内核学习营
【内核学习营】+王秀峰+pwm_breathe
发布于 2018-09-12 00:30:41 浏览:1396
[tocm] ## 实验要求: ## 准备工作 ### 硬件准备: 正点原子Explore开发板,一颗三色LED,使用串口2 ### 软件准备 stm32f4xx-HAL BSP,env0.7.1、rtt3.1.0、scons **示例代码** ```c #include
#include "board.h" #define PERIOD 512 #define CH_R 1 #define CH_G 2 #define CH_B 3 extern rt_err_t rt_pwm_enable(int channel); extern rt_err_t rt_pwm_set(int channel, rt_uint32_t period, rt_uint32_t pulse); uint16_t indexWave[] = { 1, 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 2, 2, 2, 3, 3, 3, 3, 4, 4, 4, 4, 5, 5, 5, 6, 6, 7, 7, 8, 8, 9, 9, 10, 11, 12, 12, 13, 14, 15, 17, 18, 19, 20, 22, 23, 25, 27, 29, 31, 33, 36, 38, 41, 44, 47, 51, 54, 58, 63, 67, 72, 77, 83, 89, 95, 102, 110, 117, 126, 135, 145, 156, 167, 179, 192, 206, 221, 237, 254, 272, 292, 313, 336, 361, 387, 415, 445, 477, 512, 512, 477, 445, 415, 387, 361, 336, 313, 292, 272, 254, 237, 221, 206, 192, 179, 167, 156, 145, 135, 126, 117, 110, 102, 95, 89, 83, 77, 72, 67, 63, 58, 54, 51, 47, 44, 41, 38, 36, 33, 31, 29, 27, 25, 23, 22, 20, 19, 18, 17, 15, 14, 13, 12, 12, 11, 10, 9, 9, 8, 8, 7, 7, 6, 6, 5, 5, 5, 4, 4, 4, 4, 3, 3, 3, 3, 2, 2, 2, 2, 2, 2, 2, 2, 1, 1, 1, 1, 1, 1 }; /*计算PWM表有多少个元素*/ rt_uint16_t POINT_NUM = sizeof(indexWave)/sizeof(indexWave[0]); void rt_pwm_breathe_entry(void *parameter) { rt_uint16_t i = 0; /*使能各通道*/ rt_pwm_enable(CH_R); rt_pwm_enable(CH_G); rt_pwm_enable(CH_B); while(1) { rt_pwm_set(CH_R, PERIOD, indexWave*); rt_pwm_set(CH_G, PERIOD, indexWave*); rt_pwm_set(CH_B, PERIOD, indexWave*); if(i >= POINT_NUM-1) i = 0; else i++; /* 设置整个呼吸过程为3秒左右即可达到很好的效果 */ rt_thread_delay(300/POINT_NUM); } } int rt_breathe_init() { rt_device_t pwm_dev; rt_thread_t tid; pwm_dev = rt_device_find("pwm1"); if(NULL != pwm_dev) { tid = rt_thread_create("pwm_led", rt_pwm_breathe_entry, RT_NULL, 512, RT_THREAD_PRIORITY_MAX/3, 20); if (tid != RT_NULL) rt_thread_startup(tid); } return 0; } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(rt_breathe_init, rgb breathe by pwm.); ``` 实验步骤 在env中打开PWM1,打开rtconfig.h文件添加宏 ```c #define BSP_USING_PWM1_CH1 #define BSP_USING_PWM1_CH2 #define BSP_USING_PWM1_CH3 #define BSP_USING_PWM1_CH4 ``` 查找drv_pwm文件,确定通道对应的引脚 ![1.png](/uploads/201809/12/002206ovocsd36qck3gxhi.png) ## 结果 编译运行,在`msh shell` 终端中输入`rt_breathe_init`,实际上三颗灯是全亮的,拍摄效果不太好。 ![2.gif](/uploads/201809/12/002216hn9nl99sdx2v1p1o.gif) ### 遇到的问题及解决方法 在第一次尝试的时候打开了PWM1,PWM2,PWM3,结果运行的的时候串口无法输入,检查发现使用的串口2和PWM2通道3冲突,关闭PWM2、3后第二次尝试还是没有结果, 查看程序打开PWM设备失败,因为PWM1注册的时候使用的是"pwm1",修改之后依旧不行,手动添加宏之后达到实验效果。 ```c #define BSP_USING_PWM1_CH1 #define BSP_USING_PWM1_CH2 #define BSP_USING_PWM1_CH3 #define BSP_USING_PWM1_CH4 ```
王秀峰
2018-09-12
补充:实际上代码中使能的是234通道
1.4k
王秀峰
26
【内核学习营】+王秀峰+led_rgb
NXP MCXN947测评之 adc
