网络学习营
7天rtos网络编程 day1-2 作业2
发布于 2018-10-16 01:38:51 浏览:1447
* 本帖最后由 wo4fisher 于 2018-10-16 15:22 编辑 * 要求:打开文件1.txt 文件内容为"123456789",修改为"abc456789" 思路:在源例子的基础上进行代码修改,文件路径:rt-thread\bsp\qemu-vexpress-a9\packages\filesystem_samples-latest,里边任意一个sample基础上进行修改。 创建文件,写制定内容"123456789",关闭;打开文件,读出内容,保存到缓存,关闭文件;修改缓存内容"abc456789";打开文件,写入新内容,关闭文件。在终端上用相应的命令显示文件及目录内容。 步骤:同上; ```#include
/* 当需要使用文件操作时,需要包含这个头文件 */ #define TEST_FN "/test.txt" /* 测试用的数据和缓冲 */ static char test_data[]="123456789",buffer[100]; static void mkdir_sample(void) { int fd; int index, length; /* 只写 & 创建 打开 */ fd = open(TEST_FN, O_WRONLY | O_CREAT | O_TRUNC, 0); rt_kprintf("open
"); if (fd >= 0) { /* 写入初始数据 */ length = write(fd, test_data, sizeof(test_data)); /* 关闭文件 */ close(fd); rt_kprintf("close
"); } else { rt_kprintf("open file for write failed
"); return; } /* 写读打开进行数据读取 */ fd = open(TEST_FN, O_RDONLY, 0); rt_kprintf("open REONLY
"); if (fd < 0) { rt_kprintf("check: open file for read failed
"); return; } /* 读取数据(应该为第一次写入的数据) */ length = read(fd, buffer, sizeof(buffer)); rt_kprintf("second read length=%d
",length); /* if (length != sizeof(test_data)) { rt_kprintf("check: read file failed
"); close(fd); return; } */ close(fd); rt_kprintf("%s
",buffer); /* 修改123为abc */ for (index = 0; index < 3; index ++) { buffer[index]='a'+index; } rt_kprintf("%s
",buffer); /* 第二次写数据*/ fd = open(TEST_FN, O_WRONLY, 0); rt_kprintf("open
"); length = write(fd, buffer, length); rt_kprintf("second write end
"); /* if (length != sizeof(buffer)) { rt_kprintf("check: read file failed
"); close(fd); return; } */ /* 检查数据完毕,关闭文件 */ close(fd); /* 打印结果 */ rt_kprintf("read/write done.
"); } /* 导出到 msh 命令列表中 */ MSH_CMD_EXPORT(mkdir_sample, mkdir sample);```结果: ``` \ | / - RT - Thread Operating System / | \ 3.1.0 build Oct 16 2018 2006 - 2018 Copyright by rt-thread team lwIP-2.0.2 initialized! [I/SAL_SOC] Socket Abstraction Layer initialize success. SD card capacity 65280 KB switching card to high speed failed probe mmcsd block device! found part[0], begin: 32256, size: 63.988MB file system initialization done! hello rt-thread msh />
ls
Directory /: 17107.png 1035935 2018-09-30_125320.png278913 text1.txt 12 test.txt 10 dir_test
msh />
cat test.txt
abc456789msh />
rm test.txt
msh />
ls
Directory /: 17107.png 1035935 2018-09-30_125320.png278913 text1.txt 12 dir_test
msh />
mkdir_sample
open close open REONLY second read length=10 123456789 abc456789 open second write end read/write done. msh />
cat test.txt
abc456789msh />```![2018-10-16_151846.png](/uploads/201810/16/152244xtc2aaczkad9tvov.png)
flyboy
2018-10-16
Do my self();
完成的很快啊,就是结果看着有点乱,如果贴一个图片,并加一些文字标注就更好了
wo4fisher
2018-10-16
>完成的很快啊,就是结果看着有点乱,如果贴一个图片,并加一些文字标注就更好了 ... --- 从接过里边找命令,找出命令后,看命令后边的输出结果就看出来了。:)
1.4k
wo4fisher
【LWIP学习营】第一关开发环境搭建
LWIP学习营第一周入门移植问题汇总贴
【LWIP学习营】f407+lan8720A小结
【LwIP学习营】【第一周】仅零散记录,无主题
【LwIP学习营】【第一周】LWIP移植
【LwIP学习营】【第一周】开发板适配
【LwIP学习营】【第一周】环境搭建和配置验证
