IoT_Board笔记2:LED闪烁例程_通用GPIO设备
发布于 2018-12-27 10:05:11 浏览:1640
参考内容:通用GPIO设备应用笔记[https://www.rt-thread.org/document/site/rtthread-application-note/driver/gpio/an0002-rtthread-driver-gpio/](https://www.rt-thread.org/document/site/rtthread-application-note/driver/gpio/an0002-rtthread-driver-gpio/)**问题:#define LED_PIN PIN_LED_R io口是如何一一对应起来的。**在drv_gpio.c文件中 列出了100个引脚的对应关系还有中断的相关关系。 ```static const struct pin_index pins[] = { __STM32_PIN_DEFAULT, __STM32_PIN(1, E, 2), // PE2: SAI1_MCLK_A --> ES8388 __STM32_PIN(2, E, 3), // PE3: SAI1_SD_B --> ES8388 __STM32_PIN(3, E, 4), // PE4: SAI1_FS_A --> ES8388 __STM32_PIN(4, E, 5), // PE5: SAI1_SCK_A --> ES8388 __STM32_PIN(5, E, 6), // PE6: SAI1_SD_A --> ES8388 __STM32_PIN_DEFAULT, // : VBAT __STM32_PIN(7, C, 13), //PC13: SD_CS --> SD_CARD __STM32_PIN(8, C, 14), //PC14: OSC32_IN __STM32_PIN(9, C, 15), //PC15: OSC32_OUT __STM32_PIN_DEFAULT, // : VSS __STM32_PIN_DEFAULT, // : VDD __STM32_PIN_DEFAULT, // PH0: OSC_IN __STM32_PIN_DEFAULT, // PH1: OSC_OUT __STM32_PIN_DEFAULT, // : RESET __STM32_PIN(15, C, 0), // PC0: I2C_SCL --> ES8388 __STM32_PIN(16, C, 1), // PC1: I2C_SDA --> ES8388 __STM32_PIN(17, C, 2), // PC2: GBC_LED --> ATK MODULE __STM32_PIN(18, C, 3), // PC3: GBC_KEY --> ATK MODULE __STM32_PIN_DEFAULT, // : VSSA __STM32_PIN_DEFAULT, // : VREF- __STM32_PIN_DEFAULT, // : VREF+ __STM32_PIN_DEFAULT, // : VDDA __STM32_PIN(23, A, 0), // PA0: MOTOR_A --> MOTOR __STM32_PIN(24, A, 1), // PA1: MOTOR_B --> MOTOR __STM32_PIN(25, A, 2), // PA2: UART2_TX --> EXTERNAL MODULE __STM32_PIN(26, A, 3), // PA3: UART2_RX --> EXTERNAL MODULE __STM32_PIN_DEFAULT, // : VSS __STM32_PIN_DEFAULT, // : VDD __STM32_PIN(29, A, 4), // PA4: ADC12_IN9 --> EXTERNAL MODULE __STM32_PIN(30, A, 5), // PA5: SPI1_SCK --> SD_CARD __STM32_PIN(31, A, 6), // PA6: SPI1_MISO --> SD_CARD __STM32_PIN(32, A, 7), // PA7: SPI1_MOSI --> SD_CARD __STM32_PIN(33, C, 4), // PC4: GBC_RX --> ATK MODULE __STM32_PIN(34, C, 5), // PC5: WIFI_INT --> WIFI __STM32_PIN(35, B, 0), // PB0: EMISSION --> INFRARED EMISSION __STM32_PIN(36, B, 1), // PB1: RECEPTION --> INFRARED EMISSION __STM32_PIN(37, B, 2), // PB2: BEEP --> BEEP __STM32_PIN(38, E, 7), // PE7: LED_R --> LED __STM32_PIN(39, E, 8), // PE8: LED_G --> LED __STM32_PIN(40, E, 9), // PE9: LED_B --> LED __STM32_PIN(41, E, 10), //PE10: QSPI_BK1_CLK --> SPI_FLASH __STM32_PIN(42, E, 11), //PE11: QSPI_BK1_NCS --> SPI_FLASH __STM32_PIN(43, E, 12), //PE12: QSPI_BK1_IO0 --> SPI_FLASH __STM32_PIN(44, E, 13), //PE13: QSPI_BK1_IO1 --> SPI_FLASH __STM32_PIN(45, E, 14), //PE14: QSPI_BK1_IO2 --> SPI_FLASH __STM32_PIN(46, E, 15), //PE15: QSPI_BK1_IO3 --> SPI_FLASH __STM32_PIN(47, B, 10), //PB10: AP_INT --> ALS&PS SENSOR __STM32_PIN(48, B, 11), //PB11: ICM_INT --> AXIS SENSOR __STM32_PIN_DEFAULT, // : VSS __STM32_PIN_DEFAULT, // : VDD __STM32_PIN(51, B, 12), //PB12: SPI2_CS --> EXTERNAL MODULE __STM32_PIN(52, B, 13), //PB13: SPI2_SCK --> EXTERNAL MODULE __STM32_PIN(53, B, 14), //PB14: SPI2_MISO --> EXTERNAL MODULE __STM32_PIN(54, B, 15), //PB15: SPI2_MOSI --> EXTERNAL MODULE __STM32_PIN(55, D, 8), // PD8: KEY0 --> KEY __STM32_PIN(56, D, 9), // PD9: KEY1 --> KEY __STM32_PIN(57, D, 10), //PD10: KEY2 --> KEY __STM32_PIN(58, D, 11), //PD11: WK_UP --> KEY __STM32_PIN(59, D, 12), //PD12: IO_PD12 --> EXTERNAL MODULEL __STM32_PIN(60, D, 13), //PD13: IO_PD13 --> EXTERNAL MODULE __STM32_PIN(61, D, 14), //PD14: IO_PD14 --> EXTERNAL MODULE __STM32_PIN(62, D, 15), //PD15: IO_PD15 --> EXTERNAL MODULE __STM32_PIN(63, C, 6), // PC6: TIM3_CH1 --> EXTERNAL MODULE __STM32_PIN(64, C, 7), // PC7: TIM3_CH2 --> EXTERNAL MODULE __STM32_PIN(65, C, 8), // PC8: SDIO_D0 --> WIFI __STM32_PIN(66, C, 9), // PC9: SDIO_D1 --> WIFI __STM32_PIN(67, A, 8), // PA8: IO_PA8 --> EXTERNAL MODULE __STM32_PIN(68, A, 9), // PA9: UART1_TX --> STLINK_RX __STM32_PIN(69, A, 10), //PA10: UART1_RX --> STLINK_RX __STM32_PIN(70,A, 11), // PA11: USB_D- --> USB OTG && EXTERNAL MODULE __STM32_PIN(71, A, 12), //PA12: USB_D+ --> USB OTG && EXTERNALMODULE __STM32_PIN(72, A, 13), //PA13: T_JTMS --> STLINK __STM32_PIN_DEFAULT, // : VDDUSB __STM32_PIN_DEFAULT, // : VSS __STM32_PIN_DEFAULT, // : VDD __STM32_PIN(76, A, 14), //PA14: T_JTCK --> STLINK __STM32_PIN(77, A, 15), //PA15: AUDIO_PWR --> AUDIO && POWER __STM32_PIN(78, C, 10), //PC10: SDIO_D2 --> WIFI __STM32_PIN(79, C, 11), //PC11: SDIO_D3 --> WIFI __STM32_PIN(80, C, 12), //PC12: SDIO_CLK --> WIFI __STM32_PIN(81, D, 0), // __STM32_PIN(82, D, 1), // PD1: WIFI_REG_ON --> WIFI __STM32_PIN(83, D, 2), // PD2: SDIO_CMD --> WIFI __STM32_PIN(84, D, 3), // PD3: IO_PD3 --> EXTERNAL MODULE __STM32_PIN(85, D, 4), // PD4: NRF_IRQ --> WIRELESS __STM32_PIN(86, D, 5), // PD5: NRF_CE --> WIRELESS __STM32_PIN(87, D, 6), // PD6: NRF_CS --> WIRELESS __STM32_PIN(88, D, 7), // PD7: LCD_CS --> LCD __STM32_PIN(89, B, 3), // PB3: LCD_SPI_SCK --> LCD __STM32_PIN(90, B, 4), // PB4: LCD_WR --> LCD __STM32_PIN(91, B, 5), // PB5: LCD_SPI_SDA --> LCD __STM32_PIN(92, B, 6), // PB6: LCD_RESET --> LCD __STM32_PIN(93, B, 7), // PB7: LCD_PWR --> LCD __STM32_PIN_DEFAULT, // : BOOT0 __STM32_PIN(95, B, 8), // PB8: I2C1_SCL --> EXTERNAL MODULE __STM32_PIN(96, B, 9), // PB9: I2C1_SDA --> EXTERNAL MODULE __STM32_PIN(97, E, 0), // PE0: IO_PE0 --> EXTERNAL MODULE __STM32_PIN(98, E, 1), // PE1: IO_PE1 --> EXTERNAL MODULE __STM32_PIN_DEFAULT, // : VSS __STM32_PIN_DEFAULT, // : VDD };``` 注册初始化 ```int rt_hw_pin_init(void) { return rt_device_pin_register("pin", &_stm32_pin_ops,RT_NULL); } const static struct rt_pin_ops_stm32_pin_ops = { stm32_pin_mode, stm32_pin_write, stm32_pin_read, stm32_pin_attach_irq, stm32_pin_dettach_irq, stm32_pin_irq_enable, };``` **IO设备管理框架与通用GPIO设备的联系** RT-Thread 提供了一套简单的I/O 设备管理框架,它把 I/O 设备分成了三层进行处理:应用层、I/O 设备管理层、硬件驱动层。应用程序通过 RT-Thread 的设备操作接口获得正确的设备驱动,然后通过这个设备驱动与底层 I/O 硬件设备进行数据(或控制)交互。RT-Thread 提供给上层应用的是一个抽象的设备操作接口,给下层设备提供的是底层驱动框架。对于通用 GPIO 设备,应用程序既可以通过设备操作接口访问,又可以直接通过通用 GPIO 设备驱动来访问。一般来说,我们都是使用第二种方式。那么如何在 RT-Thread 中使用通用 GPIO 设备驱动从而操作 GPIO 呢?RT-Thread 自动初始化功能依次调用 rt_hw_pin_init ===> rt_device_pin_register ===>rt_device_register 完成了 GPIO 硬件初始化。rt_device_register 注册设备类型为RT_Device_Class_Miscellaneous,即杂类设备,从而我们就可以使用统一的 API 操作 GPIO。![1.png](/uploads/201812/27/100459znestpsryptytzon.png) **程序运行流程怎么一步一步开始的?**在rtconfig.h中 配置使用PIN设备。 ```/* Kernel Device Object */ #define RT_USING_DEVICE #define RT_USING_CONSOLE #define RT_CONSOLEBUF_SIZE 256 #define RT_CONSOLE_DEVICE_NAME"uart1" /* RT-Thread Components */ #define RT_USING_COMPONENTS_INIT #define RT_USING_USER_MAIN 启动方式之一 #define RT_MAIN_THREAD_STACK_SIZE 2048 #define RT_MAIN_THREAD_PRIORITY 10 /* Device Drivers */ #define RT_USING_DEVICE_IPC #define RT_PIPE_BUFSZ 512 #define RT_USING_SERIAL #define RT_USING_PIN``` 都在components.c中,从startup_stm32l475xx.s 启动文件中开始。 ```; Reset handler Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT SystemInit //系统初始化,时钟相关等 IMPORT __main LDR R0, =SystemInit BLX R0 LDR R0, =__main BX R0 ENDP ; Dummy Exception Handlers (infinite loopswhich can be modified)``` 由于rtconfig.h配置宏RT_USING_USER_MAIN,表明通过组件的方式跳到main函数,不过此时过程是,先重新定义main函数int $Sub$$main(void),代码先跳到int$Sub$$main(void)执行, 调用rt_application_init();创建main线程,在main线程中调用main函数详见:components.c中: ```#if defined(__CC_ARM) ||defined(__CLANG_ARM) extern int $Super$main(void); /* re-define main function */ int $Sub$main(void) { rt_hw_interrupt_disable(); rtthread_startup();//启动rtos. return 0; } int rtthread_startup(void) { rt_hw_interrupt_disable(); /* board level initialization * NOTE: please initialize heap inside board initialization. */ rt_hw_board_init();//这里会进行rt_hw_pin_init()stm32_hw_usart_init();注册IO 串口设备 /* show RT-Thread version */ rt_show_version(); /* timer system initialization */ rt_system_timer_init(); /* scheduler system initialization */ rt_system_scheduler_init(); #ifdef RT_USING_SIGNALS /* signal system initialization */ rt_system_signal_init(); #endif /* create init_thread */ rt_application_init();//在这里创建main.c 的入口函数。 /* timer thread initialization */ rt_system_timer_thread_init(); /* idle thread initialization */ rt_thread_idle_init(); #ifdef RT_USING_SMP rt_hw_spin_lock(&_cpus_lock); #endif /*RT_USING_SMP*/ /* start scheduler */ rt_system_scheduler_start(); /* never reach here */ return 0; } void rt_application_init(void) { rt_thread_t tid; #ifdef RT_USING_HEAP tid = rt_thread_create("main", main_thread_entry, RT_NULL, RT_MAIN_THREAD_STACK_SIZE, RT_MAIN_THREAD_PRIORITY, 20); RT_ASSERT(tid != RT_NULL); #else rt_err_t result; tid = &main_thread; result = rt_thread_init(tid, "main", main_thread_entry,RT_NULL, main_stack,sizeof(main_stack), RT_MAIN_THREAD_PRIORITY, 20); RT_ASSERT(result == RT_EOK); /* if not define RT_USING_HEAP, using to eliminate the warning */ (void)result; #endif rt_thread_startup(tid);//启动这个线程。 } /* the system main thread */ void main_thread_entry(void *parameter) { extern int main(void); extern int $Super$main(void); /* RT-Thread components initialization */ rt_components_init();//组件初始化,这个例程暂时没用到。 #ifdef RT_USING_SMP rt_hw_secondary_cpu_up(); #endif /* invoke system main function */ #if defined(__CC_ARM) ||defined(__CLANG_ARM) $Super$main(); /* for ARMCC. */转到main.c中 #elif defined(__ICCARM__) ||defined(__GNUC__) main(); #endif }``` 由于定义#define RT_USING_COMPONENTS_INIT ```/* *Components Initialization will initialize some driver and components asfollowing *order: *rti_start --> 0 *BOARD_EXPORT --> 1 *rti_board_end --> 1.end * *DEVICE_EXPORT --> 2 *COMPONENT_EXPORT --> 3 *FS_EXPORT --> 4 *ENV_EXPORT --> 5 *APP_EXPORT --> 6 * *rti_end --> 6.end * *These automatically initialization, the driver or component initial functionmust * bedefined with: *INIT_BOARD_EXPORT(fn); * INIT_DEVICE_EXPORT(fn); *... *INIT_APP_EXPORT(fn); *etc. */ int main(void) { unsigned int count = 1; /* set LED pin mode to output */ rt_pin_mode(LED_PIN, PIN_MODE_OUTPUT); while (count > 0) { /* led on */ rt_pin_write(LED_PIN, PIN_LOW); rt_kprintf("led on, count: %d
", count); rt_thread_mdelay(500); /* led off */ rt_pin_write(LED_PIN, PIN_HIGH); rt_kprintf("led off
"); rt_thread_mdelay(500); count++; } return 0; }```
XQQ
2019-01-11
沙发
1.6k
小住住
127
124
