RT-Thread学习营
【内核和外设学习营】十里 简单LED闪亮测试
发布于 2018-09-05 09:01:26 浏览:1804
* 本帖最后由 hyz_rtt 于 2018-9-6 19:42 编辑 * 这次实验作业用的野火霸天虎STM32F407ZGT6开发板,板子上外部时钟源HSE为25M。 (1)BSP下stm32f40x里STD库默认的是25M外部时钟源HSE, ![默认定义的HSE值.png](/uploads/201809/05/085613nb9fsffuafekz9fs.png) 但是又在stm32f4xx_config.h里重新定义 HSE_VALUE为8M,只需要把这个重新定义部分代码注释掉即可。 ![重新定义的HSE值.png](/uploads/201809/05/085503v935a2j53590mz3z.png) BSP下stm32f40x里STD库现在已经支持ENV配置了,但是很遗憾配置选项里还没有外部时钟源配置选项, 所以只能自己手动操作。通常时钟配置参数都在stm32f4xx.h和system_stm32f4xx.c里。其中system_stm32f4xx.c 还有如下的相关时钟设置参数的默认配置说明,如下所示 *============================================================================= * Supported STM32F4xx device revision | Rev A *----------------------------------------------------------------------------- * System Clock source | PLL (HSE) *----------------------------------------------------------------------------- * SYSCLK(Hz) | 168000000 *----------------------------------------------------------------------------- * HCLK(Hz) | 168000000 *----------------------------------------------------------------------------- * AHB Prescaler | 1 *----------------------------------------------------------------------------- * APB1 Prescaler | 4 *----------------------------------------------------------------------------- * APB2 Prescaler | 2 *----------------------------------------------------------------------------- * HSE Frequency(Hz) | 25000000 *----------------------------------------------------------------------------- * PLL_M | 25 *----------------------------------------------------------------------------- * PLL_N | 336 *----------------------------------------------------------------------------- * PLL_P | 2 *----------------------------------------------------------------------------- * PLL_Q | 7 *----------------------------------------------------------------------------- * PLLI2S_N | NA *----------------------------------------------------------------------------- * PLLI2S_R | NA *----------------------------------------------------------------------------- * I2S input clock | NA *----------------------------------------------------------------------------- * VDD(V) | 3.3 *----------------------------------------------------------------------------- * Main regulator output voltage | Scale1 mode *----------------------------------------------------------------------------- * Flash Latency(WS) | 5 *----------------------------------------------------------------------------- * Prefetch Buffer | OFF *----------------------------------------------------------------------------- * Instruction cache | ON *----------------------------------------------------------------------------- * Data cache | ON *----------------------------------------------------------------------------- * Require 48MHz for USB OTG FS, | Enabled * SDIO and RNG clock | *----------------------------------------------------------------------------- *============================================================================= (2)BSP下stm32f40xx_hal里HAL库,这个可以通过ENV直接配置HSE为25M,对于系统时钟F407建议设置168M, 不需要改动, ![HSE时钟源设置ENV.png](/uploads/201809/05/085740w720yrep1m37537p.png) 然后重新生成工程即可。 注意:务必确保硬件完好,我的霸天虎板子很久没有用了,一开始一直打不出logo,最后换了串口才发现使用的板子串口1应该是坏掉了。 下面是实验现象,分别是MSH命令输出和放在函数里循环执行的控制台输出 ![msh命令输出.png](/uploads/201809/05/085900ssmnn14nrntwkty4.png)![示例放入循环里时控制台输出.png](/uploads/201809/05/085909fwls4m2sqmsmszkq.png)
hyz_rtt
2018-09-05
[i=s] 本帖最后由 hyz_rtt 于 2018-9-6 19:42 编辑 [/i] 发帖完善 1、实验要求: 要求硬件上:至少有一路 GPIO, 能够用来接 LED 灯,有一路串口用来做 msh shell 终端 软件上:BSP 中已经实现如下驱动:串口驱动,PIN 驱动 2、准备工作: 硬件:野火霸天虎stm32407开发板 软件:rtt3.1.0 stm32f4xxhal、env0.7.1 3、示例代码 #include
#define LED_Green 19 void LED_Blink_Samplie(void) { rt_pin_mode(LED_Green,PIN_MODE_OUTPUT); rt_kprintf("LED_Green ON\r\n"); rt_pin_write(LED_Green,PIN_LOW); rt_thread_delay(50); rt_kprintf("LED_Green OFF\r\n"); rt_pin_write(LED_Green,PIN_HIGH); rt_thread_delay(50); } MSH_CMD_EXPORT(LED_Blink_Samplie, led pin test.); 4、实验步骤 env配置HSE为25M,选择需要的驱动,配置串口2为输出串口,选择使用finsh。 5、结果:见原帖 6、遇到的问题:时钟问题,STD库和HAL库的都在原帖里上图了。 7、解决方法:原帖里已有,STD库和HAL库的都有图片文字说明在哪里修改。
1.8k
hyz_rtt
38
stm32f407+lan8720 lwip2.0 作业提交
玩溜GD32303E-EVAL BSP系列(五)----设备连接网络
onenet应用连不上云端
【文件系统】晴天文件匹配
rtt semc sdram 基于操作系统怎么初始化驱动设备
RT-Thread移植笔记
RT-Thread内核移植+LoIIs+STM32F103C8+StdLib
EVN编译报错,求助大神
【内核和外设学习营】 十里 串口指令控制RGB灯点亮的颜色
【内核和外设学习营】 十里 PWM单色呼吸灯实验
