内核学习营
【内核学习营】+青春+三路带PWM输出功能的GPIO驱动呼吸灯
发布于 2018-09-11 19:07:56 浏览:2212
* 本帖最后由 青春JY 于 2018-9-12 15:31 编辑 * **实验要求:**使用野火或正点原子M3、M4或M7开发板PWM控制呼吸灯。 硬件上:至少有一路带PWM输出功能的GPIO,能够用来连接 LED 呼吸灯; 有一路串口用来做 msh shell 终端; 软件上:串口驱动; PIN 驱动; PWM 驱动。 **准备工作:** 根据硬件连接情况配置与 LED 灯连接的PIN号; -硬件准备:正点原子stm32f407探索者开发板; -软件准备:rtt3.1.0、stm32f4xx-HAL BSP、env0.7.1。 **实例代码:**```#include
#define PERIOD 512 #define CH_R 1 extern rt_err_t rt_pwm_enable(int channel); extern rt_err_t rt_pwm_set(int channel, rt_uint32_t period, rt_uint32_t pulse); /* LED亮度等级 PWM表,指数曲线 */ /*此表使用工程目录下的python脚本index_wave.py生成*/ uint16_t indexWave[] = { 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 6, 6, 7, 7, 8, 8, 9, 9, 10, 11, 12, 12, 13, 14, 15, 17, 18, 19, 20, 22, 23, 25, 27, 29, 31, 33, 36, 38, 41, 44, 47, 51, 54, 58, 63, 67, 72, 77, 83, 89, 95, 102, 110, 117, 126, 135, 145, 156, 167, 179, 192, 206, 221, 237, 254, 272, 292, 313, 336, 361, 387, 415, 445, 477, 512, 512, 477, 445, 415, 387, 361, 336, 313, 292, 272, 254, 237, 221, 206, 192, 179, 167, 156, 145, 135, 126, 117, 110, 102, 95, 89, 83, 77, 72, 67, 63, 58, 54, 51, 47, 44, 41, 38, 36, 33, 31, 29, 27, 25, 23, 22, 20, 19, 18, 17, 15, 14, 13, 12, 12, 11, 10, 9, 9, 8, 8, 7, 7, 6, 6, 5, 5, 5, 4, 4, 4, 4, 3, 3, 3, 3, 2, 2, 2, 2, 2, 2, 2, 2, 1, 1, 1, 1, 1, 1 }; /*计算PWM表有多少个元素*/ rt_uint16_t POINT_NUM = sizeof(indexWave)/sizeof(indexWave[0]); void rt_pwm_rgb_entry(void* parameter) { rt_uint16_t i = 0; /*使能各通道*/ rt_pwm_enable(CH_R); while(1) { rt_pwm_set(CH_R, PERIOD, indexWave*); if(i >= POINT_NUM-1) i = 0; else i++; /* 设置使得整个呼吸过程为3秒左右即可达到很好的效果 */ rt_thread_delay(3000/POINT_NUM); } } int rt_breathe_rgb_init() { rt_device_t pwm_dev; rt_thread_t tid; pwm_dev = rt_device_find("pwm"); if(NULL != pwm_dev) { tid = rt_thread_create("pwm_led", rt_pwm_rgb_entry, RT_NULL, 512, RT_THREAD_PRIORITY_MAX/3, 20); if (tid != RT_NULL) rt_thread_startup(tid); } return 0; } MSH_CMD_EXPORT(rt_breathe_rgb_init, rgb breathe by pwm.);``` **实验步骤:**使用ENV配置串口、PIN驱动,拷贝PWM驱动,串口1做msh shell 终端。然后添加rgb_pwm.c文件到工程,根据自己的板子修改相应代码编译无错后下载到开发板。 **结果:**通过向控制台发送rt_pwm_rgb_init命令运行程序,红灯会以由暗到明再由明到暗循环闪烁,串口一打印如下信息:![X49FHQ{IYJPC6X17$TV4E{C.png](/uploads/201809/11/190657ryhepmbq95ems27g.png) **遇到的问题:** 1、由于stm3210x工程中没有PWM驱动,不能直接进行实验,stm32f4xx-HAL中有PWM驱动,但跟示例代码不匹配。 2、logo打印不完全。 3、驱动中少了通道使能配置。 **解决方法:** 1、使用stm32f4xx-HAL库以及正点原子stm32f407探索者开发板做实验,从别的地方拷贝适合PWM驱动。但是由于正点原子stm32f407探索者开发板上只有一个灯是与TIM14的CH1相连,所以只做了一个灯的实验。 2、把PWM驱动中没有用到的通道配置去掉即可,原因不明,望大神解答。使用自动初始化的时候很容易卡死,一直没找到根本原因。 3、在原驱动通道配置中加入TIMx_CHxHandler.OCFastMode = TIM_OCFAST_ENABLE;即可。 下载附件 [drv_pwm.c](https://oss-club.rt-thread.org/uploads/201809/11/212612t1mlsyssu77tu7zl.attach)
2.2k
青春JY
【内核学习营】+王秀峰+led_rgb
