求关于RT-Thread中Ymodem的使用方法
发布于 2018-08-08 11:34:27 浏览:6448
有没有大神用过RT-thread中的Ymodem的? 我尝试了论坛早期发的Ymodem使用方法,但是接收不到CCCC,又尝试了ENV中的Ymodem,但是还是不能成功,求指教怎么使用这个功能。。。。。。
armink
2018-08-08
来一段,使用 Ymodem + EasyFlash 完成 IAP 固件下载的代码示例,仅供参考 ``` #include
static size_t update_file_total_size, update_file_cur_size; static uint32_t crc32_checksum = 0; static enum rym_code ymodem_on_begin(struct rym_ctx *ctx, rt_uint8_t *buf, rt_size_t len) { char *file_name, *file_size; /* calculate and store file size */ file_name = (char *) &buf[0]; file_size = (char *) &buf[rt_strlen(file_name) + 1]; update_file_total_size = atol(file_size); /* 4 bytes align */ update_file_total_size = (update_file_total_size + 3) / 4 * 4; update_file_cur_size = 0; crc32_checksum = 0; /* erase backup section */ if (ef_erase_bak_app(update_file_total_size)) { /* if erase fail then end session */ return RYM_CODE_CAN; } return RYM_CODE_ACK; } static enum rym_code ymodem_on_data(struct rym_ctx *ctx, rt_uint8_t *buf, rt_size_t len) { if (update_file_cur_size + len <= update_file_total_size) { crc32_checksum = ef_calc_crc32(crc32_checksum, buf, len); } else { crc32_checksum = ef_calc_crc32(crc32_checksum, buf, update_file_total_size - update_file_cur_size); } /* write data of application to backup section */ if (ef_write_data_to_bak(buf, len, &update_file_cur_size, update_file_total_size)) { /* if write fail then end session */ return RYM_CODE_CAN; } return RYM_CODE_ACK; } void update(uint8_t argc, char **argv) { char new_char[2], c_file_size[11] = { 0 }, c_crc32_checksum[11] = { 0 }; struct rym_ctx rctx; elog_set_output_enabled(false); rt_kprintf("Waring: This operator will not recovery. If you want, press 'Y'.\n"); new_char[0] = getchar(); rt_kprintf("%c", new_char[0]); new_char[1] = getchar(); rt_kprintf("%c", new_char[1]); if ((new_char[0] != 'y') && (new_char[0] != 'Y')) { goto __exit; } rt_kprintf("Please select the application firmware file and use Ymodem to send.\n"); if (!rym_recv_on_device(&rctx, rt_console_get_device(), RT_DEVICE_OFLAG_RDWR | RT_DEVICE_FLAG_INT_RX, ymodem_on_begin, ymodem_on_data, NULL, RT_TICK_PER_SECOND)) { /* wait some time for terminal response finish */ rt_thread_delay(RT_TICK_PER_SECOND); /* save the downloaded firmware crc32 checksum ENV */ ef_set_env("iap_need_crc32_check", "1"); rt_snprintf(c_crc32_checksum, sizeof(c_crc32_checksum), "%ld", crc32_checksum); ef_set_env("iap_crc32_checksum", c_crc32_checksum); /* set need copy application from backup section flag is 1, backup application length */ ef_set_env("iap_need_copy_app", "1"); rt_sprintf(c_file_size, "%ld", update_file_total_size); ef_set_env("iap_copy_app_size", c_file_size); ef_save_env(); rt_kprintf("Download firmware to flash OK.\n"); rt_kprintf("System now will restart...\n"); NVIC_SystemReset(); } else { /* wait some time for terminal response finish */ rt_thread_delay(RT_TICK_PER_SECOND); rt_kprintf("Update firmware fail.\n"); } __exit: elog_set_output_enabled(true); } MSH_CMD_EXPORT(update, Update user application firmware); ```
丿纸飞机巛
2018-08-08
>来一段,使用 Ymodem + EasyFlash 完成 IAP 固件下载的代码示例,仅供参考 --- 谢谢,不过我的应用场景是想通过Ymodem协议发送字库文件到挂载的外部flash上,通过固件库example的tofile.c文件没实现........可能是我使用的方法不对,目前没头绪!
2018-08-08
你需要传进去,还是传出去?传进去到板子上,是tofile.c,记得有个命令执行下,然后就可以通过串口工具发送文件了。因为是tofile,所以是写到文件系统上,保存为文件的。
armink
2018-08-08
ymodem_on_data 里 ef_write_data_to_bak 就是拷贝接收到的数据到 flash 上的
丿纸飞机巛
2018-08-09
>你需要传进去,还是传出去?传进去到板子上,是tofile.c,记得有个命令执行下,然后就可以通过串口工具发送 ... --- 是的,熊老大,就是传文件到文件系统上,但是我执行命令就死机,不知道什么问题
丿纸飞机巛
2018-08-09
>ymodem_on_data 里 ef_write_data_to_bak 就是拷贝接收到的数据到 flash 上的 --- 嗯,因为有例子,想着实现上传文件就好了,没有注意协议的实现方法,我好好研究一下你这个代码块吧,谢谢!
e_donkey
2019-01-17
有没有办法传文件到上位机?
hnhebing
2019-01-28
rtt+fal+easyflash+ymodem 有完整实例吗? 我用stm32f4 实现rtt+fal+easyflash 可以应用,但是在用到ymodem->rym_recv_on_device()时程序跑飞了!! 环境:env1.10 + rtt4.0
armink
2019-01-28
>rtt+fal+easyflash+ymodem 有完整实例吗? > >我用stm32f4 实现rtt+fal+easyflash 可以应用,但是在用到ymode ... --- 有的呀,你可以参考 IoT Board 里的 Ymodem OTA 例程,都是开源的
hnhebing
2019-02-01
在正点原子stm32f407gz ymodem ota已经正常读写,获取收获把bootloader移到flash高端 0x080c0000位置,最也不担心应用程序破坏bootloader了!
6.4k
丿纸飞机巛
进入bootloader的方式探讨
求助:IAP里的APP使用的RTT,跳转后出错。[已解决]
想做网口的IAP远程升级,不知可不可行
IAP问题
