include
// 监听通讯口相关定义 #define RT_COMM_DEVICE_NAME "uart2" // 监听数据存储文件 #define DATA_FILE_NAME "dongle.dat" // 数据监听任务 #define STK_DONGLE_SIZE 1024 #define TASK_DONGLE_PRIORITY 1 rt_thread_t s_dongle_thread = RT_NULL; // 接收缓存 typedef struct { uint8_t buf[RT_SERIAL_RB_BUFSZ]; uint8_t len; } _uart_recv; _uart_recv s_uart_recv = {0}; // 中断callback static rt_err_t rt_uart_callback(rt_device_t dev, rt_size_t size) { uint8_t readSize; // 防止任务处理不及时溢出 if (s_uart_recv.len >= RT_SERIAL_RB_BUFSZ) { s_uart_recv.len = 0; } readSize = (size > RT_SERIAL_RB_BUFSZ) ? RT_SERIAL_RB_BUFSZ : size; if (s_uart_recv.len + readSize > RT_SERIAL_RB_BUFSZ) { readSize = RT_SERIAL_RB_BUFSZ - s_uart_recv.len; } s_uart_recv.len += rt_device_read(dev, 0, &s_uart_recv.buf[s_uart_recv.len], readSize); return RT_EOK; } // 写文件 static void data_file_write(uint8_t *data, uint8_t len) { char *fullpath, *path; struct dfs_fd fd; struct stat file_stat; // 文件路径 #ifdef DFS_USING_WORKDIR path = rt_strdup(working_directory); #else path = rt_strdup("/"); #endif if (NULL == path) { return; } // 路径+文件名 fullpath = dfs_normalize_path(path, DATA_FILE_NAME); if (NULL == fullpath) { rt_free(path); return; } // 打开文件 if (dfs_file_open(&fd, fullpath, O_CREAT | O_RDWR)) { rt_free(path); rt_free(fullpath); return; } // 获取文件信息 if (dfs_file_stat(fullpath, &file_stat)) { dfs_file_close(&fd); rt_free(path); rt_free(fullpath); return; } // 定位到文件末尾 if (dfs_file_lseek(&fd, file_stat.st_size) < 0) { dfs_file_close(&fd); rt_free(path); rt_free(fullpath); return; } // 写数据 if (dfs_file_write(&fd, data, len) < 0) { dfs_file_close(&fd); rt_free(path); rt_free(fullpath); return; } dfs_file_close(&fd); rt_free(path); rt_free(fullpath); } // 监听任务 void dongle_task(void *parameter) { // 监听接收 while (1) { if (s_uart_recv.len) { data_file_write(s_uart_recv.buf, s_uart_recv.len); s_uart_recv.len = 0; } rt_thread_delay(10); } } // user main int main(void) { rt_device_t comm_uart; uint8_t send_buf[] = "lillian test send.
"; // 挂载文件系统 if (dfs_mount("sd0", "/", "elm", 0, 0) == 0) { rt_kprintf("file system initialization done!
"); } else { rt_kprintf("file system initialization failed!
"); } // 打开UART2 comm_uart = rt_device_find(RT_COMM_DEVICE_NAME); // 设置中断callback rt_device_set_rx_indicate(comm_uart, rt_uart_callback); rt_device_open(comm_uart, RT_DEVICE_OFLAG_RDWR | RT_DEVICE_FLAG_INT_RX); // 测试UART2发送 rt_device_write(comm_uart, 0, send_buf, strlen((const char *)send_buf)); s_dongle_thread = rt_thread_create("dongle", dongle_task, RT_NULL, STK_DONGLE_SIZE, TASK_DONGLE_PRIORITY, 20); RT_ASSERT(s_dongle_thread != RT_NULL); rt_thread_startup(s_dongle_thread); return 0; } ``` 下载附件 [第二周:开发板跑文件系统.docx](https://oss-club.rt-thread.org/uploads/201807/28/000751i36xa9x9a3x6w3rv.attach)
lillian
2018-07-28
``` /** * This function will initial STM32 board. */ void rt_hw_board_init() { /* Configure the system clock @ 84 Mhz */ SystemClock_Config(); HAL_Init(); #ifdef RT_USING_HEAP rt_system_heap_init((void *)HEAP_BEGIN, (void *)HEAP_END); #endif #ifdef RT_USING_COMPONENTS_INIT rt_components_board_init(); #endif #ifdef RT_USING_CONSOLE rt_console_set_device(RT_CONSOLE_DEVICE_NAME); #endif if (SD_Init()) { rt_kprintf("\r\nSD init failed.\r\n"); } else { rt_kprintf("\r\nSD init OK.\r\n"); } } ```
lillian
2018-07-28
今天仔细看了系统的初始化内容,我通过ENV使能了SD卡驱动,系统有自动初始化SD卡,所以我在board.c里面那个初始化是冗余的。
lillian
2018-07-28
我的工程通过ENV配置如下: 1、Using console for console log printf uart1 2、Enable software timer with a timer thread 3、Use components automatically initialization 4、Using device virtual file system Using working directory Enable elm-chan fatfs Support long file name 5、Using generic GPIO 6、Using UART1 UART2
lillian
2018-07-28
components automatically initialization:内容如下: 1、rt_hw_pin_init(); 2、hw_usart_init(); 3、rt_hw_sdcard_init();
lillian
2018-07-28
``` \ | / - RT - Thread Operating System / | \ 3.1.0 build Jul 28 2018 2006 - 2018 Copyright by rt-thread team SD Card init OK file system initialization done! msh />list_device device type ref count ------ -------------------- ---------- sd0 Block Device 1 uart2 Character Device 1 uart1 Character Device 2 pin Miscellaneous Device 0 ```
lillian
2018-07-28
> --- 这个是我将rt_hw_board_init()里面冗余的的SD初始化删掉之后运行依然正常,终于彻底把系统自动初始化这块理清楚了。 附上rt_hw_board_init()完全是系统生成的初始化函数: ``` /** * This function will initial STM32 board. */ void rt_hw_board_init() { /* Configure the system clock @ 84 Mhz */ SystemClock_Config(); HAL_Init(); #ifdef RT_USING_HEAP rt_system_heap_init((void *)HEAP_BEGIN, (void *)HEAP_END); #endif #ifdef RT_USING_COMPONENTS_INIT rt_components_board_init(); #endif #ifdef RT_USING_CONSOLE rt_console_set_device(RT_CONSOLE_DEVICE_NAME); #endif } ```
lillian
2018-07-28
[i=s] 本帖最后由 lillian 于 2018-7-28 13:36 编辑 [/i] 另外还要纠正一个问题: 我之前的串口数据处理有问题,没有考虑到在任务里面处理数据的时候,接收中断会随时打断任务,修改接收数据,所以会丢包;我现在加了一个缓存来处理数据,修改后的源码如下: ``` ``` ``` // 接收缓存 #define RECV_BUF_MAX 1024 typedef struct { uint8_t buf[RECV_BUF_MAX]; uint8_t len; } _uart_recv; _uart_recv s_uart_recv = {0}; _uart_recv s_uart_data = {0}; // 中断callback static rt_err_t rt_uart_callback(rt_device_t dev, rt_size_t size) { uint8_t readSize; // 防止任务处理不及时溢出 if (s_uart_recv.len >= RECV_BUF_MAX) { s_uart_recv.len = 0; } readSize = (size > RECV_BUF_MAX) ? RECV_BUF_MAX : size; if ((s_uart_recv.len + readSize) > RECV_BUF_MAX) { readSize = RECV_BUF_MAX - s_uart_recv.len; } s_uart_recv.len += rt_device_read(dev, 0, &s_uart_recv.buf[s_uart_recv.len], readSize); return RT_EOK; } // 监听任务 void dongle_task(void *parameter) { // 监听接收 while (1) { rt_enter_critical(); if (s_uart_recv.len) { s_uart_data.len = s_uart_recv.len; memcpy(s_uart_data.buf, s_uart_recv.buf, s_uart_recv.len); s_uart_recv.len = 0; } rt_exit_critical(); if (s_uart_data.len) { data_file_write(s_uart_data.buf, s_uart_data.len); s_uart_data.len = 0; } rt_thread_delay(10); } } ```
lillian
2018-07-28
图1是串口发送数据,图2是监听写到dat文件的数据,不会出现丢包现象了。
快去买药
2018-08-07
楼主你407用的哪个bsp, 4xxhal吗? 我这边死活挂载不上,楼主工程能发下吗
lillian
2018-08-07
>楼主你407用的哪个bsp, 4xxhal吗? >我这边死活挂载不上,楼主工程能发下吗 --- 咋发,是4xx_hal
2.1k
lillian
49
【文件系统学习】+DMY+任务1sample例程
【文件系统学习】skawu的文件系统跑起来了
【文件系统学习】skawu之文件匹配学习
【文件系统学习】+清石+运行文件系统sample例程
【文件系统学习】+小燕+运行文件系统sample例程
【文件系统学习】+阿暖+运行文件系统 sample 例程
【文件系统学习】+小燕+一系列文件中找出指定文件
【文件系统学习】+小燕+文件数据替换
