rtc时钟跑十几个小时后,比实际时间快几秒怎么解决
发布于 2018-10-19 11:32:50 浏览:2787
* 本帖最后由 luzixing 于 2018-10-19 11:34 编辑 * 下面是驱动的代码 #include "drv_rtc.h" #include
RTC_HandleTypeDef hrtc; /* RTC init function */ void MX_RTC_Init(void) { RTC_TimeTypeDef sTime; RTC_DateTypeDef sDate; __HAL_RCC_PWR_CLK_ENABLE();//??????PWR HAL_PWR_EnableBkUpAccess();//????????? /**Initialize RTC Only*/ hrtc.Instance = RTC; hrtc.Init.HourFormat = RTC_HOURFORMAT_24; hrtc.Init.AsynchPrediv = 127; hrtc.Init.SynchPrediv = 256; hrtc.Init.OutPut = RTC_OUTPUT_DISABLE; hrtc.Init.OutPutPolarity = RTC_OUTPUT_POLARITY_HIGH; hrtc.Init.OutPutType = RTC_OUTPUT_TYPE_OPENDRAIN; RT_ASSERT(HAL_RTC_Init(&hrtc) == HAL_OK); /**Initialize RTC and set the Time and Date */ if (HAL_RTCEx_BKUPRead(&hrtc, RTC_BKP_DR0) != 0x33F2) { RCC_OscInitTypeDef RCC_OscInitStruct; RCC_PeriphCLKInitTypeDef PeriphClkInitStruct; RCC_OscInitStruct.OscillatorType=RCC_OSCILLATORTYPE_LSE;//LSE?? RCC_OscInitStruct.PLL.PLLState=RCC_PLL_NONE; RCC_OscInitStruct.LSEState=RCC_LSE_ON; //RTC??LSE HAL_RCC_OscConfig(&RCC_OscInitStruct); PeriphClkInitStruct.PeriphClockSelection=RCC_PERIPHCLK_RTC;//???RTC PeriphClkInitStruct.RTCClockSelection=RCC_RTCCLKSOURCE_LSE;//RTC????LSE HAL_RCCEx_PeriphCLKConfig(&PeriphClkInitStruct); RT_ASSERT(HAL_RTC_Init(&hrtc) == HAL_OK); sTime.Hours = 18; sTime.Minutes = 14; sTime.Seconds = 59; sTime.DayLightSaving = RTC_DAYLIGHTSAVING_NONE; sTime.StoreOperation = RTC_STOREOPERATION_RESET; RT_ASSERT(HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BIN) == HAL_OK); sDate.WeekDay = RTC_WEEKDAY_THURSDAY; sDate.Month = RTC_MONTH_OCTOBER; sDate.Date = 18; sDate.Year = 18; RT_ASSERT(HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BIN) == HAL_OK); HAL_RTCEx_BKUPWrite(&hrtc, RTC_BKP_DR0, 0x33F2); } } void HAL_RTC_MspInit(RTC_HandleTypeDef *rtcHandle) { if (rtcHandle->Instance == RTC) { /* USER CODE BEGIN RTC_MspInit 0 */ /* USER CODE END RTC_MspInit 0 */ /* RTC clock enable */ __HAL_RCC_RTC_ENABLE(); /* USER CODE BEGIN RTC_MspInit 1 */ /* USER CODE END RTC_MspInit 1 */ } } void HAL_RTC_MspDeInit(RTC_HandleTypeDef *rtcHandle) { if (rtcHandle->Instance == RTC) { /* USER CODE BEGIN RTC_MspDeInit 0 */ /* USER CODE END RTC_MspDeInit 0 */ /* Peripheral clock disable */ __HAL_RCC_RTC_DISABLE(); /* USER CODE BEGIN RTC_MspDeInit 1 */ /* USER CODE END RTC_MspDeInit 1 */ } } static rt_err_t stm32_rtc_control(struct rt_device *dev, int cmd, void *args) { struct tm *tm_now; struct tm now; RTC_TimeTypeDef sTime; RTC_DateTypeDef sDate; rt_enter_critical(); /* converts calendar time time into local time. */ tm_now = localtime((const time_t *) args); /* copy the statically located variable */ memcpy(&now, tm_now, sizeof(struct tm)); /* unlock scheduler. */ rt_exit_critical(); switch (cmd) { case RT_DEVICE_CTRL_RTC_GET_TIME: HAL_RTC_GetTime(&hrtc, &sTime, RTC_FORMAT_BIN); HAL_RTC_GetDate(&hrtc, &sDate, RTC_FORMAT_BIN); now.tm_hour = sTime.Hours; now.tm_min = sTime.Minutes; now.tm_sec = sTime.Seconds; now.tm_year = sDate.Year + 100; now.tm_mon = sDate.Month - 1; now.tm_mday = sDate.Date; *((time_t *)args) = mktime(&now); break; case RT_DEVICE_CTRL_RTC_SET_TIME: sTime.Hours = now.tm_hour; sTime.Minutes = now.tm_min; sTime.Seconds = now.tm_sec; sDate.Year = now.tm_year - 100; sDate.Month = now.tm_mon + 1; sDate.Date = now.tm_mday; HAL_RTC_SetTime(&hrtc, &sTime, RTC_FORMAT_BIN); HAL_RTC_SetDate(&hrtc, &sDate, RTC_FORMAT_BIN); break; } return RT_EOK; } static rt_err_t stm32_rtc_init(struct rt_device *dev) { return RT_EOK; } static rt_err_t stm32_rtc_open(struct rt_device *dev, rt_uint16_t oflag) { return RT_EOK; } static rt_err_t stm32_rtc_close(struct rt_device *dev) { return RT_EOK; } static rt_size_t stm32_rtc_read(struct rt_device *dev, rt_off_t pos, void *buffer, rt_size_t size) { stm32_rtc_control(dev, RT_DEVICE_CTRL_RTC_GET_TIME, buffer); return size; } static rt_size_t stm32_rtc_write(struct rt_device *dev, rt_off_t pos, const void *buffer, rt_size_t size) { stm32_rtc_control(dev, RT_DEVICE_CTRL_RTC_SET_TIME, (void *)buffer); return size; } struct rt_device rtc_device; int rt_hw_rtc_init(void) { MX_RTC_Init(); rtc_device.type = RT_Device_Class_RTC; rtc_device.rx_indicate = RT_NULL; rtc_device.tx_complete = RT_NULL; rtc_device.init = stm32_rtc_init; rtc_device.open = stm32_rtc_open; rtc_device.close = stm32_rtc_close; rtc_device.read = stm32_rtc_read; rtc_device.write = stm32_rtc_write; rtc_device.control = stm32_rtc_control; rtc_device.user_data = RT_NULL; rt_kprintf("You can also use date command to set your time and date!
"); /* register a character device */ return rt_device_register(&rtc_device, "rtc", RT_DEVICE_FLAG_DEACTIVATE); } INIT_BOARD_EXPORT(rt_hw_rtc_init);
2.8k
luzixing
21
RTC驱动框架几点建议
[新人试水] LPC1768 Nano3_9 添加RTC
STM32 关于RTC的问题
stm32f4xx-HAL BSP的RTC设置不对
关于STM32的RTC设置年份不正确的问题
RTT的RTC驱动调试
rtc驱动中的bkp模块起不到防止时间的重新设置
stm32如何断电之后开发板rtc时间继续往前跑
为什么rtc驱动中使用晶振,bkp模块的寄存器0,防止重新设...
