网络学习营
【7天入门RTOS网络编程】Young day3-5 作业
发布于 2018-10-25 19:24:09 浏览:1246
* 本帖最后由 爱喝柠檬水 于 2018-10-25 21:10 编辑 * 学习了其他同学的方法使用MSH_CMD_EXPORT()函数将命令函数输出到msh列表便于操作 代码部分 ```#include
#define BUFSZ 1024 /* 指向线程控制块的指针 */ static rt_thread_t tid1 = RT_NULL; static int sock = 0; char *recv_data; static char send_data[100]; int ret; /* tcpClient thread entry*/ static void thread_tcpClient_entry(void* parameter) { int bytes_received; /* 分配用于存放接收数据的缓冲 */ recv_data = rt_malloc(BUFSZ); if (recv_data == RT_NULL) { rt_kprintf("No memory
"); return; } while(1) { /* 从sock连接中接收最大BUFSZ - 1字节数据 */ bytes_received = recv(sock, recv_data, BUFSZ - 1, 0); if (bytes_received < 0) { /* 接收失败,关闭这个连接 */ closesocket(sock); rt_kprintf("
"); /* 释放接收缓冲 */ rt_free(recv_data); rt_thread_delete(tid1); } else if (bytes_received == 0) { /* 打印recv函数返回值为0的警告信息 */ closesocket(sock); rt_kprintf("
"); /* 释放接收缓冲 */ rt_free(recv_data); rt_thread_delete(tid1); } /* 有接收到数据,把末端清零 */ recv_data[bytes_received] = '\0'; /* 在控制终端显示收到的数据 */ rt_kprintf("
%s",recv_data); } } /* 聊天客户端初始化:新建socket,成功建立连接,并发出初始帧信息,创建接收线程 */ static int tcpClient_Start(void) { struct hostent *host; struct sockaddr_in server_addr; const char *url; int port; url = "183.193.243.90"; port =5000; /* 通过函数入口参数url获得host地址(如果是域名,会做域名解析) */ host = gethostbyname(url); /* 分配用于存放接收数据的缓冲 */ recv_data = rt_malloc(BUFSZ); if (recv_data == RT_NULL) { rt_kprintf("No memory
"); return 0; } /* 创建一个socket,类型是SOCKET_STREAM,TCP类型 */ if ((sock = socket(AF_INET, SOCK_STREAM, 0)) == -1) { /* 创建socket失败 */ rt_kprintf("Socket error
"); /* 释放接收缓冲 */ rt_free(recv_data); return 0; } /* 初始化预连接的服务端地址 */ server_addr.sin_family = AF_INET; server_addr.sin_port = htons(port); server_addr.sin_addr = *((struct in_addr *)host->h_addr); rt_memset(&(server_addr.sin_zero), 0, sizeof(server_addr.sin_zero)); /* 连接到服务端 */ if (connect(sock, (struct sockaddr *)&server_addr, sizeof(struct sockaddr)) == -1) { /* 连接失败 */ rt_kprintf("Connect fail!
"); closesocket(sock); /*释放接收缓冲 */ rt_free(recv_data); return 0; } else { rt_kprintf("Connect success!
"); } /* 创建线程1 */ tid1 = rt_thread_create("tcpClient", thread_tcpClient_entry, (void*)1, /* 线程入口是thread_entry, 入口参数是1 */ 1024, 20, 5); //THREAD_STACK_SIZE, THREAD_PRIORITY, THREAD_TIMESLICE if (tid1 != RT_NULL){ rt_kprintf("tcpclient thread init ok,connect tcp server success
"); rt_thread_startup(tid1); } else return -1; return 0; } void login(int argc, char **argv) { if(argv[1]==RT_NULL) { rt_kprintf("Please log in
Use \"login
"); return; } sprintf(send_data, "login %s
", argv[1]); /* 发送数据到sock连接 */ ret = send(sock, send_data, strlen(send_data), 0); if (ret < 0) { //* 接收失败,关闭这个连接 closesocket(sock); rt_kprintf("
send error,close the socket.
"); rt_free(recv_data); return; } else if (ret == 0) { //* 打印send函数返回值为0的警告信息 rt_kprintf("
"); rt_free(recv_data); return; } } void say(int argc, char **argv) { sprintf(send_data, "say%s
"); } } void look(void) { sprintf(send_data, "look
"); /* 发送数据到sock连接 */ ret = send(sock, send_data, strlen(send_data), 0); if (ret < 0) { //* 接收失败,关闭这个连接 closesocket(sock); rt_kprintf("
"); } } void who(void) { sprintf(send_data, "who
"); } } /* logout server 断开连接 */ void logout(void) { sprintf(send_data, "logout
"); } rt_thread_delete(tid1); closesocket(sock); } MSH_CMD_EXPORT(tcpClient_Start, Start Tcp Client ); MSH_CMD_EXPORT(login, a tcp client login); MSH_CMD_EXPORT(say, a tcp client say); MSH_CMD_EXPORT(look, a tcp client look); MSH_CMD_EXPORT(who, a tcp client who); MSH_CMD_EXPORT(logout, a tcp client logout); ``` ![1png.png](/uploads/201810/25/192146o2in8ano92n288h2.png)![2.png](/uploads/201810/25/192150shu9gwk35w59su19.png) 最后发现几个问题, 1、未使用logout 命令退出会让上一个login的用户也在聊天室,不知道用什么方法注销它。 2、say 命令 发送的字符串遇到空格 服务器不会发送回来空格后面的单词。 以上问题还需认真解决! say命令问题解决:修改say 命令函数如下 ```void say(int argc, char **argv) { strcpy(send_data,"say "); for(int i=1;i
"); //sprintf(send_data, "say %s
", argv[1]);
//原使用sprintf()只能写入argv[1]中字符串,使用strcpy()和strcat()即可解决。
"); } }```各位还有更好的方法也请分享
1.2k
爱喝柠檬水
【LWIP学习营】第一关开发环境搭建
LWIP学习营第一周入门移植问题汇总贴
【LWIP学习营】f407+lan8720A小结
【LwIP学习营】【第一周】仅零散记录,无主题
【LwIP学习营】【第一周】LWIP移植
【LwIP学习营】【第一周】开发板适配
【LwIP学习营】【第一周】环境搭建和配置验证
