网络学习营
[网络编程学习]+_xiangxi+第四周+以太网+接入阿里云
发布于 2018-08-25 20:48:48 浏览:1467
* 本帖最后由 _xiangxi 于 2018-8-25 20:47 编辑 * 本周的任务是本次学习的大综合,另外添加了以太网接入的部分。由于基础太差,耽误了太多时间。今天就贴出本周的作业内容,挑战部分明天贴出(没调通就先不贴了)。**第一部分,回顾前三周的内容。**在回顾时候,查阅群友发表的帖子,仿照帖子内容,添加了USAT3到ENV工具中。这个步骤主要分为两步:1.增加drv_usart.c的内容,添加USART3的驱动及中断函数。```void HAL_UART_MspInit(UART_HandleTypeDef *uartHandle) ... else if (uartHandle->Instance == USART3) { /* USART3 clock enable */ __HAL_RCC_USART3_CLK_ENABLE(); __HAL_RCC_GPIOB_CLK_ENABLE(); /**USART3 GPIO Configuration PB10 ------> USART3_TX PB11 ------> USART3_RX */ GPIO_InitStruct.Pin = GPIO_PIN_10 | GPIO_PIN_11; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_PULLUP; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_VERY_HIGH; GPIO_InitStruct.Alternate = GPIO_AF7_USART3; HAL_GPIO_Init(GPIOB, &GPIO_InitStruct); } ... }``````#if defined(RT_USING_UART3) /* UART3 device driver structure */ static struct drv_uart uart3; struct rt_serial_device serial3; void USART3_IRQHandler(void) { struct drv_uart *uart; uart = &uart3; /* enter interrupt */ rt_interrupt_enter(); /* UART in mode Receiver -------------------------------------------------*/ if ((__HAL_UART_GET_FLAG(&uart->UartHandle, UART_FLAG_RXNE) != RESET) && (__HAL_UART_GET_IT_SOURCE(&uart->UartHandle, UART_IT_RXNE) != RESET)) { rt_hw_serial_isr(&serial3, RT_SERIAL_EVENT_RX_IND); /* Clear RXNE interrupt flag */ __HAL_UART_CLEAR_FLAG(&uart->UartHandle, UART_FLAG_RXNE); } /* leave interrupt */ rt_interrupt_leave(); } #endif /* RT_USING_UART3 */``````int hw_usart_init(void) {```2.修改bsp/stm32f4xx-HAL/Kconfig文件```config RT_USING_UART2 bool "Using UART2" default n config RT_USING_UART3 bool "Using UART3" default n config RT_USING_UART6 bool "Using UART6" default n ```[align=center]**第二部分:以太网的连接及ping命令测试**由于我使用得是正点原子F407的板子,在板级驱动下不包含LAN8720A的驱动,不过,可以从stm32f429-apollo的相同位置拷贝drv_eth,c和drv_eth.h文件。由于在硬件电路上,不太一样,所以,我们需要根据F407的原理图对drv_eth.c进行修改。![QQ截图20180825192058.png](/uploads/201808/25/193552tbd8mgtzwyehe98m.png)![QQ截图20180825192426.png](/uploads/201808/25/193708xx1cpfkrgmmqjar3.png)![QQ截图20180825192543.png](/uploads/201808/25/193711enazaje6x2yza72e.png)其中ETH_RESET-------------------------> PCF8574扩展IO已经变成ETH_RESET------------------------->PD3因此这个地方,需要修改两处1.增添为```#define ETH_RMII_TXD1_PIN GPIO_PIN_14 #define ETH_RESET_PORN GPIOD #define ETH_RESET_PIN GPIO_PIN_3``` 2.修改phy_pin_reset(void)函数```static void phy_pin_reset(void) { GPIO_InitTypeDef GPIO_InitStructure; __HAL_RCC_GPIOD_CLK_ENABLE(); GPIO_InitStructure.Speed = GPIO_SPEED_HIGH; GPIO_InitStructure.Mode = GPIO_MODE_OUTPUT_PP; GPIO_InitStructure.Pull = GPIO_NOPULL; GPIO_InitStructure.Pin = ETH_RESET_PIN; HAL_GPIO_Init(ETH_RESET_PORN,&GPIO_InitStructure); HAL_GPIO_WritePin(ETH_RESET_PORN,ETH_RESET_PIN,GPIO_PIN_RESET); rt_thread_delay(RT_TICK_PER_SECOND/10); HAL_GPIO_WritePin(ETH_RESET_PORN,ETH_RESET_PIN,GPIO_PIN_SET); rt_thread_delay(RT_TICK_PER_SECOND/10); }``` 3.删除pcf8574的驱动。除此之外,我隐约记得还需要删除什么,如果将来移植报错,还可以再修改,这里有修改好的。![drv_eth.c](/uploads/201808/25/195457wlqleoslz3o5hdln.attach)![drv_eth.h](/uploads/201808/25/195503j4xgxzo7tro4o4g9.attach)4.修改drivers/的Sconscript文件。```if GetDepend('RT_USING_LWIP'): src += ['drv_eth.c']``` 5.在env工具配置界面![QQ截图20180825200610.png](/uploads/201808/25/200736j4q8aywt3kzcle7k.png)![QQ截图20180825200626.png](/uploads/201808/25/200740fs1sr5j1bz5dsjbv.png)![QQ截图20180825200636.png](/uploads/201808/25/200744s9pdkekhoqakk9zc.png)![QQ截图20180825200707.png](/uploads/201808/25/200748z41s14jf414f1otq.png)这个部分比较程式化,详细可以查阅[网络开发应用笔记](https://www.rt-thread.org/document/site/rtthread-application-note/components/network/an0011-rtthread-system-network-started/)截止到这个部分,以太网部分就可以可完成了,使用ifconfig命令和ping命令![QQ截图20180825201225.png](/uploads/201808/25/201257xv77v2z4fdqcqxva.png)使用weather命令![QQ截图20180825201242.png](/uploads/201808/25/201301hcsm4064s8u65fmv.png)**第三部分:连接阿里云部分**阿里云这个平台,和Onenet类似,需要我们先注册一个账号,开启物联网平台功能。然后创建应用,添加设备。![QQ截图20180825202410.png](/uploads/201808/25/202427vrocq6jjm6efoex5.png)这个就是完成后的样子。这个实验,有点不同,如果开启Onenet包就无法关闭[phao MQTT选项,如果不关闭,就会报错![QQ截图20180825202622.png](/uploads/201808/25/202752e77clnwnu9l9olwc.png)![QQ截图20180825202642.png](/uploads/201808/25/202756sggsp0zoq5o1mot5.png)![QQ截图20180825202702.png](/uploads/201808/25/202800rz0pt6hnl6o5opr5.png)这是报出的错误,当然,你也可以在生成工程里修改,嗯`~~~我改了好久,发现还是这样比较方便。![重复定义错误.png](/uploads/201808/25/203022fxcqhgqmtm2p72xd.png)在AliKit的配置界面,需要填入三个数据![QQ截图20180825203105.png](/uploads/201808/25/203146jgn28ki89niz1j12.png)分别代表阿里云设备信息界面的![QQ截图20180825203239.png](/uploads/201808/25/203346qmoxemdkxa04r0zr.png)这些都配置完成后,可以使用ali_mqtt_test start命令连接阿里云,嗯~~~如果报错,可能是网络错误,我:L把代码原封不动得重新烧录进去,竟然就可以了。 **第四部分:大综合时候出现的BUG**我开启了AT组件,配置了ESP8266又打开了LWIP功能,嗯~~~结果,不能正常联网。所以,在之后得测试里,就关闭了AT组件。浏览帖子时,听到有人提过AT组件联网和LWIP联网的优先级的问题,等以后我可以再试一下。还有就是上面说过的,IOT Cloud开启后,paho MQTT为默认打开的情况,在使用ENV工具时,也需要细心留意。总体来说,本次网络学习营的学习内容让我很受益,碰到的问题都是我之前没有接触过的,同时经过本次学习,也学会了很多知识,不过越发感觉到自己知识能力的不足,十分感谢能给我参加本次集训营的机会。马上就要开学了,接着暑假训练营的训练成果,可以更加深入得了解RT-Thread,也希望RT-Thead功能越来越强大。
1.5k
_xiangxi
47
【LWIP学习营】第一关开发环境搭建
LWIP学习营第一周入门移植问题汇总贴
【LWIP学习营】f407+lan8720A小结
【LwIP学习营】【第一周】仅零散记录,无主题
【LwIP学习营】【第一周】LWIP移植
【LwIP学习营】【第一周】开发板适配
【LwIP学习营】【第一周】环境搭建和配置验证
