Kernel
同优先级的多个线程,需要主动出让CPU
发布于 2018-08-17 16:39:53 浏览:1943
* 本帖最后由 wj2893155 于 2018-8-20 14:03 编辑 * 大家好,小弟新人 今天移植了RTT,但遇到了一个问题,如题。特来求教 我创建了3个线程,配置相同的优先级和时间片,每个线程内都是循环打印。 结果只有1个现成会打印,其他两个线程没有打印。 然后我在每个线程里加上rt_thread_yield,3个线程才能全部运行。如果必须这样,那时间片的概念有什么价值? 感谢 粘贴上代码: static void uart_thread_entry(void *param) { int i = 0; while (1) { printf("%d----%d
", (int)param, i++); //rt_thread_yield(); //rt_thread_sleep(1); } } static void uart_thread_entry2(void *param) { int i = 0; while (1) { printf("%d----%d
", (int)param, i++); //rt_thread_yield(); //rt_thread_sleep(1); } } static void uart_thread_entry3(void *param) { int i = 0; while (1) { printf("%d----%d
", (int)param, i++); //rt_thread_yield(); //rt_thread_sleep(1); } } static struct rt_thread uart_thread; static struct rt_thread uart_thread2; static struct rt_thread uart_thread3; static rt_uint8_t uart_stack[512]; static rt_uint8_t uart_stack2[512]; static rt_uint8_t uart_stack3[512]; static void application() { rt_err_t result; /* init uart thread */ //static struct rt_thread uart_thread; result = rt_thread_init(&uart_thread, "uart", uart_thread_entry, (void *)1, (rt_uint8_t*)&uart_stack[0], sizeof(uart_stack), 20,//0~32,32¸ß 5); if (result == RT_EOK) { //uart_test(NULL); rt_thread_startup(&uart_thread); } /* init uart thread */ //static struct rt_thread uart_thread2; result = rt_thread_init(&uart_thread2, "uart2", uart_thread_entry2, (void *)2, (rt_uint8_t*)&uart_stack2[0], sizeof(uart_stack), 20,//0~32,32¸ß 5); if (result == RT_EOK) { //uart_test(NULL); rt_thread_startup(&uart_thread2); } /* init uart thread */ result = rt_thread_init(&uart_thread3, "uart3", uart_thread_entry3, (void *)3, (rt_uint8_t*)&uart_stack3[0], sizeof(uart_stack), 20,//0~32,32¸ß 5); if (result == RT_EOK) { //uart_test(NULL); rt_thread_startup(&uart_thread3); } }
alee
2018-08-17
把你代码贴出来看看。我试过相同优先级线程,时间片轮询是可以的。下面是我实验用的示例。 #define THREAD_PRIORITY 25 #define THREAD_STACK_SIZE 512 #define THREAD_TIMESLICE 5 /* 指向线程控制块的指针 */ static rt_thread_t tid1 = RT_NULL; static rt_thread_t tid2 = RT_NULL; /* 线程 1 入口 */ static void thread1_entry(void* parameter) { rt_uint32_t count = 0; while (1) { /* 打印线程 1 的输出 */ rt_kprintf("thread1: count = %d\n", count ++); } } /* 线程 2 入口 */ static void thread2_entry(void* parameter) { rt_uint32_t count = 0; while (1) { /* 打印线程 2 的输出 */ rt_kprintf("thread2: count = %d\n", count ++); } } /* 线程让出处理器示例的初始化 */ int thread_yield_init(void) { /* 创建线程 1 */ tid1 = rt_thread_create("thread", thread1_entry, /* 线程入口是 thread1_entry */ RT_NULL, /* 入口参数是 RT_NULL */ THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); if (tid1 != RT_NULL) rt_thread_startup(tid1); /* 创建线程 2 */ tid2 = rt_thread_create("thread", thread2_entry, /* 线程入口是 thread2_entry */ RT_NULL, /* 入口参数是 RT_NULL */ THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE); if (tid2 != RT_NULL) rt_thread_startup(tid2); return 0; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(thread_yield_init, thread yield); 下面是打印信息: msh >thread1: count = 0 thread1: count = 1 thread1: thread2: count = 0 thread2: count = 1 thread2: count = 2count = 2 thread1: count = 3 thread1: count = 4 thread thread2: count = 3 thread2: count = 4 thread2: count =1: count = 5 thread1: count = 6 thread1: count = 7 thre 8 thread2: count = 6 thread2: count = 7 thread2: counad2: count = 8 thread1: count = 9 thread1: count = 10 tt = 11thread2: count = 9 thread2: count = 10
wj2893155
2018-08-17
static void uart_thread_entry(void *param) { int i = 0; while (1) { printf("%d----%d\r\n", (int)param, i++); //rt_thread_yield(); //rt_thread_sleep(1); } } static void uart_thread_entry2(void *param) { int i = 0; while (1) { printf("%d----%d\r\n", (int)param, i++); //rt_thread_yield(); //rt_thread_sleep(1); } } static void uart_thread_entry3(void *param) { int i = 0; while (1) { printf("%d----%d\r\n", (int)param, i++); //rt_thread_yield(); //rt_thread_sleep(1); } } static struct rt_thread uart_thread; static struct rt_thread uart_thread2; static struct rt_thread uart_thread3; static rt_uint8_t uart_stack[512]; static rt_uint8_t uart_stack2[512]; static rt_uint8_t uart_stack3[512]; static void application() { rt_err_t result; /* init uart thread */ //static struct rt_thread uart_thread; result = rt_thread_init(&uart_thread, "uart", uart_thread_entry, (void *)1, (rt_uint8_t*)&uart_stack[0], sizeof(uart_stack), 20,//0~32,32¸ß 5); if (result == RT_EOK) { //uart_test(NULL); rt_thread_startup(&uart_thread); } /* init uart thread */ //static struct rt_thread uart_thread2; result = rt_thread_init(&uart_thread2, "uart2", uart_thread_entry2, (void *)2, (rt_uint8_t*)&uart_stack2[0], sizeof(uart_stack), 20,//0~32,32¸ß 5); if (result == RT_EOK) { //uart_test(NULL); rt_thread_startup(&uart_thread2); } /* init uart thread */ result = rt_thread_init(&uart_thread3, "uart3", uart_thread_entry3, (void *)3, (rt_uint8_t*)&uart_stack3[0], sizeof(uart_stack), 20,//0~32,32¸ß 5); if (result == RT_EOK) { //uart_test(NULL); rt_thread_startup(&uart_thread3); } }
wj2893155
2018-08-17
>把你代码贴出来看看。我试过相同优先级线程,时间片轮询是可以的。下面是我实验用的示例。 > >#define THREAD ... --- 我在下面贴了代码,帮忙看一下 谢谢
123456
2019-12-10
你是导出到shell中执行吗?
翌雨芩风
2019-12-10
你的 RT_CONFIG.H 是否开启了使能 时间片啊??
1.9k
wj2893155
cpu使用率分析
选择FreeRTOS, 还是RT-Thread。
thread heap stack overflow ?
rtt消息队列delay问题
释放被删除线程的内存地方在哪里啊
请教:各线程结束后,释放其中的内存的连续性问题
STM32F103中断关于信号量、邮箱问题
RTT中的线程栈大小如何控制
关于线程由执行态变为挂起态的代码实现,,,
