RT-Thread English
RT-Gui : a simple example
发布于 2011-01-18 03:57:55 浏览:8123
Hi all, I'm using stm32 radio project to understand RT-GUI by examples. I'm not able to implement a simple view with one button and one label. When I press the button I need to change the label. I don' understand how link the button to the handler. I use rtgui_button_set_onbutton(apply_button, apply_handler) but is not enough. Last thing : the button pressed image is different from button not pressed image or I have to create manually? Thanks Marco
Steva
2011-01-18
Found it, only problems with touch calibration. static void apply_handler(struct rtgui_widget* widget, rtgui_event_t* event) { rt_uint32_t vol, bri; bri = 0; } void workbench_panel1(void* parameter) { rt_mq_t mq; rtgui_view_t* view; rtgui_label_t* label; struct rtgui_button* apply_button; struct rtgui_workbench* workbench; rtgui_rect_t rect; mq = rt_mq_create("wmq", 256, 8, RT_IPC_FLAG_FIFO); /* ×??á?±?°??????GUI???? */ rtgui_thread_register(rt_thread_self(), mq); /* ???¨?????¤×÷?¨ */ workbench = rtgui_workbench_create("main", "workbench #1"); rtgui_widget_set_event_handler(RTGUI_WIDGET(workbench), rtgui_workbench_event_handler); if (workbench == RT_NULL) return; view = rtgui_view_create("view"); if (view == RT_NULL) return; /* ???¨??????±??°?? */ RTGUI_WIDGET_BACKGROUND(RTGUI_WIDGET(view)) = light_grey; /* ?í??????label */ label = rtgui_label_create("RT-Thread"); rect.x1 = 10; rect.y1 = 10; rect.x2 = 210; rect.y2 = 30; /* ?è??label?????? */ rtgui_widget_set_rect(RTGUI_WIDGET(label), &rect); rtgui_container_add_child(RTGUI_CONTAINER(view), RTGUI_WIDGET(label)); rect.x1 = 50; rect.y1 = 50; rect.x2 = 210; rect.y2 = 90; apply_button = rtgui_button_create("Hello"); RTGUI_WIDGET_FOREGROUND(RTGUI_WIDGET(apply_button)) = blue; rtgui_widget_set_rect(RTGUI_WIDGET(apply_button), &rect); rtgui_button_set_onbutton(apply_button, apply_handler); rtgui_container_add_child(RTGUI_CONTAINER(view), RTGUI_WIDGET(apply_button)); /* ?í??????workbench?? */ rtgui_workbench_add_view(workbench, view); /* ·?????·??????????? */ rtgui_view_show(view, RT_FALSE); /* ?????¤×÷?¨???????· */ rtgui_workbench_event_loop(workbench); /* ??×??áGUI???? */ rtgui_thread_deregister(rt_thread_self()); /* delete message queue */ rt_mq_delete(mq); } /* ??????workbench */ void workbench_init() { rt_thread_t tid; tid = rt_thread_create("wb", workbench_panel1, RT_NULL, 2048, 20, 5); if (tid != RT_NULL) rt_thread_startup(tid); } void gui_init() { extern void rtgui_touch_hw_init(void); extern rt_err_t load_setup(void); rtgui_rect_t rect; /* ??????RT-Thread/GUI server */ rtgui_system_server_init(); /* ×??á??°? */ rect.x1 = 0; rect.y1 = 0; rect.x2 = 240; rect.y2 = 320; rtgui_panel_register("main", &rect); rtgui_panel_set_default_focused("main"); /* ??????LCD???? */ rt_hw_lcd_init(); /* ???????ü?????? */ //rt_hw_key_init(); /* ???????????????? */ load_setup(); //touch×°???????? rtgui_touch_hw_init(); rt_device_init_all(); /* ??????workbench */ workbench_init(); }
8.1k
Steva
Welcome to RT-Thread RTOS English discussion
good!
The speed of external SRAM of STM32
RT-Thread on ST Forum
Splay Tree
More RTGUI screenshot
STM32 pimer2
mini2440 support
Howto Run RT-Thread 0.4.0 on QEMU/mini2440
RT-Gui : how can use it?
