内核学习营
alarm
【内核学习营】+王秀峰+rtc_alarm
发布于 2018-09-13 00:33:23 浏览:3411
[tocm] ## 实验要求: ## 准备工作 ### - 硬件准备: 正点原子Explore开发板,使用串口2、蜂鸣器、LED ### - 软件准备 stm32f4xx-HAL BSP,env0.7.1、rtt3.1.0、scons ## 示例代码 ```c #include
#define KEY1 2 #define BEEP 20 #define LED 21 #define BEEP_ON(x) rt_pin_write(x ,1) #define BEEP_OFF(x) rt_pin_write(x ,0) #define LED_ON(x) rt_pin_write(x ,0) #define LED_OFF(x) rt_pin_write(x ,1) #define ALARM_NUM_MAX 10 struct rt_alarm *ALARM[ALARM_NUM_MAX]; void alarm_callback_entry(rt_alarm_t alarm, time_t timestamp) { /* 打开蜂鸣器 */ BEEP_ON(BEEP); LED_ON(LED); rt_kprintf("Time out!
"); } void alarm_test_entry(void* parameter) { rt_uint32_t hour, minute, second; while(1) { if(rt_pin_read(KEY1)==0) { BEEP_OFF(BEEP); LED_OFF(LED); } get_time(&hour,&minute,&second); if((second%5) == 0) { rt_kprintf("%d,%d,%d
",hour,minute,second); } rt_thread_delay(20); } } int alarm_init(void) { rt_thread_t tid; /* 初始化按键输入 */ rt_pin_mode(KEY1, PIN_MODE_INPUT); /* 将蜂鸣器控制脚设置为输出模式 */ rt_pin_mode(BEEP, PIN_MODE_OUTPUT); rt_pin_mode(LED, PIN_MODE_OUTPUT); /* 蜂鸣器默认不响 */ BEEP_OFF(BEEP); LED_OFF(LED); rt_memset(&ALARM, NULL, sizeof(ALARM)); tid = rt_thread_create("alarm_test", alarm_test_entry, RT_NULL, 512, RT_THREAD_PRIORITY_MAX/3, 20); if (tid != RT_NULL) rt_thread_startup(tid); set_date(2018,9,12); set_time(21,33,40); /* 初始化闹钟服务 */ rt_alarm_system_init(); return 0; } INIT_APP_EXPORT(alarm_init); void alarm_add(int argc, char **argv) { struct rt_alarm_setup _alarm; if(argc > 1) { _alarm.flag = RT_ALARM_ONESHOT; /* 单次定时 */ rt_memset(&_alarm.wktime, RT_ALARM_TM_NOW, sizeof(struct tm)); _alarm.wktime.tm_hour = atol(argv[1]); if(argc > 2) { _alarm.wktime.tm_min = atol(argv[2]); _alarm.wktime.tm_sec = 0; } if(ALARM[0] == NULL) { ALARM[0] = rt_alarm_create(alarm_callback_entry, &_alarm); } else { rt_alarm_control(ALARM[0], RT_ALARM_CTRL_MODIFY, &_alarm); } rt_alarm_start(ALARM[0]); } } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(alarm_add, e.g: alarm_add 12 15); /* 12时15分 */ ``` ## 实验步骤 ### 手动添加宏 ```c #define RT_USING_RTC #define RT_USING_ALARM ``` 执行`scons --target=mdk5`重新构建工程 ### 设置RTC时间 ### 编译下载执行 在msh shell中输入alarm_add 21 34添加闹钟,等待闹钟执行** ## 结果 ![1.png](/uploads/201809/13/002958ngc65q2pcpva1pp5.png) ## 遇到的问题及解决方法 实验的过程中alarm成功设置,但是一直没有触发alarm中断,看了一下论坛中挂出来的drv_rtc.c文件,发现跟自己使用的版本不太一样,替换之后成功运行,我这里就不吐槽了。 ## 下载附件 - [drv_rtc.c](/uploads/201809/13/003224ybeqfof2a6f5qff9.attach) - [drv_rtc.h](/uploads/201809/13/003301oi3311ipososlfih.attach)
znmcu123
2019-11-15
没有触发alarm中断,是因为你落了一句话 ```c _alarm.hw_alarm = 1; ``` ===================================== 然后,我想问题一下alarm,支不支持周期性的闹钟,interval,貌似没有什么用
小菜鸟爱吃菜
2020-01-07
这个是f429的吗
王秀峰
2020-01-07
>这个是f429的吗 是的
王秀峰
2020-01-07
>没有触发alarm中断,是因为你落了一句话 谢谢提醒
小菜鸟爱吃菜
2020-01-08
>是的 为啥我原样不动竟然都定不触发不了闹钟
sANT
2020-05-06
>为啥我原样不动竟然都定不触发不了闹钟 我也触发不了,你的找到问题了吗?
mii
2020-08-04
楼主的drv_rtc.c文件下载不了了,能不能提供新的下载方式
2022-06-08
嵌入式
3.4k
王秀峰
26
RTC驱动框架几点建议
[新人试水] LPC1768 Nano3_9 添加RTC
STM32 关于RTC的问题
stm32f4xx-HAL BSP的RTC设置不对
关于STM32的RTC设置年份不正确的问题
RTT的RTC驱动调试
rtc驱动中的bkp模块起不到防止时间的重新设置
rtc时钟跑十几个小时后,比实际时间快几秒怎么解决
stm32如何断电之后开发板rtc时间继续往前跑
FRDM-MCXN94 7Flash实践--W25Q64
