在SConscript文件中如何添加链接lib文件?
发布于 2018-11-30 16:32:46 浏览:1680
[tocm] ```python from building import * # get current directory cwd = GetCurrentDir() # The set of source files associated with this SConscript file. src = Glob('src/*.c') path = [cwd + '/inc'] #1、如何添加 test.lib 文件。 #2、如何在DefineGroup的最后一个参数里增加多个参数?比如我想同时有CPPPATH和LINKFLAGS group = DefineGroup('Filesystem', src, depend = ['RT_USING_DFS'], CPPPATH = path) Return('group') ```
liu2guang
2018-11-30
给你个例子,里面应有尽有 ``` #-*- encoding: utf-8 -*- #--------------------------------------------------------------------------------- # @File: Sconscript for package # @Author: liu2guang # @Date: 2018-09-19 18:07:00(v0.1.0) # # @LICENSE: GPLv3: https://github.com/rtpkgs/buildpkg/blob/master/LICENSE. # #--------------------------------------------------------------------------------- import os from building import * Import('RTT_ROOT') Import('rtconfig') #--------------------------------------------------------------------------------- # Package configuration #--------------------------------------------------------------------------------- PKGNAME = "libstm32hal" VERSION = "v0.1.0" DEPENDS = ["PKG_USING_LIBSTM32HAL"] #--------------------------------------------------------------------------------- # Compile the configuration # # SOURCES: Need to compile c and c++ source, auto search when SOURCES is empty # # LOCAL_CPPPATH: Local file path (.h/.c/.cpp) # LOCAL_CCFLAGS: Local compilation parameter # LOCAL_ASFLAGS: Local assembly parameters # # CPPPATH: Global file path (.h/.c/.cpp), auto search when LOCAL_CPPPATH/CPPPATH # is empty # no pass!!! # CCFLAGS: Global compilation parameter # ASFLAGS: Global assembly parameters # # CPPDEFINES: Global macro definition # LOCAL_CPPDEFINES: Local macro definition # # LIBS: Specify the static library that need to be linked # LIBPATH: Specify the search directory for the library file (.lib/.a) # # LINKFLAGS: Link options #--------------------------------------------------------------------------------- SOURCES = [] LOCAL_CPPPATH = [] LOCAL_CCFLAGS = "" LOCAL_ASFLAGS = "" CPPPATH = [] CCFLAGS = "" ASFLAGS = "" CPPDEFINES = [] LOCAL_CPPDEFINES = [] LIBS = [] LIBPATH = [] LINKFLAGS = "" #--------------------------------------------------------------------------------- # Feature clip configuration, optional #--------------------------------------------------------------------------------- #--------------------------------------------------------------------------------- # Compiler platform configuration, optional #--------------------------------------------------------------------------------- if GetDepend("LIBSTM32HAL_USING_STATIC_LIB") == True: if rtconfig.CROSS_TOOL == "keil" and GetDepend(['SOC_STM32F469NI']) == True: LIBS += ["libstm32hal_f469_armcc"] LIBPATH += [GetCurrentDir() + "/libstm32hal/libstm32hal_f469_armcc"] CPPPATH += [GetCurrentDir() + "/libstm32hal/libstm32hal_f469_armcc"] else: print("not support cross tool or soc!") else: SOURCES += Glob('libstm32hal/libstm32hal_f4xx/*.c') CPPPATH += [GetCurrentDir() + "/libstm32hal/libstm32hal_f4xx"] #--------------------------------------------------------------------------------- # Warning: internal related processing, developers do not modify!!! #--------------------------------------------------------------------------------- #--------------------------------------------------------------------------------- # System variables #--------------------------------------------------------------------------------- objs = [] root = GetCurrentDir() #--------------------------------------------------------------------------------- # Sub target #--------------------------------------------------------------------------------- list = os.listdir(root) if GetDepend(DEPENDS): for d in list: path = os.path.join(root, d) if os.path.isfile(os.path.join(path, 'SConscript')): objs = objs + SConscript(os.path.join(d, 'SConscript')) #--------------------------------------------------------------------------------- # Main target #--------------------------------------------------------------------------------- objs = DefineGroup(name = PKGNAME + '-' + VERSION, src = SOURCES, depend = DEPENDS, CPPPATH = CPPPATH, CCFLAGS = CCFLAGS, ASFLAGS = ASFLAGS, LOCAL_CPPPATH = LOCAL_CPPPATH, LOCAL_CCFLAGS = LOCAL_CCFLAGS, LOCAL_ASFLAGS = LOCAL_ASFLAGS, CPPDEFINES = CPPDEFINES, LOCAL_CPPDEFINES = LOCAL_CPPDEFINES, LIBS = LIBS, LIBPATH = LIBPATH, LINKFLAGS = LINKFLAGS) Return("objs") #--------------------------------------------------------------------------------- # End #--------------------------------------------------------------------------------- ```
flyboy
2018-11-30
Do my self();
mark
1.7k
adg7660
用scons构建代码出现问题
求助用scons生成不了mdk工程
关于使用scons编译的问题
关于scons 编译CPP问题求教
scons编译出现警告信息
SCons生成MDK5工程出错
realtouch的scons问题
SCons的PreAction能用吗?
scons 编译时出错。
求教:关于scons构建rtt时的两个问题
