文件系统学习营
【文件系统学习】+yufanyufan77+第二周 tar解析
发布于 2018-07-28 23:06:44 浏览:1899
* 本帖最后由 yufanyufan77 于 2018-7-28 23:27 编辑 * [align=center]** **```这个位置添加错了,怎么才能删掉```**1****、开发环境:**原子stm32f4探索者、ENV、rt_thread **2****、参考文档**[http://www.moon-soft.com/program/FORMAT/comm/tar.htm](http://www.moon-soft.com/program/FORMAT/comm/tar.htm)[https://www.rt-thread.org/document/site/rtthread-development-guide/rtthread-manual-doc/zh/1chapters/12-chapter_filesystem/](https://www.rt-thread.org/document/site/rtthread-development-guide/rtthread-manual-doc/zh/1chapters/12-chapter_filesystem/) **3****、这次的任务主要有以下几个要点:**熟读tar格式Tar格式解析在SD卡建文件夹在文件夹中写入解析的数据 **tar.h文件**```#ifndef __UNRAR_H__ #define __UNRAR_H__ /* * standard archive format - standard tar - ustar */ #define recordsize 512 #define namsiz 100 #define tunmlen 32 #define tgnmlen 32 #define lf_oldnormal '\0' /* normal disk file, unix compatible */ #define lf_normal '0' /* normal disk file */ #define lf_link '1' /* link to previously dumped file */ #define lf_symlink '2' /* symbolic link */ #define lf_chr '3' /* character special file */ #define lf_blk '4' /* block special file */ #define lf_dir '5' /* directory */ #define lf_fifo '6' /* fifo special file */ #define lf_contig '7' /* contiguous file */ /* further link types may be defined later. */ /* bits used in the mode field - values in octal */ #define tsuid 04000 /* set uid on execution */ #define tsgid 02000 /* set gid on execution */ #define tsvtx 01000 /* save text (sticky bit) */ /* file permissions */ #define turead 00400 /* read by owner */ #define tuwrite 00200 /* write by owner */ #define tuexec 00100 /* execute/search by owner */ #define tgread 00040 /* read by group */ #define tgwrite 00020 /* write by group */ #define tgexec 00010 /* execute/search by group */ #define toread 00004 /* read by other */ #define towrite 00002 /* write by other */ #define toexec 00001 /* execute/search by other */ typedef struct tar_header { char name[100]; char mode[8]; char uid[8]; char gid[8]; char size[12]; char mtime[12]; char chksum[8]; char typeflag; char linkname[100]; char magic[6]; char version[2]; char uname[32]; char gname[32]; char devmajor[8]; char devminor[8]; char prefix[155]; char padding[12]; }tar_header_Type; typedef struct untarCon { unsigned char startFlag; char filename[100]; char* filedata ; unsigned int fileSizes; unsigned int writeDataLen; unsigned int readFinshDataLen; }untarCon_Type; #endif ``` **untar.c文件**```/* * File : led.h * This file is part of SS_FYF * COPYRIGHT (C) 2009, yufanyufan77 * * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * QQ:765637468 * * Change Logs: * Date Author Notes * 2018-07-28 yufanyufan77 first implementation */ #include "unrar.h" #include
/* 当需要使用文件操作时,需要包含这个头文件 */ //切换到上一层目录 #define changeLastDir() chdir("/..") tar_header_Type tarHead; static untarCon_Type untarCons; //检测到目录,创建目录 rt_err_t untar_makdir(tar_header_Type tarHead); //tar格式解析 rt_err_t untar_file(tar_header_Type tarHead); //检测到文件,创建创建文件到相应目录下 rt_err_t untar_writefiles(untarCon_Type* untarCons); void read_tarFile(const char* fpaths,int x) { char buf[512]; int i = 0; int fd = 0; int len = 0; rt_memset((char*)&untarCons,0,sizeof(untarCons)); untarCons.filedata = buf; fd = open(fpaths,O_RDONLY); if(fd == RT_NULL) rt_kprintf("%d open file fail!"); for(i=0;;i++) { seekfile(fd , sizeof(tarHead)*i); if(!untarCons.startFlag) { len = read(fd,(char*)&tarHead,sizeof(tarHead)); } else { len = read(fd,buf,512); } if(len <= 0) { rt_kprintf("
read file finsh!
"); break; } if(!untarCons.startFlag) { untar_file(tarHead); } else//向指定目录写文件 { untar_writefiles(&untarCons); } } close(fd); } unsigned int cal(unsigned int data,unsigned char n) { unsigned int datatemp=1; if(!n) return 1; while(n--) { datatemp*=data; } return datatemp; } //8进制转换 unsigned int eightToten(unsigned int data) { unsigned int tempeight = 0; unsigned int temp = data; unsigned int tempy = 0; unsigned char i = 0; for(i=0; ;i++) { tempy = temp%10; tempeight = tempeight+(tempy<<3*i); temp = data/cal(10,i+1); if(!temp) break; } return tempeight; } //tar格式解析 rt_err_t untar_file(tar_header_Type tarHead) { unsigned int temp; if(tarHead.name[0]==RT_NULL) return RT_EOK; //根据文件类型判断进行相应的处理 switch(tarHead.typeflag) { case lf_oldnormal: break; case lf_normal://普通磁盘文件 rt_memcpy(untarCons.filename,tarHead.name,sizeof(tarHead.name)); untarCons.startFlag = 1; temp=atoi(tarHead.size); untarCons.fileSizes = eightToten(temp); rt_kprintf("untarCons.fileSizes = %d
",untarCons.fileSizes); break; case lf_link: break; case lf_symlink: break; case lf_chr: break; case lf_blk: break; case lf_dir://目录 //创建目录 untar_makdir(tarHead); break; case lf_fifo: break; case lf_contig: break; } } //检测到目录,创建目录 rt_err_t untar_makdir(tar_header_Type tarHead) { char nameStr[100]; int dirid = 0; DIR* dirtemp ; dirtemp = opendir("/sd"); if(dirtemp == RT_NULL) { rt_kprintf("open %s dir faill!
",nameStr); return RT_ERROR; } sprintf(nameStr,"/sd/%s",tarHead.name); dirid = mkdir(nameStr,0x777); if(dirid == RT_EOK) { rt_kprintf("creat %s dir ok!
",nameStr); return RT_EOK; } else rt_kprintf("creat %s dir faill!
",nameStr); closedir(dirtemp); return RT_ERROR; } //检测到文件,创建创建文件到相应目录下 rt_err_t untar_writefiles(untarCon_Type* untarCons) { char nameStr[100]; int dirid = 0; DIR* dirtemp ; int fd; int size; int len = 0; sprintf(nameStr,"/sd/%s",untarCons->filename); fd = open(nameStr, O_WRONLY | O_CREAT);//向SD写入数据 if (fd >= 0) { struct stat buf; char* str; stat(nameStr, &buf); seekfile(fd , buf.st_size); if(untarCons->fileSizes > 512) { untarCons->fileSizes -= 512; len = write(fd,untarCons->filedata,512); } else { len = write(fd,untarCons->filedata,untarCons->fileSizes); untarCons->fileSizes = 0; untarCons->startFlag = 0; } if(!len) rt_kprintf("write %s file faill
",untarCons->filename); close(fd); return RT_EOK; } untarCons->startFlag = 0; return RT_ERROR; } #ifdef RT_USING_FINSH #include
FINSH_FUNCTION_EXPORT(read_tarFile, startup read_tarFile); #endif /* RT_USING_FINSH */ ``` 下载附件 [RT-Thread文件系统学习营tar解析挑战任务.docx](https://oss-club.rt-thread.org/uploads/201807/28/232309k4z1krj1nm41pnfx.attach)
wen619
2018-08-07
你好,能否把你在原子407板子上移植RTT+LWIP成功的工程分享给我下,RTT和LWIP对我来说都是新的,按照你学习营的笔记我自己无法独立完成,谢谢了先![email]419099632@qq.com[/email]
yufanyufan77
2018-08-07
>你好,能否把你在原子407板子上移植RTT+LWIP成功的工程分享给我下,RTT和LWIP对我来说都是新的,按照你学习 ... --- 你可以说说你有什么地方不明白的
wen619
2018-08-07
首先 我想知道[https://www.rt-thread.org/qa/thread-7696-1-1.html](https://www.rt-thread.org/qa/thread-7696-1-1.html)里截屏的移植是否成功?RX err = -3 不能说明我移植失败吧? 另外 我添加了E:\RT-Thread\rt-thread-master\rt-thread-master\examples\network里面的udpclinet.c文件,下一步是不是应该建一个udpclinet.h文件并在其中申明udpclinet.c文件里的函数void udpclient(const char *url, int port, int count),之后可以在main中包含udpclinet.h文件并创建线程调用udpclient()函数测试与PC服务器的收发功能?
嘻哈CM3
2019-02-17
文件系统的学习营资料可以传一份给我吗?[email]www88888ab@126.com[/email]
1.9k
yufanyufan77
36
【文件系统学习】+DMY+任务1sample例程
【文件系统学习】skawu的文件系统跑起来了
【文件系统学习】skawu之文件匹配学习
【文件系统学习】+清石+运行文件系统sample例程
【文件系统学习】+小燕+运行文件系统sample例程
【文件系统学习】+阿暖+运行文件系统 sample 例程
【文件系统学习】+小燕+一系列文件中找出指定文件
【文件系统学习】+小燕+文件数据替换
