rt1052下的usb host
发布于 2018-12-12 09:34:55 浏览:3365
在rt1052下,env配置usb device ,会生成一个drv_usbd.c 但是env配置usb host ,没有生成drv_usbh.c 是因为这块的驱动还没有写,还是我的env有问题
yqiu
2018-12-12
USB Host 的驱动还没有呢。
w1019564793
2018-12-12
[i=s] 本帖最后由 w1019564793 于 2018-12-12 14:00 编辑 [/i] >USB Host 的驱动还没有呢。 --- 这边有点急,能提供点思路吗 可以按照这个结构来吗 ``` /* * File : stm32_usbh.c * This file is part of RT-Thread RTOS * COPYRIGHT (C) 2015, RT-Thread Development Team * * The license and distribution terms for this file may be * found in the file LICENSE in this distribution or at * http://www.rt-thread.org/license/LICENSE * * Change Logs: * Date Author Notes * 2017-10-30 ZYH the first version */ #include "drv_usbh.h" #include
#include "board.h" #define OTG_FS_PORT 1 static HCD_HandleTypeDef _stm_hhcd_fs; static struct rt_completion urb_completion; void HAL_HCD_MspInit(HCD_HandleTypeDef *hcdHandle) { GPIO_InitTypeDef GPIO_InitStruct; if (hcdHandle->Instance == USB_OTG_FS) { /**USB_OTG_FS GPIO Configuration PA9 ------> USB_OTG_FS_VBUS PA10 ------> USB_OTG_FS_ID PA11 ------> USB_OTG_FS_DM PA12 ------> USB_OTG_FS_DP */ __HAL_RCC_GPIOA_CLK_ENABLE(); #ifdef USBH_USING_VBUS GPIO_InitStruct.Pin = GPIO_PIN_9; GPIO_InitStruct.Mode = GPIO_MODE_INPUT; GPIO_InitStruct.Pull = GPIO_NOPULL; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); #endif GPIO_InitStruct.Pin = GPIO_PIN_12 | GPIO_PIN_11; GPIO_InitStruct.Mode = GPIO_MODE_AF_PP; GPIO_InitStruct.Pull = GPIO_NOPULL; GPIO_InitStruct.Speed = GPIO_SPEED_FREQ_LOW; GPIO_InitStruct.Alternate = GPIO_AF10_OTG_FS; HAL_GPIO_Init(GPIOA, &GPIO_InitStruct); /* Peripheral clock enable */ __HAL_RCC_USB_OTG_FS_CLK_ENABLE(); /* Peripheral interrupt init */ HAL_NVIC_SetPriority(OTG_FS_IRQn, 5, 0); HAL_NVIC_EnableIRQ(OTG_FS_IRQn); } } void HAL_HCD_MspDeInit(HCD_HandleTypeDef *hcdHandle) { if (hcdHandle->Instance == USB_OTG_FS) { /* Peripheral clock disable */ __HAL_RCC_USB_OTG_FS_CLK_DISABLE(); /**USB_OTG_FS GPIO Configuration PA9 ------> USB_OTG_FS_VBUS PA10 ------> USB_OTG_FS_ID PA11 ------> USB_OTG_FS_DM PA12 ------> USB_OTG_FS_DP */ #ifdef USBH_USING_VBUS HAL_GPIO_DeInit(GPIOA, GPIO_PIN_9); #endif HAL_GPIO_DeInit(GPIOA, GPIO_PIN_12 | GPIO_PIN_11); /* Peripheral interrupt Deinit*/ HAL_NVIC_DisableIRQ(OTG_FS_IRQn); } } void OTG_FS_IRQHandler(void) { rt_interrupt_enter(); HAL_HCD_IRQHandler(&_stm_hhcd_fs); rt_interrupt_leave(); } void HAL_HCD_SOF_Callback(HCD_HandleTypeDef *hhcd)//提供定时器 { //rt_kprintf("sof callback\n"); } static __IO rt_bool_t connect_status = RT_FALSE; void HAL_HCD_Connect_Callback(HCD_HandleTypeDef *hhcd) { uhcd_t hcd = (uhcd_t)hhcd->pData; if (!connect_status) { connect_status = RT_TRUE; RT_DEBUG_LOG(RT_DEBUG_USB, ("connected\n")); rt_usbh_root_hub_connect_handler(hcd, OTG_FS_PORT, RT_FALSE); } } void HAL_HCD_Disconnect_Callback(HCD_HandleTypeDef *hhcd) { uhcd_t hcd = (uhcd_t)hhcd->pData; if (connect_status) { connect_status = RT_FALSE; RT_DEBUG_LOG(RT_DEBUG_USB, ("disconnnect\n")); rt_usbh_root_hub_disconnect_handler(hcd, OTG_FS_PORT); } } void HAL_HCD_HC_NotifyURBChange_Callback(HCD_HandleTypeDef *hhcd, uint8_t chnum, HCD_URBStateTypeDef urb_state) { //rt_kprintf("NotifyURBChange_Callback\n"); rt_completion_done(&urb_completion); } static rt_err_t drv_reset_port(rt_uint8_t port) { RT_DEBUG_LOG(RT_DEBUG_USB, ("reset port\n")); HAL_HCD_ResetPort(&_stm_hhcd_fs); return RT_EOK; } static int drv_pipe_xfer(upipe_t pipe, rt_uint8_t token, void *buffer, int nbytes, int timeout) { while (1) { if (!connect_status) { return -1; } rt_completion_init(&urb_completion); HAL_HCD_HC_SubmitRequest(&_stm_hhcd_fs, pipe->pipe_index, (pipe->ep.bEndpointAddress & 0x80) >> 7, pipe->ep.bmAttributes, token, buffer, nbytes, 0); rt_completion_wait(&urb_completion, timeout); if (HAL_HCD_HC_GetState(&_stm_hhcd_fs, pipe->pipe_index) == HC_NAK) { RT_DEBUG_LOG(RT_DEBUG_USB, ("nak\n")); if (pipe->ep.bmAttributes == USB_EP_ATTR_INT) { rt_thread_delay((pipe->ep.bInterval * RT_TICK_PER_SECOND / 1000) > 0 ? (pipe->ep.bInterval * RT_TICK_PER_SECOND / 1000) : 1); } HAL_HCD_HC_Halt(&_stm_hhcd_fs, pipe->pipe_index); HAL_HCD_HC_Init(&_stm_hhcd_fs, pipe->pipe_index, pipe->ep.bEndpointAddress, pipe->inst->address, USB_OTG_SPEED_FULL, pipe->ep.bmAttributes, pipe->ep.wMaxPacketSize); continue; } else if (HAL_HCD_HC_GetState(&_stm_hhcd_fs, pipe->pipe_index) == HC_STALL) { RT_DEBUG_LOG(RT_DEBUG_USB, ("stall\n")); pipe->status = UPIPE_STATUS_STALL; if (pipe->callback != RT_NULL) { pipe->callback(pipe); } return -1; } else if (HAL_HCD_HC_GetState(&_stm_hhcd_fs, pipe->pipe_index) == URB_ERROR) { RT_DEBUG_LOG(RT_DEBUG_USB, ("error\n")); pipe->status = UPIPE_STATUS_ERROR; if (pipe->callback != RT_NULL) { pipe->callback(pipe); } return -1; } else if (HAL_HCD_HC_GetURBState(&_stm_hhcd_fs, pipe->pipe_index) != URB_NOTREADY && HAL_HCD_HC_GetURBState(&_stm_hhcd_fs, pipe->pipe_index) != URB_NYET) { RT_DEBUG_LOG(RT_DEBUG_USB, ("ok\n")); pipe->status = UPIPE_STATUS_OK; if (pipe->callback != RT_NULL) { pipe->callback(pipe); } return nbytes; } return -1; } } static rt_uint16_t pipe_index = 0; static rt_uint8_t drv_get_free_pipe_index() { rt_uint8_t idx; for (idx = 1; idx < 16; idx++) { if (!(pipe_index & (0x01 << idx))) { pipe_index |= (0x01 << idx); return idx; } } return 0xff; } static void drv_free_pipe_index(rt_uint8_t index) { pipe_index &= ~(0x01 << index); } static rt_err_t drv_open_pipe(upipe_t pipe) { pipe->pipe_index = drv_get_free_pipe_index(); HAL_HCD_HC_Init(&_stm_hhcd_fs, pipe->pipe_index, pipe->ep.bEndpointAddress, pipe->inst->address, USB_OTG_SPEED_FULL, pipe->ep.bmAttributes, pipe->ep.wMaxPacketSize); /* Set DATA0 PID token*/ if (_stm_hhcd_fs.hc[pipe->pipe_index].ep_is_in) { _stm_hhcd_fs.hc[pipe->pipe_index].toggle_in = 0; } else { _stm_hhcd_fs.hc[pipe->pipe_index].toggle_out = 0; } return RT_EOK; } static rt_err_t drv_close_pipe(upipe_t pipe) { HAL_HCD_HC_Halt(&_stm_hhcd_fs, pipe->pipe_index); drv_free_pipe_index(pipe->pipe_index); return RT_EOK; } struct uhcd_ops _uhcd_ops = { drv_reset_port, drv_pipe_xfer, drv_open_pipe, drv_close_pipe, }; static rt_err_t _init(rt_device_t device) { HCD_HandleTypeDef *hhcd = (HCD_HandleTypeDef *)device->user_data; hhcd->Instance = USB_OTG_FS; hhcd->Init.Host_channels = 8; hhcd->Init.speed = HCD_SPEED_FULL; hhcd->Init.dma_enable = DISABLE; hhcd->Init.phy_itface = HCD_PHY_EMBEDDED; hhcd->Init.Sof_enable = DISABLE; RT_ASSERT(HAL_HCD_Init(hhcd) == HAL_OK); HAL_HCD_Start(hhcd); #ifdef USBH_USING_CONTROLLABLE_POWER rt_pin_mode(USBH_POWER_PIN, PIN_MODE_OUTPUT); rt_pin_write(USBH_POWER_PIN, PIN_LOW); #endif return RT_EOK; } int stm_usbh_register(void) { uhcd_t uhcd = (uhcd_t)rt_malloc(sizeof(struct uhcd)); RT_ASSERT(uhcd != RT_NULL); rt_memset((void *)uhcd, 0, sizeof(struct uhcd)); uhcd->parent.type = RT_Device_Class_USBHost; uhcd->parent.init = _init; uhcd->parent.user_data = &_stm_hhcd_fs; uhcd->ops = &_uhcd_ops; uhcd->num_ports = 1; _stm_hhcd_fs.pData = uhcd; rt_device_register((rt_device_t)uhcd, "usbh", 0); rt_usb_host_init(); return RT_EOK; } INIT_DEVICE_EXPORT(stm_usbh_register); ```
lymzzyh
2018-12-12
没有host驱动,有能力可以自己写,比较急建议用NXP的协议栈
杨庆涛NB
2018-12-14
>USB Host 的驱动还没有呢。 --- 由于计划写这块吗:)
tanliang23
2019-03-25
楼主这块解决了吗,我现在也遇到了想用usb host udisk 配置完了 用不了,驱动注册没搞完呢,不行就移植协议栈,不走OS了
tanliang23
2019-03-28
顶一顶
bear1
2019-08-09
RTT现在支持USB Host 了吗?
3.4k
w1019564793
37
请教USB Host
STM32F4调试USB 读卡器(Slave)提示格式化
USB 框架问题
USB键盘
LPC17xx 如何添加USB HOST设备
RT-Thread目前支持USB HOST了吗?
USB HOST的支持问题
USB库已经很久没更新了
