Devices
请教spi驱动lcd显示屏问题
发布于 2018-12-03 17:20:48 浏览:2728
/* * SPI_ILI9225_LCD驱动 */ #include "drv_lcd.h" #define SPI_BUS_NAME "spi1" #define SPI_ILI9225_LCD_NAME "spi10" struct LCD_ILI9225_SPI_CS//片选 { rt_uint8_t pin; }; struct rt_lcd_ops { void (* drawPoint)(rt_uint8_t x,rt_uint8_t y,rt_uint16_t data); void (* drawLine)(rt_uint16_t x0, rt_uint16_t y0,rt_uint16_t x1, rt_uint16_t y1,rt_uint16_t Color); void (* drawCircle)(rt_uint16_t X,rt_uint16_t Y,rt_uint16_t R,rt_uint16_t fc); void (* drawRect)(rt_uint16_t x, rt_uint16_t y, rt_uint16_t w, rt_uint16_t h,rt_uint16_t bc); }; static struct rt_spi_device spi_dev_lcd; static struct LCD_ILI9225_SPI_CS spi_cs; void delay_ms(rt_uint32_t nms) { volatile rt_uint16_t i; while (nms--) { for (i = 0; i < 500; i++) { __NOP(); } } } //发送命令 static void ILI9225_write_reg(const rt_uint8_t cmd) { rt_size_t len; rt_pin_write(TFT_RS,PIN_LOW); len = rt_spi_send(&spi_dev_lcd,&cmd,1); if (len != 1) { rt_kprintf("ILI9225_write_reg error. %d
", len); } } //发送数据 static void ILI9225_write_data(const rt_uint8_t data) { rt_size_t len; rt_pin_write(TFT_RS,PIN_HIGH); len = rt_spi_send(&spi_dev_lcd, &data, 1); if (len != 1) { rt_kprintf("ILI9225_write_data error. %d
", len); } } //发送16位数据 static void ILI9225_write_16bit_data(const rt_uint16_t data) { ILI9225_write_data(data >> 8); ILI9225_write_data(data&0x00ff); } //寄存器写数据 static void ILI9225_write_reg_with_data(const rt_uint8_t cmd,const rt_uint16_t data) { ILI9225_write_reg(cmd); ILI9225_write_16bit_data(data); } //SPI配置 static int rt_hw_ILI9225_config(void) { rt_err_t res; spi_cs.pin=TFT_CS; rt_pin_mode(spi_cs.pin,PIN_MODE_OUTPUT); res = rt_spi_bus_attach_device(&spi_dev_lcd, SPI_ILI9225_LCD_NAME, SPI_BUS_NAME,(void* )&spi_cs); if (res != RT_EOK) { rt_kprintf("rt_spi_bus_attach_device!
"); return res; } /* config spi */ { struct rt_spi_configuration cfg; cfg.data_width = 8; cfg.mode = RT_SPI_MASTER | RT_SPI_MODE_MASK; cfg.max_hz = 20 * 1000 * 1000; /* 20M,SPI max 42MHz, 4-wire spi */ rt_spi_configure(&spi_dev_lcd, &cfg); } return RT_EOK; } // static int ILI9225_hw_level_Init(void) { rt_hw_ILI9225_config(); rt_pin_mode(TFT_RS, PIN_MODE_OUTPUT); //LCD Init For 2.0inch LCD Panel with ILI9225. ILI9225_write_reg_with_data(0x10, 0x0000); // Set SAP,DSTB,STB ILI9225_write_reg_with_data(0x11, 0x0000); // Set APON,PON,AON,VCI1EN,VC ILI9225_write_reg_with_data(0x12, 0x0000); // Set BT,DC1,DC2,DC3 ILI9225_write_reg_with_data(0x13, 0x0000); // Set GVDD ILI9225_write_reg_with_data(0x14, 0x0000); // Set VCOMH/VCOML voltage delay_ms(40); // Delay 20 ms // Please follow this power on sequence ILI9225_write_reg_with_data(0x11, 0x0018); // Set APON,PON,AON,VCI1EN,VC ILI9225_write_reg_with_data(0x12, 0x1121); // Set BT,DC1,DC2,DC3 ILI9225_write_reg_with_data(0x13, 0x0063); // Set GVDD ILI9225_write_reg_with_data(0x14, 0x3961); // Set VCOMH/VCOML voltage ILI9225_write_reg_with_data(0x10, 0x0800); // Set SAP,DSTB,STB delay_ms(10); // Delay 10 ms ILI9225_write_reg_with_data(0x11, 0x1038); // Set APON,PON,AON,VCI1EN,VC delay_ms(30); // Delay 30 ms ILI9225_write_reg_with_data(0x02, 0x0100); // set 1 line inversion ILI9225_write_reg_with_data(0x01,0x001C);//横屏 ILI9225_write_reg_with_data(0x03,0x1038); ILI9225_write_reg_with_data(0x07, 0x0000); // Display off ILI9225_write_reg_with_data(0x08, 0x0808); // set the back porch and front porch ILI9225_write_reg_with_data(0x0B, 0x1100); // set the clocks number per line ILI9225_write_reg_with_data(0x0C, 0x0000); // CPU interface ILI9225_write_reg_with_data(0x0F, 0x0501); // Set Osc ILI9225_write_reg_with_data(0x15, 0x0020); // Set VCI recycling ILI9225_write_reg_with_data(0x20, 0x0000); // RAM Address ILI9225_write_reg_with_data(0x21, 0x0000); // RAM Address //-------------- Set GRAM area -----------------// ILI9225_write_reg_with_data(0x30, 0x0000); ILI9225_write_reg_with_data(0x31, 0x00DB); ILI9225_write_reg_with_data(0x32, 0x0000); ILI9225_write_reg_with_data(0x33, 0x0000); ILI9225_write_reg_with_data(0x34, 0x00DB); ILI9225_write_reg_with_data(0x35, 0x0000); ILI9225_write_reg_with_data(0x36, 0x00AF); ILI9225_write_reg_with_data(0x37, 0x0000); ILI9225_write_reg_with_data(0x38, 0x00DB); ILI9225_write_reg_with_data(0x39, 0x0000); // ----------- Adjust the Gamma Curve ----------// ILI9225_write_reg_with_data(0x50, 0x0603); ILI9225_write_reg_with_data(0x51, 0x080D); ILI9225_write_reg_with_data(0x52, 0x0D0C); ILI9225_write_reg_with_data(0x53, 0x0205); ILI9225_write_reg_with_data(0x54, 0x040A); ILI9225_write_reg_with_data(0x55, 0x0703); ILI9225_write_reg_with_data(0x56, 0x0300); ILI9225_write_reg_with_data(0x57, 0x0400); ILI9225_write_reg_with_data(0x58, 0x0B00); ILI9225_write_reg_with_data(0x59, 0x0017); ILI9225_write_reg_with_data(0x0F, 0x0701); // Vertical RAM Address Position ILI9225_write_reg_with_data(0x07, 0x0012); // Vertical RAM Address Position delay_ms(50); // Delay 50ms ILI9225_write_reg_with_data(0x07, 0x1017); // Vertical RAM Address Position rt_pin_mode(TFT_LEDA,PIN_MODE_OUTPUT); rt_pin_write(TFT_LEDA,PIN_HIGH); rt_thread_delay(10); lcd_clear(GREEN); return 0; } SPI10挂载成功,ili9225初始化代码也没问题,但是不能实现清屏****** 求大神指导
2018-12-03
先挂上逻辑分析仪再说,
丿纸飞机巛
2018-12-04
[i=s] 本帖最后由 丿纸飞机巛 于 2018-12-4 12:06 编辑 [/i] >先挂上逻辑分析仪再说, --- 我看了一下逻辑分析仪,是sck 和mosi没信号,cs和dc都有信号,查了一下drv_spi,发现没问题呀,,,,,不知道咋整
2.7k
丿纸飞机巛
LCD双缓冲有什么好的办法实现
LCD NT35510 驱动代码
io设备驱动的疑惑与建议
液晶屏驱动 U8g2 移植
求助:在模板上添加LCD模块出现L6406E错误
hwtimer硬件定时器驱动和使用经验
硬件定时器超时时间计算问题
不使用 RT-Thread 的驱动框架结构可以吗?
